V2: reverse-proxy transparent
v2.0.0-beta9 h1:oILdAOfunJ4ijBN9kOWjFIeH8EufBX/N1pC9HbnwjzU=
Please provide all of the relevant information and DO NOT REDACT anything except passwords/keys. Thank you!
OS, relevant versions, systemd? docker? etc.
CentOS 7 amd64
$ caddy start --config Caddyfile --adapter caddyfile
Not used
d. My complete Caddyfile:
unknwon.dev {
    reverse_proxy * localhost:4333 {
Please describe the issue thoroughly enough so that anyone can reproduce the exact behavior you’re seeing. Be as specific as possible.
In v1, the transparent subdirective would work, but I can’t find anything similar in v2 docs.
reload: adapting config using caddyfile: parsing caddyfile tokens for 'reverse_proxy': /etc/caddy/Caddyfile:23 - Error during parsing: unrecognized subdirective transparent
Read through GitHub - caddyserver/caddy: Fast and extensible multi-platform HTTP/1-2-3 web server with automatic HTTPS · GitHub.
Hi @Unknwon, the error Caddy has output:
This is because there is no transparent preset for v2’s reverse_proxy directive.
For any headers your upstream requires, you will need to add them manually with the header_up subdirective.
Edit: This thread is from early in Caddy 2’s beta cycle, before it was even released. Caddy 2’s default behavior is to pass all headers through to the backend without modification, including setting/augmenting the X-Forwarded-For header for you. Basically, in Caddy 2, “transparent” is the default mode of operation. You do not need to set the headers like you did in v1 unless your backend app has specific/unconventional requirements.
References:
Thanks!
The remote IP is basically all I want… :cry:
There might be one as yet undocumented. Once I find it, I’ll edit the post and let you know.
@Unknwon, could you try with {http.request.remote} and let me know if that works?
(see: caddy/replacer.go at 7ff02f37b6cbdf8e73a47d94604672ca2f1f1aa7 · caddyserver/caddy · GitHub)
SSHing to my server…
It works! Thank you :smiley:
Yeah, before we reach 2.0 stable I’ll be sure to go back and add more shorthand placeholders for the Caddyfile. Right now you have to use their full name for some of them.
Edit: To clarify, for anyone finding this later: there is no “transparent” preset in Caddy 2 because Caddy 2 passes the Host header thru by default already. It also adds X-Forwarded-For automatically. If you need any other headers set, you can do so with header_up.
Somewhat related question: can Caddy reverse proxy to the backend app using HTTP/2, or does it always convert to HTTP/1.1 like Nginx?
I’m asking having read this.
It can use HTTP/2, but HTTP/2 requires HTTPS, so make sure to enable HTTPS to your backends. In your HTTP transport, define at least: "tls": {} (or for the Caddyfile, use the tls subdirective in your HTTP transport.)
Moderator edit: This thread got a lot of hits but contains outdated information from very early in the beta cycle of Caddy v2. It has been removed here to avoid confusing searchers. Please refer to current documentation instead:
