Unexpected 403 with Nextcloud dav
Hi there, im trying to get nextcloud to work served locally from /var/www/nextcloud, but i get a weird error.
2.3.0
Bare metal on debian 10, with repository added to apt.
Debian 10 vps
caddy start
as root
paste full file contents here
sub.host.tld {
  # Logfile
    output file /var/opt/caddy/caddy.log
    level info
  # Certificates from certbot
  tls /etc/letsencrypt/live/sub.host.tld/cert.pem /etc/letsencrypt/live/sub.host.tld/privkey.pem
  root * /var/www/nextcloud
  php_fastcgi unix//run/php/php8.0-fpm.sock {
    env front_controller_active true
    env PATH /bin
  # Custom http header
    Strict-Transport-Security "max-age=15768000;includeSubDomains;"
  # Redirect dav stuff
  # Deny certain files/folders
  @forbidden {
        path /.htaccess
        path /data/*
        path /config/*
        path /db_structure
        path /.xml
        path /README
        path /3rdparty/*
        path /lib/*
        path /templates/*
        path /occ
        path /console.php
  respond @forbidden 403
I serve nextcloud from /var/www/nextcloud, not the docker image of it.
Nextcloud gives attitude because it cant reach the dav backend. If i try to go to sub.host.tld/remote.php/dav i get an “Access denied” in the browser and log shows 403.
All files in www/nextcloud are chowned by www-data.
I dont’t understand the 403 by any means, there are no @forbidden rules for remote.php or anything. Most of nextcloud is served well.
My best guess is that i messed up the config somewhere and that caddy is trying to serve /remote.php/dav as a folder and searches for /remote.php/dav/index.php instead of passing /dav to remote.php. Could that be?
IP - - [29/Apr/2021:11:17:03 +0200] “GET /remote.php/dav HTTP/2.0” 403 15
Looking in similar configs and Caddyfiles in the wiki, none of them helpful for my case. Paste the default wiki nextcloud Caddyfile and try, but still not working. Messing with the @forbidden and try to serve files from root (which worked). But not remote.php/dav
Can anyone point me to the right direction?
Okay, i seem to have found a solution after a deep dive in this forum. I implemented a “temporary fix” from last april from this post since php_fastcgi routes everything through index.php, therefore preventing remote.php from being called with /dav. Will post config.
That should already work, the default behaviour of php_fastcgi does that already, since that topic was written:
Are you sure that Caddy can find the /remote.php file?
Turn on the debug mode global option, you should see additional logging about the results of the rewrites.
Also, try running with v2.4.0-beta.2, there may have been relevant fixes since (hard to keep track).
Full working config for me as of now:
example.com {
  import slog
  encode gzip zstd
  php_fastcgi unix//var/run/php/php8.0-fpm.sock {
    env PATH /bin
    # enable HSTS
        @forbidden {
                path    /.htaccess
                path    /data/*
                path    /config/*
                path    /db_structure
                path    /.xml
                path    /README
                path    /3rdparty/*
                path    /lib/*
                path    /templates/*
                path    /occ
                path    /console.php
        respond @forbidden "@forbidden"
        @phpFiles {
            path_regexp phpfile ^/(remote|public|cron|core/ajax/update|status|ocs/v1|ocs/v2)\.php
        rewrite @phpFiles {http.regexp.phpfile.0}
Will try 2.4 beta tomorrow and report
Thanks for your response. Just to make sure i tried again without the @phpFiles Matcher and rewrite and with 2.3 the remote.php/dav querie returns “Access denied.” If i put it back in the config, it works fine, no warning in dashboard and remote.php/dav returns
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client..
Will try with 2.4 tomorrow, if it does not require compiling.
So this morning i’m testing with
v2.4.0-beta.2 h1:DUaK4qtL3T0/gAm0fVVkHgcMN04r4zGpfPUZWHRR8QU=
from github. Maybe i’m doing something wrong but i still need the filematcher for remote.php and rewrite rule for nextcloud to work.
Also the nextcloud desktop app can’t connect/auth to my server. I didn’t test the desktop app yesterday, so propably it wouldn’t have yesterday either. The error the desktop app shows is
Error accessing token endpoint
Error transferring https://sub.domain.tld/index.php/login/v2 - server replied: Forbidden
Browser access is working fine i can browse nextcloud, edit settings etc. The urls are like sub.domain.com/login/ or sub.domain.com/apps/dashboard etc.
Again, current config is
sub.domain.com {
  # logging
  import slog
  encode gzip zstd
    env PATH /bin
    # enable HSTS
        @forbidden {
          path    /.htaccess
          path    /data/*
          path    /config/*
          path    /db_structure
          path    /.xml
          path    /README
          path    /3rdparty/*
          path    /lib/*
          path    /templates/*
          path    /occ
          path    /console.php
  # allow remote.php and others to be served by fpm
  @phpFiles {
I don’t know why the brwoser app is working, but the desktop app isn’t. And since you said it it shouldn’t need the matcher for remote.php, i don’t know why that isn’t working either. Sorry.
I turned on debug log and i think this is the request from the desktop app:
  "level": "debug",
  "ts": 1619855138.0240307,
  "logger": "http.handlers.rewrite",
  "msg": "rewrote request",
  "request": {
    "remote_addr": "IP:50318",
    "proto": "HTTP/1.1",
    "method": "POST",
    "host": "sub.domain.com",
    "uri": "/index.php/login/v2",
    "headers": {
      "User-Agent": [
        "Computername (Desktop Client - Windows)"
      "Cookie": [
        "oc_sessionPassphrase=o9Qzt2hIbQddQ99ATjdyJHy5mes%2FZsntrW%2FF1QgYC4El8H8Cp5ks7p0eD3GBUnvYQnA03CGym9oVh1Fa0lI%2BaZ0thGJttFSmKpUKy0auprURpCs6kP5LB0M67eF5fxGy; oc8nqiyqfk0m=7r82ag6urt4jha6dpbu7crskg3; __Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true"
      "Accept-Encoding": [
        "gzip, deflate"
      "Content-Length": [
        "0"
      "Accept": [
      "X-Request-Id": [
        "79921dc0-7e57-4207-a1d4-fdf2e2bf14a2"
      "Connection": [
        "Keep-Alive"
      "Accept-Language": [
        "de-DE,en,*"
    "tls": {
      "resumed": false,
      "version": 772,
      "cipher_suite": 4865,
      "proto": "",
      "proto_mutual": true,
      "server_name": "sub.domain.com"
  "method": "POST",
  "uri": "/index.php"
  "level": "debug",
  "ts": 1619855138.024199,
  "logger": "http.reverse_proxy.transport.fastcgi",
  "msg": "roundtrip",
  "request": {
    "method": "POST",
    "uri": "/index.php",
    "headers": {
      "X-Forwarded-Proto": [
        "https"
      "Content-Length": [
        "0"
      "Accept": [
      "X-Request-Id": [
        "de-DE,en,*"
      "User-Agent": [
      "Cookie": [
        "gzip, deflate"
      "X-Forwarded-For": [
        "IP"
    "tls": {
      "resumed": false,
      "version": 772,
      "proto": "",
  "dial": "/var/run/php/php8.0-fpm.sock",
  "env": {
    "AUTH_TYPE": "",
    "CONTENT_LENGTH": "0",
    "CONTENT_TYPE": "",
    "DOCUMENT_ROOT": "/var/www/nextcloud",
    "DOCUMENT_URI": "/index.php",
    "GATEWAY_INTERFACE": "CGI/1.1",
    "HTTPS": "on",
    "HTTP_ACCEPT": "*/*",
    "HTTP_ACCEPT_ENCODING": "gzip, deflate",
    "HTTP_ACCEPT_LANGUAGE": "de-DE,en,*",
    "HTTP_CONTENT_LENGTH": "0",
    "HTTP_COOKIE": "oc_sessionPassphrase=o9Qzt2hIbQddQ99ATjdyJHy5mes%2FZsntrW%2FF1QgYC4El8H8Cp5ks7p0eD3GBUnvYQnA03CGym9oVh1Fa0lI%2BaZ0thGJttFSmKpUKy0auprURpCs6kP5LB0M67eF5fxGy; oc8nqiyqfk0m=7r82ag6urt4jha6dpbu7crskg3; __Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true",
    "HTTP_HOST": "sub.domain.com",
    "HTTP_USER_AGENT": "Computername (Desktop Client - Windows)",
    "HTTP_X_FORWARDED_FOR": "IP",
    "HTTP_X_FORWARDED_PROTO": "https",
    "HTTP_X_REQUEST_ID": "79921dc0-7e57-4207-a1d4-fdf2e2bf14a2",
    "PATH": "/bin",
    "PATH_INFO": "/login/v2",
    "PATH_TRANSLATED": "/var/www/nextcloud/login/v2",
    "QUERY_STRING": "",
    "REMOTE_ADDR": "IP",
    "REMOTE_HOST": "IP",
    "REMOTE_IDENT": "",
    "REMOTE_PORT": "50318",
    "REMOTE_USER": "",
    "REQUEST_METHOD": "POST",
    "REQUEST_SCHEME": "https",
    "REQUEST_URI": "/index.php/login/v2",
    "SCRIPT_FILENAME": "/var/www/nextcloud/index.php",
    "SCRIPT_NAME": "/index.php",
    "SERVER_NAME": "sub.domain.com",
    "SERVER_PROTOCOL": "HTTP/1.1",
    "SERVER_SOFTWARE": "Caddy/v2.4.0-beta.2",
    "SSL_CIPHER": "TLS_AES_128_GCM_SHA256",
    "SSL_PROTOCOL": "TLSv1.3",
    "front_controller_active": "true"
  "level": "debug",
  "ts": 1619855138.0247207,
  "msg": "upstream roundtrip",
  "upstream": "unix//var/run/php/php8.0-fpm.sock",
  "request": {
    "method": "POST",
    "headers": {
        "https"
      "Content-Length": [
        "0"
      "Accept": [
      "X-Request-Id": [
        "de-DE,en,*"
      "User-Agent": [
      "Cookie": [
        "gzip, deflate"
        "IP"
    "tls": {
      "resumed": false,
      "version": 772,
      "proto": "",
  "duration": 0.000608025,
  "headers": {
    "Status": [
      "403 Forbidden"
    "Content-Type": [
      "text/html; charset=UTF-8"
  "status": 403
Here is the debug log for the /remote.php/dav request without the matcher and rewrite directive:
  "level": "debug",
  "ts": 1619856201.439723,
  "request": {
    "remote_addr": "IP:50349",
    "proto": "HTTP/2.0",
    "method": "GET",
    "uri": "/remote.php/dav",
    "headers": {
      "Te": [
        "trailers"
      "User-Agent": [
        "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0"
      "Dnt": [
        "1"
        "1"
      "Cookie": [
        "oc_sessionPassphrase=kO1aaj79QDEsiYQ%2BBqKrHbcc79MxZwGS4GRulm1%2Bxk7FnAMcLj8PH6Pagx5G%2BtJSfAcXiUnZHdsVTqltQ%2BxPem0EezWpZ0L%2BcS0BuaXfDfIM7qK5XBT1JPe4bhHRJUbJ; oc8nqiyqfk0m=41u5uqu22atm7iako806uvaav9; __Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; nc_username=tllggrs; nc_token=zfaRSuiAL8qCWZF%2FeN0NEbU8ce2E32fR; nc_session_id=41u5uqu22atm7iako806uvaav9"
      "Cache-Control": [
        "max-age=0"
      "Accept": [
        "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"
        "de,en-US;q=0.7,en;q=0.3"
        "gzip, deflate, br"
    "tls": {
      "resumed": false,
      "version": 772,
      "proto": "h2",
  "method": "GET",
  "uri": "/remote.php"
  "level": "debug",
  "ts": 1619856201.4399064,
  "msg": "roundtrip",
  "request": {
    "method": "GET",
    "uri": "/remote.php",
    "headers": {
      "User-Agent": [
      "Dnt": [
        "1"
        "1"
      "Te": [
        "trailers"
        "IP"
        "https"
      "Accept": [
        "gzip, deflate, br"
      "Cookie": [
      "Cache-Control": [
        "max-age=0"
    "tls": {
      "resumed": false,
      "version": 772,
      "proto": "h2",
  "env": {
    "AUTH_TYPE": "",
    "CONTENT_LENGTH": "",
    "CONTENT_TYPE": "",
    "DOCUMENT_URI": "/remote.php",
    "HTTPS": "on",
    "HTTP_ACCEPT": "text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8",
    "HTTP_ACCEPT_ENCODING": "gzip, deflate, br",
    "HTTP_ACCEPT_LANGUAGE": "de,en-US;q=0.7,en;q=0.3",
    "HTTP_CACHE_CONTROL": "max-age=0",
    "HTTP_COOKIE": "oc_sessionPassphrase=kO1aaj79QDEsiYQ%2BBqKrHbcc79MxZwGS4GRulm1%2Bxk7FnAMcLj8PH6Pagx5G%2BtJSfAcXiUnZHdsVTqltQ%2BxPem0EezWpZ0L%2BcS0BuaXfDfIM7qK5XBT1JPe4bhHRJUbJ; oc8nqiyqfk0m=41u5uqu22atm7iako806uvaav9; __Host-nc_sameSiteCookielax=true; __Host-nc_sameSiteCookiestrict=true; nc_username=tllggrs; nc_token=zfaRSuiAL8qCWZF%2FeN0NEbU8ce2E32fR; nc_session_id=41u5uqu22atm7iako806uvaav9",
    "HTTP_DNT": "1",
    "HTTP_TE": "trailers",
    "HTTP_UPGRADE_INSECURE_REQUESTS": "1",
    "HTTP_USER_AGENT": "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:88.0) Gecko/20100101 Firefox/88.0",
    "PATH": "/bin",
    "PATH_INFO": "/dav",
    "PATH_TRANSLATED": "/var/www/nextcloud/dav",
    "QUERY_STRING": "",
    "REMOTE_IDENT": "",
    "REMOTE_PORT": "50349",
    "REMOTE_USER": "",
    "REQUEST_METHOD": "GET",
    "REQUEST_URI": "/remote.php/dav",
    "SCRIPT_FILENAME": "/var/www/nextcloud/remote.php",
    "SCRIPT_NAME": "/remote.php",
    "SERVER_PROTOCOL": "HTTP/2.0",
  "level": "debug",
  "ts": 1619856201.4403615,
  "request": {
    "method": "GET",
    "headers": {
      "Accept": [
        "gzip, deflate, br"
      "Cookie": [
      "Cache-Control": [
        "max-age=0"
      "User-Agent": [
      "Dnt": [
        "1"
        "1"
      "Te": [
        "trailers"
        "IP"
        "https"
    "tls": {
      "resumed": false,
      "version": 772,
      "proto": "h2",
  "duration": 0.000545987,
  "headers": {
    "Status": [
      "403 Forbidden"
    "Content-Type": [
  "status": 403
I see
and think that could be an issue because path translated doesn’t exist in that way. But i don’t know what to fix because fpm seems to get a hiccup between calling root/remote.php and root/dav. There is no dav folder in nextcloud 21 root folder, i checked.
That’s actually correct according to the fastcgi spec, believe it or not. Most sites don’t use that env anyways.
The one difference in your config vs others I’ve seen is that you added env PATH /bin. Are you sure you need that? I think that’s messing things up.
I added env PATH /bin because nextcloud asked me to in its settings overview when i had not. And it’s actually in caddys example file. Though for v1, it was referenced in one of the wiki articles.
I deleted it from the config and restarted, but sadly still no access to /remote.php/dav. And again, nextcloud is warning me of the unset PATH variable.
Well, i think i found a reason for the problem. I use php8.0-fpm but didn’t read the nextcloud docs thoroughly. Actually recommended is 7.4 for Nc21. I found forum posts from users upgrading to 8.0, so i figured why not, since it worked for them. Today i did a downgrade to 7.4 and everything is working now (at least i think :wink:).
Thanks for your patience.
That makes sense. PHP 8 changed quite a lot of things that are tricky to maintain backwards compatibility with, so it’s quite possible that some trouble exists there.
