v2.5.1 h1:bAWwslD1jNeCzDa+jDCNwb8M3UJ2tPa8UZFFzPVmGKs=
I run Caddy using the official docker container, caddy - Official Image | Docker Hub, with vanilla settings. I run caddy (and other services) directly via docker run, no additional orchestration layer (no docker-compose etc).
docker run --name caddy \
--detach \
--publish 0.0.0.0:80:80 \
--publish 0.0.0.0:443:443 \
--restart always \
-v ${HERE}/Caddyfile:/etc/caddy/Caddyfile \
-v ${HERE}/.caddy/:/data \
--network cirrus-net \
caddy
My host machine is a baremetal workstation running Ubuntu Linux 22.04 with current docker, Docker version 20.10.12, build 20.10.12-0ubuntu4.
See above
see above
Actually my complete Caddyfile is here: servers/cirrus/Caddyfile at 9be448631cb166db8fb0a06ba6266075a74b99a7 · boettiger-lab/servers · GitHub
it’s a little long and really I don’t think very relevant to this question, as all the services configured there work 100% as expected.
I’m trying to see caddy’s metrics/use load, trying to follow the official docs at Monitoring Caddy with Prometheus metrics — Caddy Documentation. docker logs caddy works great to see the default logs (i.e errors), but I cannot access the metrics endpoint (either for basic metrics or prometheus). The official docs do not cover the dockerized case, they suggest trying something like:
curl http://localhost:2019/metrics
Of course this fails for my setup – caddy isn’t on port 2019 as you can see from my docker command, and caddy is behind the docker network abstraction layer so it’s not on localhost either.
I can run another container that is also attached to the above network, e.g. a vanilla ubuntu container, and then I think based on the usual docker network logic caddy would be visible under the container name, e.g. something like:
curl caddy:2019/metrics
but that errors with:
curl: (7) Failed to connect to caddy port 2019: Connection refused
(as expected I think since caddy isn’t running on port 2019, but on 80 and 443 as indicated in my docker command, right?). Omitting the port seems like it would be correct, but that returns silently:
root@981ba2b05c84:/# curl caddy/metrics
I’m probably missing something very obvious here, but just not sure where to start. I’m not getting any unexpected error, I just can’t figure out how to talk to the caddy service directly (i.e. ‘localhost:2019’ in the demos). I have no trouble with any of the services listed under full https domain names in my caddyfile.
none
Please see above
I’d like to do something similar to
Caddy V2 and prometheus metrics, but the case is not quite the same, as it appears in that configuration caddy is already on localhost:2019 in that example, and I just don’t know what to change that to in the case of docker.
