Use Caddy for local HTTPS (TLS) between front-end reverse proxy and LAN hosts
TL;DL
This Wiki explains how to enable https connections between hosts in a LAN with automatically renewed certificates. Just scroll down and go over the example Caddyfiles. They hopefully have enough comment to understand the idea :wink:
Introduction
If you have successfully followed the Wiki Using Caddy as a reverse proxy in a home network by @Matt, you have setup a reverse proxy that provides a TLS encrypted connection from the internet to that reverse proxy. This is mandatory and you shouldn’t want it any less. However, beyond the reverse proxy your connections are non-TLS.
This Wiki is about -also- adding TLS between that reverse proxy (frontend) and the hosts behind it (backends) with automatically renewed certificates. Whether this is important, is up to you. Normally, you should be able to trust your own LAN. But there may be situations you don’t want to take a chance. In my case I use the password manager Bitwarden and I didn’t want to send my passwords unencrypted over the LAN.
This Wiki assumes you have managed to setup a reverse proxy as explained in the Wiki Using Caddy as a reverse proxy in a home network. From here I have added TLS encryption to the backend(s).
Definitions and Requirements
The definitions and requirements from the Wiki mentioned above apply for this Wiki too. This Wiki has one extra requirement. You need to setup either a local DNS or split DNS.
With your own (split) DNS you can resolve Fully Qualified Domain Names (FQDN) in your LAN rather than using IP addresses. For example:
nextcloud.my.example.com → 192.168.0.4 or
office.roadrunner → 192.168.0.4
Going into details about DNS or split DNS is out of the scope of this Wiki. Cloudflare has a pretty good explanation what is DNS and more about split DNS can be found here.
Two well-known DNS systems are:
I use unbound because it is by default available in OPNsense and comes with a handy GUI.
Alternatively, you could also fill up your hosts files but I have not tested this myself. It will be much more work to maintain though.
Topology
The below figure is somewhat similar to the version without TLS in the LAN. There is a frontend host and two backend hosts. Each host can be virtual or physical. The frontend hosts acts as reverse proxy to the outside WWWorld and provides trusted certificates from Let’s Encrypt. The backend hosts are hosting several services.
The difference is that the same frontend Caddy service is also setup as a certificate authority using the ACME protocol (powered by smallstep) to provide certificates for the backends.
Each backend also has a Caddy service running that requests the certificate and to either act as a web server or reverse proxy (or both) to the desired services on that backend.
Note that the hosts with docker containers is just presented as a possibility. This Wiki will focus on the 2nd host with Nextcloud on it.
DNS
To set up the DNS you can follow the same guidance as in Using Caddy as a reverse proxy in a home network.
Local (Split) DNS
Each host should be given a FQDN to resolve the IP of the corresponding host in the local network. In this example I created:
caddy.roadrunner → 192.168.0.2 to reach the frontend (downstream) Caddy service
services.roadrunner → 192.168.0.3 to reach the 1st backend (upstream) host with services
office.roadrunner → 192.168.2.4 to reach the 2nd backend (upstream) host with services
I created domain names for the hosts because pointing directly to the IP addresses didn’t work with the ACME server. I was not able to get certificates for the backends.
Services
Services can either be installed natively or you can use docker containers. The Caddy services should not be in a docker container because this will complicate the automated certificate renewal.
Port forwarding
To set up the port forwarding you can follow the same guidance as in Using Caddy as a reverse proxy in a home network.
Local HTTPS
To enable local HTTPS you need to enable the ACME server in the Frontend Caddy service in the Caddyfile. In the backend you have to point to this server in the Caddyfile to request a certificate.
Frontend
To enable the ACME server in the frontend, include the acme_server directive in the Caddyfile.
# ACME Server
caddy.roadrunner {
	acme_server
	tls internal
Note that the FQDN caddy.roadrunner is used here.
Secondly, you need define or update the FQDN where Caddy listens to and reverse proxies accordingly with TLS.
nextcloud.my.example.com {
	reverse_proxy https://office.roadrunner {
In the above example, connections from nextcloud.my.example.com coming from the WAN are being forwarded to office.roadrunner with TLS enabled.
There is one extra line header_up Host {upstream_hostport} which is a host header with placeholder that will override the host header with the host name in the proxy upstream.
Read my question topic for more info.
Backends
There are two ways to configure the backends to request a certificate from the frontend.
  1. By setting the TLS directive for each domain that is configured in the Caddyfile, for example;
office.roadrunner {
		ca https://caddy.roadrunner/acme/local/directory
		ca_root /etc/ssl/certs/root.crt
Here the FQDN office.roadrunner is told to request a certificate from caddy.roadrunner.
  1. By setting one directive for the whole Caddyfile in the global section.
# Global Option Block
# TLS Options
acme_ca https://caddy.roadrunner/acme/local/directory
acme_ca_root /etc/ssl/certs/root.crt
Here a certificate is requested from caddy.roadrunner for each defined domain (sites) in the Caddyfile.
To request a certificate, a root certificate from the server is required. (Read this blog from Mike Malone to understand why). Once you have started the Caddy service on the frontend for the first time and there are no errors, a file named root.crt is generated in .local/share/caddy/pki/authorities/local
NOTE: The absolute path for the certificate depends on how you run Caddy. Typically when you use systemd the absolute path will be /var/lib/caddy/.local/share/caddy/pki/authorities/local but if you run caddy with caddy start the path .local/share/caddy/pki/authorities/local
You will have to copy this file to the backend and point to it in the Caddyfile. In the above example the file root.crt has been copied to /etc/ssl/certs/root.crt will be created in the in the directory you initiated the command (and where the Caddyfile is located).
If you are working with SSH terminals, you can just copy / paste the content of root.crt to the other terminal with your favourite txt editor, ie vim. The content will look something like this:
-----BEGIN CERTIFICATE-----
Mkd2PrifjSodwIBAgIQICdiSD4Yf9/2x0JL2MKkqzAKBggqhkjOPQQDAjAwMS4w
LAYDVQQDEyVDYWRkeSBMb2NhbCBBdXRob3JpdHkgLSAyMDIxIEVDQyBSb290MB4X
DTIxMDIwMzE3NDKEWRJ#fFJEklejejelWo3oFj3NTYyMlowMDEuMCwGA1UEAxMlQ2FkZHkg
TG9jYWwgQXV0aG9yaXR5IC0gMjAyMSBFQ0MgUm9vdDBZMBMGByqGSM49AgEGCCqG
SM49AwEHA0IABF6n6K32IongBmQmrFuTKCL0LlNWGY/aLUsWQtb6WazWMtEJxoH/
9FTO9zoUl5tPGyKU7yty6xFkejelfFDpoa[fpfWPOfkjewBDMA4GA1UdDwEB/wQEAwIBBjAS
BgNVHRMBAf8ECDAGAQH/AgEBMB0GA1UdDgQWBBShK2n24nbgtXrJTNjmfHIPfUTh
4jAKBggqhkjOPQQDAgNIADBFAiEAvAZzPc05PTyL2ilxcwIB5LEq9HDgl/eEtQok
Fu1VERUCIC4JxfRKk4PfhRcjBJ8Rz0cjYFJR9fOV90wFo9FEKw[pwq
-----END CERTIFICATE-----
Now the only thing left to do is to add a service to the defined domain office.roadrunner. You could directly point to a fileserver (Caddy is also a fileserver) or reverse proxy to another service on this backend. In this example I will use Nextcloud. The config is heavily inspired by this great Wiki by @basil
office.roadrunner {
	root * /var/www/html
	php_fastcgi 127.0.0.1:9000 {
		env front_controller_active true # Remove index.php form url
	header Strict-Transport-Security max-age=31536000; # enable HSTS
	@forbidden {
		path /.htaccess
		path /data/*
		path /config/*
		path /db_structure
		path /.xml
		path /README
		path /3rdparty/*
		path /lib/*
		path /templates/*
		path /occ
		path /console.php
	respond @forbidden 404
Test
After this you should be ready to caddy run or caddy reload if Caddy is already running.
When someone enters https://nextcloud.my.example.com in his browser a TLS encrypted connection is made to the frontend host with a certificate provided by Let’s Encrypt. The connection is then forwarded with TLS from the local ACME server to https://office.roadrunner on the backend host.
For debugging you can enable the debug option in the global section of each Caddy service.
Caddyfiles + comments
For completeness I have copied two full Caddyfiles for reference.
Frontend
	debug		# enable debugging. Comment out when everything is working
# ACME Server
acme.roadrunner {		# defining FQDN for ACME server
	acme_server		# defining the ACME server
	tls internal
# Nextcloud
nextcloud.my.example.com {		# defining incoming FQDN
Backend
	# General Option
	# TLS Options
	acme_ca https://acme.roadrunner/acme/local/directory # point to ACME server
	acme_ca_root /etc/ssl/certs/root.crt  # define root certificate
office.roadrunner {		# FQDN for the backend
        @forbidden {
                path /.htaccess
                path /data/*
                path /config/*
                path /db_structure
                path /.xml
                path /README
                path /3rdparty/*
                path /lib/*
                path /templates/*
                path /occ
                path /console.php
Disclaimer
Most of the information in this Wiki can be found in either the official documentation or in the many posts and Wiki’s on this forum. I tried to link as much as possible to the original source. Together with a lot of help from @francislavoie and @matt I was able to get the local https to work.
To come
In seperate Wiki’s I will post more Caddyfile examples how to host Nextcloud with Collabora, Bitwarden and Papermerge.
Caddy is really great in doing this because it’s got everything. Most of the times you can strip down the docker containers and remove Apache, Nginx Trafic and Cerbot and just let (one) Caddy service do the job.
HTTPS on LAN - Access via different host
Internal CA - Single point of failure?
Caddy reverse proxy + Nextcloud + Collabora + Vaultwarden with local HTTPS
Caddy as reverse proxy and acme-server with my own root-certificate in one docker container?
Caddy as reverse_proxy for another caddy serving wordpress
Caddy Lab / Setup Examples
Local HTTPS -- Using local ACME endpoint
Reverse proxy + nginx over https
mTLS under FreeBSD
Reverse proxy and self-signed certificate
TLS Handshake error when reverse proxy requesting certificate
TLS between frontend/backend 502
Reverse Proxy without files
Redirection issue with multiple chained Caddy reverse proxy servers
Jellyfin behind Caddy on an other server using internal tls
Cannot access apps (501 error) with Proxmox LxC homelab and Caddy as reverse proxy for DuckDNS subdomains
Caddy never stops
Reverse proxy parsing difficulties
mTLS under FreeBSD
mTLS under FreeBSD
mTLS under FreeBSD
mTLS under FreeBSD
mTLS under FreeBSD
mTLS between two Caddy reverse proxies
Configuring internal tls
Caddy, Traefik, Firewall && Cloudflare -- threading the TLS needle!
Acme server for local https - on synology
Reverse_proxy between valid external domain and a made up internal domain
Caddy as a challenge relay
Add dns entry to Opensense / Hooks?
Cert_Issuer defaults to LetsEncrypt
I was having a look at the acme directive last night and wondering how I might use it? Lo and behold, I now have a concrete example of its application in the wiki. Writing a well-thought-out wiki article like this one takes a lot of effort. @Rob789 Well done!
@matt You and your small team have done an amazing job of bringing Caddy this far. I’m sure it’s an understatement to say that you’re all being stretched thin on the ground, on top of giving up your free time in the forum. This is by no means a criticism, but I do find much of the documentation terse and difficult to put in context. You do a sterling job of tackling the ‘what’ and ‘how’. This is really a call out to the Caddy community to assist with the ‘when’, ‘where’ and ‘why’; to continue to ‘put some meat on the bones’ and deliver some super useful wiki articles like this one to help unravel the mysteries of the documentation.
Food for thought: The help section of the forum is largely about tapping into the depth and breadth of knowledge the Caddy team has. We’re ever so grateful when the team assists us in solving a problem that has us stumped. The wiki section of the forum is our opportunity to give back to the Caddy team for the tremendous support we receive.
A post was split to a new topic: Reverse proxy parsing difficulties
I was going to try setting up my net like this but then I realized there’s no need to have Caddy be man-in-the-middle, pointlessly decrypting and then re-encrypting the data when it could* just forward the raw data according to SNI (as I don’t need the gateway to do anything else with it). *Well it can’t but I mean I’m thinking to use this instead GitHub - dlundquist/sniproxy: Proxies incoming HTTP and TLS connections based on the hostname contained in the initial request of the TCP session.
Would be cool and especially efficient to have something like this right on the gateway router too.
Of course using different TCP ports or better-yet different IPv6 addresses would be even more efficient/simple but the web has not evolved in such a way that makes that practical :pensive:
TCP ports could be fine if u dont mind the number in urls but getting https for it is a mess cause the ACME challenge needs port 80/443 for that :confused: hey dont convert that emoji i want raw ‘:/’
@ledlamp you can use GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy for this.
Oh cool, that looks like awesome functionality for caddy to have!
A post was split to a new topic: Setting up NextCloud behind Caddy
Does the ACME server require using domain names or were you just unable to get it to work with the IP addresses? (@matt for additional insight) For my use-case I would prefer to just use IP addresses and not have a DNS system at all, but it is not obvious to me if that is possible. (Great post btw!)
Public ACME servers currently don’t generally issue certificates for IP addresses. (ZeroSSL I think does issue IP certs, but I’m not sure if their ACME endpoint does.)
Caddy’s internal (but not publicly-trusted) ACME server does issue IP certificates, IIRC.
However if you trust your internal network and the connections are purely internal, you probably don’t need TLS at all.
3 posts were split to a new topic: Local domains with public certs
The above method seems to require the backend Nextcloud service to have Caddy as a file server, ie. both in one container.
If the backend service doesn’t have Caddy as a file server (e.g. Nextcloud all-in-one image on its own container, without caddy), is TLS connection to Nextcloud not possible?
Is it possible to run Caddy in its own LXC container (should this be run as file server or as a second reverse proxy?) and Nextcloud all-in-one image in another container, and still able to set up TLS connection to Nextcloud?
Nextcloud “all-in-one” is a bit of a misnomer. It’s not actually all-in-one.
It has a “mastercontainer” which runs in Docker. The mastercontainer’s job appears to be to connect to your Docker socket, configure, and run all the other containers Nextcloud needs. It spins up a number of containers, and your control over these is limited.
It seems to use Caddy as a reverse proxy in the mastercontainer and Apache as a reverse proxy for the Nextcloud application itself, the latter of which is configured to listen on port 11000 on the host, by default.
Skimming over their documentation, it doesn’t seem like there’s a convenient way to change which ACME server they get certificates from, and it doesn’t seem like you can swap out Apache for something more suitable. Their recommendation for more complex HTTPS requirements is to simply put another Caddy server in front of Apache: all-in-one/reverse-proxy.md at main · nextcloud/all-in-one · GitHub
Which, of course, you can do and then configure that Caddy server as specified in the above wiki post to have TLS between the Caddy servers.
  1. For Backend Caddy, can this Caddy be run as a Reverse Proxy again to direct to Service A (e.g. Nextcloud AIO, File Browser, etc) running in the same container.
  2. If this service A offers two modes: HTTP and HTTPS, which one should be used?
  • a. If HTTP is used, would we get a connection mismatch error of “HTTP error in an HTTPS connection”?
  • b. If HTTPS is used, must we ensure that the service has its own certificate and put this certificate in the Backend Caddyfile (ie. “tls certificate.pem private.key”)?
  • c. If HTTPS is used and we don’t feel the need to check for certificates since the service is in the same container as the Backend Caddy, we can use the subdirective transport http { tls_insecure_skip_verify } in this case to keep the connection as HTTPS?
  • d. In the Nextcloud example above, the traffic from frontend to backend Caddy is HTTPS. What about the traffic from backend Caddy to Nextcloud in the same container? The example has Caddy run as a file server. Does that negate the need to have Nextcloud run as HTTP or HTTPS?
  1. When service A asks for an external URL for its listening address (127.0.0.1) and port (9000), is the external URL, in the above example, nextcloud.my.example.com or office.roadrunner?
Thanks.
Awesome wiki. @Rob789 .
I plan to have separate CA(step-ca) that manages internal network in similar topology but without Caddy for internal half.
In my case:
  1. A Caddy server would become Reverse Proxy(frontend) for example.com (my public domain) like @Matt suggested.
  2. A CA(like step-ca) runs independently and can provision certs for example.lan and has its root cert added as trusted in above Caddy server.
  3. Certbot(or any other ACME Client) in each internal service(backend) requests a certificate from the frontend.
Just want to confirm, if assumption is correct when I say that in comparison,
Point 2 above, step-ca is replaced by another Caddy server(as it internally uses step-ca).
Point 3 above, certbot replaced by Caddy servers.
Is my logic/analogy correct?
I think so!
