Caddy V2 and prometheus metrics
I run Caddy in docker with docker-compose with static configuration
Docker
CMD ["/usr/bin/caddy", "run", "--config", "/etc/Caddyfile"]
    experimental_http3
    admin 0.0.0.0:2019 {
    	metrics /metrics
As per docs I’m trying to scrape metrics but 404 is returned.
(running inside container)
/srv #  curl -v localhost:2019/metrics
*   Trying 127.0.0.1:2019...
* Connected to localhost (127.0.0.1) port 2019 (#0)
> GET /metrics HTTP/1.1
> Host: localhost:2019
> User-Agent: curl/7.69.1
< HTTP/1.1 404 Not Found
< X-Content-Type-Options: nosniff
< Date: Sun, 06 Dec 2020 10:39:17 GMT
< Content-Length: 19
404 page not found
{"level":"info","ts":1607251157.8994603,"logger":"admin.api","msg":"received request","method":"GET","host":"localhost:2019","uri":"/metrics","remote_addr":"127.0.0.1:44546","headers":{"Accept":["*/*"],"User-Agent":["curl/7.69.1"]}}
Reconfigure, tried to debug with curl and logs
Any help or suggestions will be highly appreciated
Thanks for supporting this great product
Apparently, configuration format of Caddyfile has changed again and after update to 2.2.1 server didn’t start because of the metrics is not valid parameter anymore.
I have removed it and viola, metrics became available at localhost:2019/metrics
So update to 2.2.1 resolved this issue.
Metrics was a feature introduced in v2.2, it did not exist in v2.1
FYI that global options syntax is not correct, the admin global options don’t take handler directives as arguments. Metrics are always-on and accessible from the admin API at /metrics. See the global options docs for the options available to admin:
There is a metrics directive, for site blocks, that allows you to make the metrics endpoint available outside of the admin API, on whatever server you want:
