v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
As a reverse proxy and web server for a symfony app
Docker desktop in WSL 2
Dockerfile
ARG CADDY_VERSION=2
FROM caddy:${CADDY_VERSION}-builder-alpine AS symfony_caddy_builder
RUN xcaddy build \
--with github.com/dunglas/mercure \
--with github.com/dunglas/mercure/caddy \
--with github.com/dunglas/vulcain \
--with github.com/dunglas/vulcain/caddy
FROM caddy:${CADDY_VERSION} AS symfony_caddy
WORKDIR /srv/app
COPY --from=dunglas/mercure:v0.11 /srv/public /srv/mercure-assets/
COPY --from=symfony_caddy_builder /usr/bin/caddy /usr/bin/caddy
COPY --from=symfony_php /srv/app/public public/
COPY docker/caddy/Caddyfile /etc/caddy/Caddyfile
docker-compose.yml
build:
context: .
target: symfony_caddy
depends_on:
- php
SERVER_NAME: ${SERVER_NAME:-localhost}
MERCURE_PUBLISHER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeMe!}
MERCURE_SUBSCRIBER_JWT_KEY: ${CADDY_MERCURE_JWT_SECRET:-!ChangeMe!}
- php_socket:/var/run/php
- caddy_data:/data
- caddy_config:/config
# HTTP
- target: 80
published: ${HTTP_PORT:-80}
protocol: tcp
# HTTPS
- target: 443
published: ${HTTPS_PORT:-443}
protocol: tcp
# HTTP/3
- target: 443
published: ${HTTP3_PORT:-443}
protocol: udp
none
# Debug
{$DEBUG}
# HTTP/3 support
servers {
protocol {
experimental_http3
{$SERVER_NAME}:443 {
log
reverse_proxy {$SERVER_NAME}:80
{$SERVER_NAME}:80, caddy:80 {
log
route {
root * /srv/app/public
mercure {
# Transport to use (default to Bolt)
transport_url {$MERCURE_TRANSPORT_URL:bolt:///data/mercure.db}
# Publisher JWT key
publisher_jwt {env.MERCURE_PUBLISHER_JWT_KEY} {env.MERCURE_PUBLISHER_JWT_ALG}
# Subscriber JWT key
subscriber_jwt {env.MERCURE_SUBSCRIBER_JWT_KEY} {env.MERCURE_SUBSCRIBER_JWT_ALG}
# Allow anonymous subscribers (double-check that it's what you want)
anonymous
# Enable the subscription API (double-check that it's what you want)
subscriptions
# Extra directives
{$MERCURE_EXTRA_DIRECTIVES}
vulcain
push
php_fastcgi unix//var/run/php/php-fpm.sock
encode zstd gzip
Caddy send X-Forwarded-Proto with an http value to my symfony app.
The web server part of the Caddyfile don’t forward the proto of the reverse proxy section like nginx do.
{"level":"info","ts":1657098944.7389662,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"172.22.0.4","remote_port":"46952","proto":"HTTP/1.1","method":"GET","host":"localhost","uri":"/","headers":{"Sec-Fetch-User":["?1"],"Upgrade-Insecure-Requests":["1"],"X-Forwarded-For":["172.22.0.1"],"X-Forwarded-Proto":["https"],"Accept-Language":["fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7"],"Cache-Control":["max-age=0"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Dest":["document"],"Sec-Gpc":["1"],"X-Forwarded-Host":["localhost"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.5060.66 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Fetch-Mode":["navigate"]}},"user_id":"","duration":0.070867548,"size":58191,"status":200,"resp_headers":{"Date":["Wed, 06 Jul 2022 09:15:44 GMT"],"X-Debug-Token":["b39101"],"Content-Type":["text/html; charset=UTF-8"],"Server":["Caddy"],"Cache-Control":["no-cache, private"],"X-Debug-Token-Link":["http://localhost/_profiler/b39101"],"X-Robots-Tag":["noindex"],"Link":["<http://localhost/api/docs.jsonld>; rel=\"http://www.w3.org/ns/hydra/core#apiDocumentation\""],"X-Powered-By":["PHP/8.1.7"]}}
{"level":"info","ts":1657098944.7403917,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"172.22.0.1","remote_port":"33870","proto":"HTTP/2.0","method":"GET","host":"localhost","uri":"/","headers":{"Cache-Control":["max-age=0"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.5060.66 Safari/537.36"],"Accept-Encoding":["gzip, deflate, br"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Gpc":["1"],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Language":["fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"localhost"}},"user_id":"","duration":0.075352902,"size":58191,"status":200,"resp_headers":{"Alt-Svc":["h3=\":443\"; ma=2592000,h3-29=\":443\"; ma=2592000"],"Date":["Wed, 06 Jul 2022 09:15:44 GMT"],"Link":["<http://localhost/api/docs.jsonld>; rel=\"http://www.w3.org/ns/hydra/core#apiDocumentation\""],"X-Robots-Tag":["noindex"],"Cache-Control":["no-cache, private"],"Server":["Caddy","Caddy"],"X-Debug-Token-Link":["http://localhost/_profiler/b39101"],"X-Debug-Token":["b39101"],"Content-Type":["text/html; charset=UTF-8"],"X-Powered-By":["PHP/8.1.7"]}}
{"level":"error","ts":1657098945.2216153,"logger":"http.log.access","msg":"handled request","request":{"remote_ip":"172.22.0.1","remote_port":"46794","proto":"HTTP/1.1","method":"OPTIONS","host":"localhost","uri":"/_wdt/b39101","headers":{"Sec-Fetch-Mode":["cors"],"Sec-Fetch-Site":["cross-site"],"Connection":["keep-alive"],"Accept":["*/*"],"Access-Control-Request-Method":["GET"],"Access-Control-Request-Headers":["x-requested-with"],"Origin":["https://localhost"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/103.0.5060.66 Safari/537.36"],"Accept-Language":["fr-FR,fr;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Dest":["empty"],"Accept-Encoding":["gzip, deflate, br"]}},"user_id":"","duration":0.052704014,"size":36,"status":400,"resp_headers":{"Server":["Caddy"],"X-Debug-Token-Link":["http://localhost/_profiler/413d67"],"X-Powered-By":["PHP/8.1.7"],"Vary":["Origin"],"Access-Control-Allow-Methods":["GET, OPTIONS, POST, PUT, PATCH, DELETE"],"Access-Control-Allow-Origin":["https://localhost"],"X-Debug-Token":["413d67"],"Access-Control-Max-Age":["3600"],"Cache-Control":["no-cache, private"],"Content-Type":["text/html; charset=UTF-8"],"Access-Control-Allow-Headers":["content-type, authorization"],"Date":["Wed, 06 Jul 2022 09:15:45 GMT"],"Status":["400 Bad Request"],"X-Robots-Tag":["noindex"]}}
I already tried to force value with header_up in the reverse proxy and header in the web server.
