Caddy add-package hangs indefinitely
This problem: Add-package hangs indefinitely
No errors show
v2.11.4 h1:XKxkMTgNSizEvKG6QHue6cAsFOteU2qA61w2tKkCWi0=
From the Caddy Ubuntu/Debian apt repo
Ubuntu 24.04 x86_64
systemd unit
stock file from deb package
N/A
Type here
You shouldn’t rely on that, we plan on getting rid of it anyway. See proposal: remove `{add,remove}-package` and `upgrade` commands from core · Issue #7010 · caddyserver/caddy · GitHub
You should build Caddy with xcaddy instead. See Build from source — Caddy Documentation
The upgrade command and the download page on the caddyserver.com website are dead too.
Edit: xcaddy seems easy enough to use and works flawlessly (so far). I am comfortable moving away from caddy upgrade.
Does it work better now? We just upgraded our build server thanks to @elee1766’s help.
Can xcaddy please be included in the main debian repo then so we don’t have to add a second repo just for this tool? Or include it in the main caddy deb.
