# caddy version
Fedora CoreOS, systemd, podman
podman-compose up
version: '3.7'
image: caddy
- "****:80"
- ${PWD}/Caddyfile:/etc/caddy/Caddyfile:ro,Z
- caddy_data:/data
- caddy_config:/config
- nc_data:/var/www/html
- caddynet
depends_on:
- nc
healthcheck:
test: ["CMD", "curl", "-f", "http://localhost/status.php"]
interval: 1m30s
timeout: 10s
retries: 3
start_period: 40s
labels:
- io.containers.autoupdate=registry
nc:
image: nextcloud:22-fpm
volumes: &nextcloud_volumes
- caddynet
expose:
- 9000
# [… more nextcloud stuff …]
nc_data:
caddy_data:
caddy_config:
caddynet:
http://:80 {
root * /var/www/html
php_fastcgi nc:9000 {
env front_controller_active true # Remove index.php form url
# enable HSTS
# Strict-Transport-Security max-age=31536000;
redir /.well-known/carddav /remote.php/dav permanent
redir /.well-known/caldav /remote.php/dav permanent
@forbidden {
path /.htaccess
path /data/*
path /config/*
path /db_structure
path /.xml
path /README
path /3rdparty/*
path /lib/*
path /templates/*
path /occ
path /console.php
respond @forbidden 404
(It’s reverse-proxied, so the HTTP/80 is okay.)
As explained here both the old Caddy example file and many nginx configuration examples/suggestions such as the official nginx Nextcloud doc.
So how can these rewrites all be ported to the new Caddy syntax?
Important note: Note I’d like to avoid introducing security vulnerabilities by trying to fiddle something in there, whichcan then have bad side effects. The reason is Nextcloud itself had a vulnerability report suggesting to adjust the nginx configuration (CVE-2019-11043), which was some remote code execution vulnerability. It was an issue in php-fpm ultimately, but the workaround/mitigation suggested by Nextcloud were nginx config adjustments.
Just that to explain some background of why I’m a little “wary” here…
N/A
see above
already linked
