The Nextcloud Quick reference on Docker Hub states that there are two versions (apache
or fpm
) of the Nextcloud image. The apache
version contains a full Nextcloud installation including an apache web server. The fpm
version must be combined with any webserver that can proxy the http requests to the FastCGI-port of the container.
In the Quick reference fpm
example, an nginx container is combined with the Nextcloud-fpm image and a MariaDB database container. If you would rather use Caddy in place of nginx, below you will find an equivalent fpm
example that replaces nginx with Caddy v2 as the webserver.
docker-compose.yml:
version: '2'
nextcloud:
db:
caddy_data:
db:
image: mariadb
command: --transaction-isolation=READ-COMMITTED --binlog-format=ROW
restart: always
- db:/var/lib/mysql
- MYSQL_ROOT_PASSWORD=
- MYSQL_PASSWORD=
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud:fpm
links:
- db
- nextcloud:/var/www/html
restart: always
web:
image: caddy
links:
- app
- caddy_data:/data
volumes_from:
- app
restart: always
Caddyfile:
root * /var/www/html
php_fastcgi app:9000
# enable HSTS
# Strict-Transport-Security max-age=31536000;
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
Reference: Dockerised Caddy V2 + Nextcloud-FPM to create an unsecured Nextcloud instance
