How-To Guide: Caddy V2 & Cloudflare DNS-01 via Docker
This post outlines how I was able to get Caddy V2 & Cloudflare DNS ACME DNS-01 challenge working. It took a fair bit of doc review (the DNS-01 stuff for V2 is sparse at the moment), and some trial & error, so I hope it can help others!
Note that this process assumes (and my knowledge is limited to):
  1. You’re using Docker, and you know how to use it
  2. You use Cloudflare for DNS
  3. You wish to use DNS-01 ACME challenge via LetsEncrypt
Though in theory some of this can be re-purposed for other use-cases as needed.
Part 1: Docker Configuration
  • Option 1 (Easy, but less preferred):
    I built a quick Docker image with Caddy & the Cloudflare DNS module built in. Find it here on Docker Hub. Please note that you should NOT rely upon this image for anything important, in case I break it :slight_smile:
  • Option 2 (in case you’re a DIY-er, or in case I break Option 1 above):
    As Caddy has not yet bundled the DNS provider modules into the official Caddy docker image, you must build your own image with the module pre-loaded. The easiest way I found to do this is as follows:
    1. Create a new Dockerfile on GitHub with the content below. This builds the base caddy:latest image with the Cloudflare module added in:
      FROM caddy:builder AS builder
      RUN caddy-builder \
          github.com/caddy-dns/cloudflare
      FROM caddy:latest
    2. Deploy that image to Docker Hub via Docker’s documentation. Alternatively, Deploy to your own image repository solution.
    3. Deploy your newly-created container using the directions on the official Caddy docker image, with a slight modification for our new ACME integration. For example:
      docker run -it --name caddy \
        -p 80:80 \
        -p 443:443 \
        -v caddy_data:/data \
        -v caddy_config:/config \
        -v $PWD/Caddyfile:/etc/caddy/Caddyfile \
        -e CLOUDFLARE_EMAIL=me@example.com \
        -e CLOUDFLARE_API_TOKEN=12345 \
        -e ACME_AGREE=true \
        image/imageName
Part 2: Caddyfile
You should add the following to your Caddyfile as the tls directive. Note that I haven’t figured out why the using {env.CLOUDFLARE_EMAIL} for the email address didn’t work, so for now I’ve got it manually declared:
tls me@example.com {
That’s pretty much it! Please let me know if you have any questions related to this, and I’ll do my best to help out.
Thanks for posting!
Should we make this a wiki so that others can improve it over time?
This is a good post. I think any wiki article should also discuss the limitations of DNS-01 if users want to enable “orange-cloud” web-proxy protection in Cloudflare.
Thanks for the feedback! I think a wiki (maybe on the GitHub or General Docs?) around the various LetsEncrypt options would be good. This covers only one scenario, albeit a fairly popular one, from what I’ve seen.
Our wiki is here:
It’s just another category on the forums
