1. Output of caddy version:
v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
systemd
DigitalOcean droplet with Ubuntu 22.04
test.genuineandalusia.com {
root * /var/www/html
php_fastcgi unix//run/php/php8.1-fpm.sock
@disallowed {
path /xmlrpc.php
path *.sql
path /wp-content/uploads/*.php
rewrite @disallowed '/index.php'
I’m trying to get Caddy up and running with Wordpress but hit a dead end.
First my problem was that I had tls internal in my Caddy config, not realizing the generated certificates will not be trusted by browsers by default (if I understood correctly).
I removed it and now at least I can curl my server (test.genuineandalusia.com) but all I get back is a “500 Internal Server Error”.
Also, Chrome and Firefox still tell me the connection to the server is not secure, but maybe they’re caching the previous, not-trusted certificate?
Sep 25 11:14:06 genuine-andalusia systemd[1]: Starting Caddy...
Sep 25 11:14:06 genuine-andalusia caddy[2904]: caddy.HomeDir=/var/lib/caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Sep 25 11:14:06 genuine-andalusia caddy[2904]: caddy.Version=v2.6.1 h1:EDqo59TyYWhXQnfde93Mmv4FJfYe00dO60zMiEt+pzo=
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.GOOS=linux
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.GOARCH=amd64
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.Compiler=gc
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.NumCPU=1
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.GOMAXPROCS=1
Sep 25 11:14:06 genuine-andalusia caddy[2904]: runtime.Version=go1.19.1
Sep 25 11:14:06 genuine-andalusia caddy[2904]: os.Getwd=/
Sep 25 11:14:06 genuine-andalusia caddy[2904]: LANG=C.UTF-8
Sep 25 11:14:06 genuine-andalusia caddy[2904]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Sep 25 11:14:06 genuine-andalusia caddy[2904]: NOTIFY_SOCKET=/run/systemd/notify
Sep 25 11:14:06 genuine-andalusia caddy[2904]: HOME=/var/lib/caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: LOGNAME=caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: USER=caddy
Sep 25 11:14:06 genuine-andalusia caddy[2904]: INVOCATION_ID=7771137379274e938ce40d84ae21247c
Sep 25 11:14:06 genuine-andalusia caddy[2904]: JOURNAL_STREAM=8:31598
Sep 25 11:14:06 genuine-andalusia caddy[2904]: SYSTEMD_EXEC_PID=2904
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1511278,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"warn","ts":1664104446.1535056,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":12}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1555185,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1559248,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.156102,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.157724,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1580703,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/lucas-clemente/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"debug","ts":1664104446.1584394,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1586442,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"debug","ts":1664104446.1588974,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1591015,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1592672,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["test.genuineandalusia.com"]}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"debug","ts":1664104446.159922,"logger":"tls","msg":"loading managed certificate","domain":"test.genuineandalusia.com","expiration":1671874421,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"debug","ts":1664104446.1605139,"logger":"tls.cache","msg":"added certificate to cache","subjects":["test.genuineandalusia.com"],"expiration":1671874421,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"622fdcf9afa7461fb1c19375f66a18f9aaab9a04f34181ea9934b29de9739245","cache_size":1,"cache_capacity":10000}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"debug","ts":1664104446.1606967,"logger":"events","msg":"event","name":"cached_managed_cert","id":"972290b3-00c0-4cf7-977e-b3b62ecc0f42","origin":"tls","data":{"sans":["test.genuineandalusia.com"]}}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.161006,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 25 11:14:06 genuine-andalusia systemd[1]: Started Caddy.
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.164919,"msg":"serving initial configuration"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1677127,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002a7960"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1679797,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 25 11:14:06 genuine-andalusia caddy[2904]: {"level":"info","ts":1664104446.1688337,"logger":"tls","msg":"finished cleaning storage units"}
I thought maybe PHP is the problem, so I followed a blog post’s advice and changed the user, group, listen.user and listen.group values in the PHP config from www-data to caddy, also also ran chown caddy:caddy /var/www/html, but this didn’t change anything.
