I installed Caddy as a Reverse Proxy and use Caddy as server for Wordpress as well (in a proxmox environment).
My Caddy file on the reverse proxy:
shiatsu.example.com {
reverse_proxy 192.168.178.211 {
My Caddy file on the Wordpress installation:
http://shiatsu.example.com {
root * /var/www/wordpress
php_fastcgi unix//run/php/php8.2-fpm.sock
@disallowed {
path /xmlrpc.php
path *.sql
path /wp-content/uploads/*.php
rewrite @disallowed '/index.php'
and I added the requested if ($_SERVER['HTTP_X_FORWARDED_PROTO'] == 'https') $_SERVER['HTTPS']='on'; into my Wordpress wp-config.php.
The output is however not following css styles, when I enable https://.
Must be an issue of port forwarding not working anymore, as Wordpress sends an 301 response.
v2.6.4
Caddy without https:// is working properly (also presenting the Wordpress content as expected).
Ubuntu 22.04 LTS on a Proxmox 7.3 Linux Container.
5. Links to relevant resources (i.e. what I investigated)
problems-setting-up-wordpress-with-caddy
no-css-being-loaded-on-backend
reverse-proxy-caddy-wordpress-ssl-docker
v2-reverse-proxy-transparent
