Using the caddy add-package command hangs indefinitely. I’ve tried with multiple different packages and they all hang the same way. (One of my tests has been sitting there for >30m, with no additional feedback about what’s going on.)
$ docker run --rm caddy:2 caddy add-package github.com/caddy-dns/cloudflare
{"level":"info","ts":1678247248.6178856,"msg":"this executable will be replaced","path":"/usr/bin/caddy"}
{"level":"info","ts":1678247248.618044,"msg":"requesting build","os":"linux","arch":"amd64","packages":["github.com/caddy-dns/cloudflare"]}
There is no further output, no errors, no indication that anything at all is happening.
$ docker run --rm caddy:2 caddy version
I’m using the docker image available at https://hub.docker.com/_/caddy.
Docker, running under WSL2 on Windows 11:
$ uname -a
Linux Box 5.15.90.1-microsoft-standard-WSL2 #1 SMP Fri Jan 27 02:56:13 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
Also reproduced on a DigitalOcean droplet running Ubuntu 22.04 LTS.
See above, but here it is again:
Not relevant. See above.
