Zerossl issuance error after upgrade to Caddy v2.8.0
Migrated Caddy from version 2.6.2 to 2.8.0. Facing issue in zerossl issuance.
Issues:
  • Zerossl issuance not working and throwing below error
{“level”:“error”,“ts”:1718622299.338324,“logger”:“tls.renew”,“msg”:“could not get certificate from issuer”,“identifier”:“test21.whizzygeeks.com”,“issuer”:“zerossl”,“error”:“creating certificate: POST https://api.zerossl.com/certificates?access_key=redacted: HTTP 200: API error 2836: csr_cn_is_invalid (details=map) (raw={"success":false,"error":{"code":2836,"type":"csr_cn_is_invalid"}} decode_error=json: unknown field "success")”}
{“level”:“debug”,“ts”:1718622303.069677,“logger”:“events”,“msg”:“event”,“name”:“cert_failed”,“id”:“1bbb8a36-12ba-456b-80ce-feaabcce42ba”,“origin”:“tls”,“data”:{“error”:{},“identifier”:“test21.whizzygeeks.com”,“issuers”:[“zerossl”,“acme-v02.api.letsencrypt.org-directory”],“remaining”:7822501232249134,“renewal”:true}}
  • All certificate are being reissued after upgrade from version 2.6.2 to 2.8.0
  • Same config is working perfectly in version 2.6.2
    Note: Ignore Letsencrypt error rate limit which are usually not visible when zerossl works fine
{"level":"debug","ts":1718622113.8828826,"logger":"tls.permission.http","msg":"asking permission endpoint","remote":"","domain":"test21.whizzygeeks.com","url":"http://domain-validator.whizzygeeks.com/px-validate?domain=test21.whizzygeeks.com"}
{"level":"debug","ts":1718622113.886623,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"localhost:6081","total_upstreams":1}
{"level":"debug","ts":1718622113.8871162,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:6081","duration":0.000416818,"request":{"remote_ip":"54.159.182.238","remote_port":"51364","client_ip":"54.159.182.238","proto":"HTTP/2.0","method":"GET","host":"test21.whizzygeeks.com","uri":"/","headers":{"X-Forwarded-For":["54.159.182.238:51364"],"X-Forwarded-Proto":["https"],"Access-Control-Allow-Origin":["{http.request.access_control_allow_origin}"],"X-Forwarded-Port":[""],"Origin":["{http.request.origin}"],"X-Real-Ip":["54.159.182.238:51364"],"User-Agent":["curl/7.81.0"],"Accept":["*/*"],"X-Forwarded-Host":["test21.whizzygeeks.com"],"Access-Control-Allow-Credentials":["{http.request.access_control_allow_credentials}"],"Access-Control-Max-Age":["{http.request.access_control_max_age}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"test21.whizzygeeks.com"}},"headers":{"X-Cache-Hits":["15"],"Mobile":[""],"Server":["nginx"],"X-Ratelimit-Limit":["300"],"X-Ua":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"],"Age":["1632"],"X-Varnish":["983044 3"],"Host":["test21.whizzygeeks.com"],"Via":["1.1 varnish (Varnish/6.0)"],"X-Cache":["HIT"],"Accept-Ranges":["bytes"],"Content-Type":["text/html; charset=UTF-8"],"X-Ratelimit-Remaining":["299"],"Strict-Transport-Security":["max-age=31536000; includeSubDomains"],"Connection":["keep-alive"],"Date":["Mon, 17 Jun 2024 10:34:41 GMT"],"Vary":["Accept-Encoding"],"X-Content-Type-Options":["nosniff"],"X-Device":["pc"]},"status":200}
{"level":"debug","ts":1718622113.9641237,"logger":"tls.permission.http","msg":"response from permission endpoint","remote":"","domain":"test21.whizzygeeks.com","url":"http://domain-validator.whizzygeeks.com/px-validate?domain=test21.whizzygeeks.com","status":200}
{"level":"info","ts":1718622113.9641638,"logger":"tls.on_demand","msg":"attempting certificate renewal","remote_ip":"54.159.182.238","remote_port":"51364","server_name":"test21.whizzygeeks.com","subjects":["test21.whizzygeeks.com"],"expiration":1726444800,"remaining":7822686.117271079,"revoked":false}
{"level":"info","ts":1718622113.9649742,"logger":"tls.renew","msg":"acquiring lock","identifier":"test21.whizzygeeks.com"}
{"level":"info","ts":1718622113.9651086,"logger":"tls.renew","msg":"lock acquired","identifier":"test21.whizzygeeks.com"}
{"level":"debug","ts":1718622113.9657342,"logger":"tls","msg":"loading managed certificate","domain":"test21.whizzygeeks.com","expiration":1726444800,"issuer_key":"zerossl","storage":"{\"address\":\"primary-redis.whizzygeeks.com:6379\",\"host\":\"primary-redis.whizzygeeks.com\",\"port\":\"6379\",\"db\":6,\"username\":\"\",\"password\":\"REDACTED\",\"timeout\":60,\"key_prefix\":\"caddytls\",\"value_prefix\":\"caddy-storage-redis\",\"aes_key\":\"\",\"tls_enabled\":false,\"tls_insecure\":true}"}
{"level":"info","ts":1718622113.9658303,"logger":"tls.renew","msg":"renewing certificate","identifier":"test21.whizzygeeks.com","remaining":7822686.034173003}
{"level":"debug","ts":1718622113.9658585,"logger":"events","msg":"event","name":"cert_obtaining","id":"e85c7397-ab55-447a-b0ca-40838f336071","origin":"tls","data":{"forced":false,"identifier":"test21.whizzygeeks.com","issuer":"zerossl","remaining":7822686034173003,"renewal":true}}
{"level":"info","ts":1718622113.9660556,"logger":"tls.issuance.zerossl","msg":"creating certificate","identifiers":["test21.whizzygeeks.com"]}
{"level":"error","ts":1718622114.3268423,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test21.whizzygeeks.com","issuer":"zerossl","error":"creating certificate: POST https://api.zerossl.com/certificates?access_key=redacted: HTTP 200: API error 2836: csr_cn_is_invalid (details=map[]) (raw={\"success\":false,\"error\":{\"code\":2836,\"type\":\"csr_cn_is_invalid\"}} decode_error=json: unknown field \"success\")"}
{"level":"info","ts":1718622114.3273354,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["test21.whizzygeeks.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"admin@admin.com"}
{"level":"info","ts":1718622114.3273542,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["test21.whizzygeeks.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"admin@admin.com"}
{"level":"info","ts":1718622114.3273652,"logger":"http","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1786967397","account_contact":["mailto:admin@admin.com"]}
{"level":"debug","ts":1718622114.327373,"logger":"http.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1786967397","identifiers":["test21.whizzygeeks.com"]}
{"level":"debug","ts":1718622114.4617774,"logger":"http.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Mon, 17 Jun 2024 11:01:54 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["I4RLVp83EI-PUBx-3Uv17NYgQc63TNVB10uO6mT1MjSqgK9h6Uk"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622114.605757,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Boulder-Requester":["1786967397"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["328"],"Content-Type":["application/problem+json"],"Date":["Mon, 17 Jun 2024 11:01:54 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/docs/rate-limits>;rel=\"help\""],"Replay-Nonce":["prJkcjKSg6yQ7QNvvYwEWec8Bnn2rNfjBpaj6wYSqBPvafWB2EE"],"Retry-After":["81171"],"Server":["nginx"]},"status_code":429}
{"level":"error","ts":1718622114.6058612,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test21.whizzygeeks.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: test21.whizzygeeks.com, retry after 2024-06-18T09:34:46Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/"}
{"level":"debug","ts":1718622114.6058903,"logger":"events","msg":"event","name":"cert_failed","id":"cdf17c54-f20d-454f-a45d-7c75289f82b2","origin":"tls","data":{"error":{},"identifier":"test21.whizzygeeks.com","issuers":["zerossl","acme-v02.api.letsencrypt.org-directory"],"remaining":7822686034173003,"renewal":true}}
{"level":"error","ts":1718622114.6059027,"logger":"tls.renew","msg":"will retry","error":"[test21.whizzygeeks.com] Renew: [test21.whizzygeeks.com] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: test21.whizzygeeks.com, retry after 2024-06-18T09:34:46Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/ (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":0.64077684,"max_duration":2592000}
{"level":"debug","ts":1718622118.4776285,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:1636: EOF"}
{"level":"debug","ts":1718622118.8286824,"logger":"events","msg":"event","name":"tls_get_certificate","id":"76f8a9c7-6e57-40d8-85e4-69221830ffc1","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4867,4865,49196,49200,159,52393,52392,52394,49195,49199,158,49188,49192,107,49187,49191,103,49162,49172,57,49161,49171,51,157,156,61,60,53,47,255],"ServerName":"test21.whizzygeeks.com","SupportedCurves":[29,23,30,25,24,256,257,258,259,260],"SupportedPoints":"AAEC","SignatureSchemes":[1027,1283,1539,2055,2056,2057,2058,2059,2052,2053,2054,1025,1281,1537,771,769,770,1026,1282,1538],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[772,771],"RemoteAddr":{"IP":"54.159.182.238","Port":48061,"Zone":""},"LocalAddr":{"IP":"172.30.50.177","Port":443,"Zone":""}}}}
{"level":"debug","ts":1718622118.828721,"logger":"tls.handshake","msg":"choosing certificate","identifier":"test21.whizzygeeks.com","num_choices":2}
{"level":"debug","ts":1718622118.828735,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"test21.whizzygeeks.com","subjects":["test21.whizzygeeks.com"],"managed":true,"issuer_key":"zerossl","hash":"440fa1ce9b97d0d00c406b5aaebbae94d21511935aafd404be9a5af2b5d8af60"}
{"level":"debug","ts":1718622118.8287416,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"54.159.182.238","remote_port":"48061","subjects":["test21.whizzygeeks.com"],"managed":true,"expiration":1726444800,"hash":"440fa1ce9b97d0d00c406b5aaebbae94d21511935aafd404be9a5af2b5d8af60"}
{"level":"warn","ts":1718622118.8287919,"logger":"tls","msg":"certificate is in emergency renewal window; expiration imminent","subjects":["test21.whizzygeeks.com"],"expiration":1726444800,"ari_cert_id":"","next_ari_update":null,"renew_check_interval":4752000,"window_start":-6795364578.8713455,"window_end":-6795364578.8713455,"remaining":7822681.171208327}
{"level":"debug","ts":1718622118.829215,"logger":"tls.on_demand","msg":"certificate expires soon but is already being renewed; serving current certificate","remote_ip":"54.159.182.238","remote_port":"48061","subjects":["test21.whizzygeeks.com"],"remaining":7822681.170787119}
{"level":"debug","ts":1718622118.833376,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"localhost:6081","total_upstreams":1}
{"level":"debug","ts":1718622118.8337245,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"localhost:6081","duration":0.000258532,"request":{"remote_ip":"54.159.182.238","remote_port":"48061","client_ip":"54.159.182.238","proto":"HTTP/2.0","method":"GET","host":"test21.whizzygeeks.com","uri":"/","headers":{"X-Forwarded-Proto":["https"],"Access-Control-Allow-Credentials":["{http.request.access_control_allow_credentials}"],"Access-Control-Max-Age":["{http.request.access_control_max_age}"],"Origin":["{http.request.origin}"],"Access-Control-Allow-Origin":["{http.request.access_control_allow_origin}"],"User-Agent":["curl/7.81.0"],"Accept":["*/*"],"X-Forwarded-For":["54.159.182.238:48061"],"X-Forwarded-Host":["test21.whizzygeeks.com"],"X-Forwarded-Port":[""],"X-Real-Ip":["54.159.182.238:48061"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"test21.whizzygeeks.com"}},"headers":{"Host":["test21.whizzygeeks.com"],"X-Varnish":["983045 3"],"Age":["1637"],"Mobile":[""],"Accept-Ranges":["bytes"],"Date":["Mon, 17 Jun 2024 10:34:41 GMT"],"X-Content-Type-Options":["nosniff"],"X-Ratelimit-Remaining":["299"],"Via":["1.1 varnish (Varnish/6.0)"],"X-Cache-Hits":["16"],"Content-Type":["text/html; charset=UTF-8"],"Vary":["Accept-Encoding"],"X-Ratelimit-Limit":["300"],"X-Cache":["HIT"],"Connection":["keep-alive"],"X-Device":["pc"],"Server":["nginx"],"Strict-Transport-Security":["max-age=31536000; includeSubDomains"],"X-Ua":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/126.0.0.0 Safari/537.36"]},"status":200}
{"level":"debug","ts":1718622128.4778833,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:36705: EOF"}
{"level":"debug","ts":1718622138.477863,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:35986: EOF"}
{"level":"debug","ts":1718622148.4777973,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:60890: EOF"}
{"level":"debug","ts":1718622158.4778786,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:2442: EOF"}
{"level":"debug","ts":1718622168.4777806,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:30897: EOF"}
{"level":"debug","ts":1718622174.607452,"logger":"tls","msg":"loading managed certificate","domain":"test21.whizzygeeks.com","expiration":1726444800,"issuer_key":"zerossl","storage":"{\"address\":\"primary-redis.whizzygeeks.com:6379\",\"host\":\"primary-redis.whizzygeeks.com\",\"port\":\"6379\",\"db\":6,\"username\":\"\",\"password\":\"REDACTED\",\"timeout\":60,\"key_prefix\":\"caddytls\",\"value_prefix\":\"caddy-storage-redis\",\"aes_key\":\"\",\"tls_enabled\":false,\"tls_insecure\":true}"}
{"level":"info","ts":1718622174.6075747,"logger":"tls.renew","msg":"renewing certificate","identifier":"test21.whizzygeeks.com","remaining":7822625.392429246}
{"level":"debug","ts":1718622174.607619,"logger":"events","msg":"event","name":"cert_obtaining","id":"f19a4fb7-2314-4c58-a5b7-9d48d9d9a544","origin":"tls","data":{"forced":false,"identifier":"test21.whizzygeeks.com","issuer":"zerossl","remaining":7822625392429246,"renewal":true}}
{"level":"info","ts":1718622174.60785,"logger":"tls.issuance.zerossl","msg":"creating certificate","identifiers":["test21.whizzygeeks.com"]}
{"level":"error","ts":1718622174.913276,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test21.whizzygeeks.com","issuer":"zerossl","error":"creating certificate: POST https://api.zerossl.com/certificates?access_key=redacted: HTTP 200: API error 2836: csr_cn_is_invalid (details=map[]) (raw={\"success\":false,\"error\":{\"code\":2836,\"type\":\"csr_cn_is_invalid\"}} decode_error=json: unknown field \"success\")"}
{"level":"info","ts":1718622174.9137535,"logger":"http","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/152387183","account_contact":["mailto:admin@admin.com"]}
{"level":"debug","ts":1718622174.9137719,"logger":"http.acme_client","msg":"creating order","account":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/152387183","identifiers":["test21.whizzygeeks.com"]}
{"level":"debug","ts":1718622175.0915434,"logger":"http.acme_client","msg":"http request","method":"HEAD","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Mon, 17 Jun 2024 11:02:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["dM8JUU3IqN2oqxlzPBLelXiwqwqFwF19SPqWrMah4dyXnFOGGQY"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622175.1850417,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Boulder-Requester":["152387183"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["359"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/152387183/17256668053"],"Replay-Nonce":["AJh-apMwZ4u3koOC-c3Nn0h59nZuvCpYxkGkDMnOirsPKGOOoZM"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":201}
{"level":"debug","ts":1718622175.2475388,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/12797115783","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Boulder-Requester":["152387183"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["786"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["dM8JUU3Iu6phD_Wx3-vSb_R-I1uXaT0i-2nZ6HJDKzD_fZsZruI"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622175.2476423,"logger":"http.acme_client","msg":"skipping challenge initiation because authorization is not pending","identifier":"test21.whizzygeeks.com","authz_status":"valid"}
{"level":"info","ts":1718622175.247649,"logger":"http.acme_client","msg":"authorization finalized","identifier":"test21.whizzygeeks.com","authz_status":"valid"}
{"level":"info","ts":1718622175.2476535,"logger":"http.acme_client","msg":"validations succeeded; finalizing order","order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/152387183/17256668053"}
{"level":"debug","ts":1718622175.3330567,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/finalize/152387183/17256668053","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Boulder-Requester":["152387183"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["364"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:55 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Location":["https://acme-staging-v02.api.letsencrypt.org/acme/order/152387183/17256668053"],"Replay-Nonce":["dM8JUU3Il_ioed2AbChSX-M-qPhhkJSUm9qsT_khlHHjjnN9hEY"],"Retry-After":["3"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622178.4007277,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/order/152387183/17256668053","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["471"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["AJh-apMw5ahTk40O11KVkgH4t7URXrbRCyR-l6F15p2yjMBIH4s"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622178.4658296,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["2998"],"Content-Type":["application/pem-certificate-chain"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e/1>;rel=\"alternate\""],"Replay-Nonce":["AJh-apMw0MF26ppQVwXL2nORnjnE-dea61EDYzBEHbk4aORed5E"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622178.4659343,"logger":"http.acme_client","msg":"getting renewal info","names":["test21.whizzygeeks.com"]}
{"level":"debug","ts":1718622178.4774861,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:59342: EOF"}
{"level":"debug","ts":1718622178.5352857,"logger":"http.acme_client","msg":"http request","method":"GET","url":"https://acme-staging-v02.api.letsencrypt.org/draft-ietf-acme-ari-03/renewalInfo/oXQaBm1Qt4YtSizBfrSNiElszRY.K15zeBa8NcBjBGxwctAR32oO","headers":{"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"info","ts":1718622178.535356,"logger":"http.acme_client","msg":"got renewal info","names":["test21.whizzygeeks.com"],"window_start":1723717374,"window_end":1723890174,"selected_time":1723720244,"recheck_after":1718643778.535352,"explanation_url":""}
{"level":"debug","ts":1718622178.603168,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e/1","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["2441"],"Content-Type":["application/pem-certificate-chain"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e/0>;rel=\"alternate\""],"Replay-Nonce":["AJh-apMwicJ0joDc4Oe40dzJPkkZf2x1Iwx3r0Cbr670CMP6AKQ"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622178.6032853,"logger":"http.acme_client","msg":"getting renewal info","names":["test21.whizzygeeks.com"]}
{"level":"debug","ts":1718622178.6664674,"logger":"http.acme_client","msg":"http request","method":"GET","url":"https://acme-staging-v02.api.letsencrypt.org/draft-ietf-acme-ari-03/renewalInfo/oXQaBm1Qt4YtSizBfrSNiElszRY.K15zeBa8NcBjBGxwctAR32oO","headers":{"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["101"],"Content-Type":["application/json"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-staging-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Retry-After":["21600"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"info","ts":1718622178.6665208,"logger":"http.acme_client","msg":"got renewal info","names":["test21.whizzygeeks.com"],"window_start":1723717374,"window_end":1723890174,"selected_time":1723724721,"recheck_after":1718643778.6665182,"explanation_url":""}
{"level":"info","ts":1718622178.6665382,"logger":"http.acme_client","msg":"successfully downloaded available certificate chains","count":2,"first_url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e"}
{"level":"debug","ts":1718622178.666544,"logger":"http","msg":"selected certificate chain","url":"https://acme-staging-v02.api.letsencrypt.org/acme/cert/2b5e737816bc35c063046c7072d011df6a0e"}
{"level":"info","ts":1718622178.666947,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["test21.whizzygeeks.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"admin@admin.com"}
{"level":"info","ts":1718622178.6669629,"logger":"http","msg":"done waiting on internal rate limiter","identifiers":["test21.whizzygeeks.com"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"admin@admin.com"}
{"level":"info","ts":1718622178.6669734,"logger":"http","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1786967397","account_contact":["mailto:admin@admin.com"]}
{"level":"debug","ts":1718622178.6669805,"logger":"http.acme_client","msg":"creating order","account":"https://acme-v02.api.letsencrypt.org/acme/acct/1786967397","identifiers":["test21.whizzygeeks.com"]}
{"level":"debug","ts":1718622178.7100153,"logger":"http.acme_client","msg":"http request","method":"HEAD","url":"https://acme-v02.api.letsencrypt.org/acme/new-nonce","headers":{"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Cache-Control":["public, max-age=0, no-cache"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\""],"Replay-Nonce":["prJkcjKSJBwQC_O7Wb8UOsKp5d0A4M3lf1SyJJzxh3nrS5d5GUw"],"Server":["nginx"],"Strict-Transport-Security":["max-age=604800"],"X-Frame-Options":["DENY"]},"status_code":200}
{"level":"debug","ts":1718622178.7661018,"logger":"http.acme_client","msg":"http request","method":"POST","url":"https://acme-v02.api.letsencrypt.org/acme/new-order","headers":{"Content-Type":["application/jose+json"],"User-Agent":["Caddy/2.8.0 CertMagic acmez (linux; arm64)"]},"response_headers":{"Boulder-Requester":["1786967397"],"Cache-Control":["public, max-age=0, no-cache"],"Content-Length":["328"],"Content-Type":["application/problem+json"],"Date":["Mon, 17 Jun 2024 11:02:58 GMT"],"Link":["<https://acme-v02.api.letsencrypt.org/directory>;rel=\"index\"","<https://letsencrypt.org/docs/rate-limits>;rel=\"help\""],"Replay-Nonce":["prJkcjKSzubxFw-nx7gbKdxPm0PnV1DvBiQnDNk0PGytwbK55gM"],"Retry-After":["81107"],"Server":["nginx"]},"status_code":429}
{"level":"error","ts":1718622178.7662132,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test21.whizzygeeks.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: test21.whizzygeeks.com, retry after 2024-06-18T09:34:46Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/"}
{"level":"debug","ts":1718622178.7662432,"logger":"events","msg":"event","name":"cert_failed","id":"836bec2a-9491-4b03-a6c7-be5583ecb96d","origin":"tls","data":{"error":{},"identifier":"test21.whizzygeeks.com","issuers":["zerossl","acme-v02.api.letsencrypt.org-directory"],"remaining":7822625392429246,"renewal":true}}
{"level":"error","ts":1718622178.766253,"logger":"tls.renew","msg":"will retry","error":"[test21.whizzygeeks.com] Renew: [test21.whizzygeeks.com] creating new order: attempt 1: https://acme-v02.api.letsencrypt.org/acme/new-order: HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: test21.whizzygeeks.com, retry after 2024-06-18T09:34:46Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/ (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":64.801127187,"max_duration":2592000}
{"level":"debug","ts":1718622188.4774888,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:18773: EOF"}
{"level":"debug","ts":1718622198.477621,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:53509: EOF"}
{"level":"debug","ts":1718622208.4777474,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:7492: EOF"}
{"level":"debug","ts":1718622218.477652,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:61529: EOF"}
{"level":"debug","ts":1718622228.4774976,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:33741: EOF"}
{"level":"debug","ts":1718622238.4773412,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:44118: EOF"}
{"level":"debug","ts":1718622240.5106258,"logger":"http.stdlib","msg":"http: TLS handshake error from 99.82.161.83:33280: EOF"}
{"level":"debug","ts":1718622248.4775677,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:59503: EOF"}
{"level":"debug","ts":1718622258.4776495,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:56593: EOF"}
{"level":"debug","ts":1718622268.4778032,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.30.0.109:61862: EOF"}
Caddy Version 2.8.0
Ubuntu 22.04.4 LTS on ARM AWS EC2 instance
systemctl start caddy
Type=notify
        order rate_limit before basicauth
        #cert_issuer  acme https://acme-v02.api.letsencrypt.org/directory
        cert_issuer zerossl XXXXXXXXXXXXXXXXXXXXXXXX
        # Use Let's Encrypt or ZeroSSL to sign certificates.
                output file /var/log/caddy/server.log {
                        roll_size 100mb
                        roll_keep 15
                        roll_keep_for 480h
        email admin@whizzygeeks.com
        storage redis {
                host "primary-redis.whizzygeeksview.com"
                port 6379
                address "primary-redis.whizzygeeksview.com:6379"
                username ""
                password "Klinsmen80"
                db 6
                key_prefix "caddytls"
                value_prefix "caddy-storage-redis"
                timeout 60
                tls_enabled "false"
                tls_insecure "true"
        on_demand_tls {
                ask http://domain-validator.whizzygeeks.com/px-validate
        renew_interval 55d
        #ocsp_interval 1d
*.whizzygeeks.com:80 {
        header / {
                -Server
        @post method POST PUT OPTIONS
        @get method GET
        reverse_proxy @post internal-PROD-whizzygeeks-THEME-INTERNAL-ALB-XXXXXXXX.us-east-1.elb.amazonaws.com:80 {
                method POST
                header_up X-Real-IP {http.request.remote}
                header_up X-Forwarded-For {http.request.remote}
                #header_up CloudFront-Is-Mobile-Viewer {http.request.header.cloudfront_is_mobile_viewer}
                #header_up CloudFront-Is-IOS-Viewer {http.request.header.cloudfront_is_ios_viewer}
                #header_up CloudFront-Is-Android-Viewer {http.request.header.cloudfront_is_android_viewer}
                #header_up CloudFront-Is-Desktop-Viewer {http.request.header.cloudfront_is_desktop_viewer}
                header_up Access-Control-Allow-Origin {http.request.access_control_allow_origin}
                header_up Access-Control-Allow-Credentials {http.request.access_control_allow_credentials}
                header_up Access-Control-Max-Age {http.request.access_control_max_age}
                header_up Origin {http.request.origin}
        reverse_proxy @post internal-PROD-whizzygeeks-THEME-INTERNAL-ALB-XXXXXXXXXXXX.us-east-1.elb.amazonaws.com:80 {
                method OPTIONS
                #header_up CloudFront-Is-Mobile-Viewer {http.request.cloudfront_is_mobile_viewer}
                #header_up CloudFront-Is-IOS-Viewer {http.request.cloudfront_is_ios_viewer}
                #header_up CloudFront-Is-Android-Viewer {http.request.cloudfront_is_android_viewer}
                #header_up CloudFront-Is-Desktop-Viewer {http.request.cloudfront_is_desktop_viewer}
                method PUT
        reverse_proxy @get http://localhost:6081 {
                method GET
http:// {
        redir https://{host}{uri} permanent
:443 {
        header / {
      -Server
                output file /var/log/caddy/wildcard_access.log {
                        roll_size 100mb
                        roll_keep 20
                        roll_keep_for 480h
        #tls zerossl https://acme-v02.api.letsencrypt.org/directory
                #issuer zerossl  # could alternatively use "issuer acme ..." with ZeroSSL directory endpoint
                #issuer acme # current default is LE; hard-code dir endpoint to force that
                on_demand
                #issuer zerossl acme
        @get method GET
                method POST
                method OPTIONS
                method PUT
                method GET
        rate_limit {
                zone dynamic_example {
                        key {remote_host}
                        events 600
                        window 1m
                        jitter 2.0
                        sweep_interval 1m
What kind of plan do you have with ZeroSSL? Seems that you might need to upgrade your plan if you want to keep using the API. Otherwise, their ACME endpoint is free.
Matt it’s a paid plan - Basic .
We never exceeded the limit till now for zerossl.
I believe the mentioned error is due to LE . once zerossl SSL issuance fails it switches to LE.
Oh, my bad, that error was actually from Let’s Encrypt. I got the wrong impression from your topic title. LE is rate limiting you.
This error, though, from ZeroSSL, is odd… I wish they would say what’s invalid about your domain name.
Are you actually on 2.8.0 instead of 2.8.4? Make sure to use the latest version in case there’s any relevant bug fixes. Then if it still happens, let us know.
Thanks , will try tomorrow and confirm back. I picked latest one from debian repo for arm after doing an apt update
@matt Seeing same set of errors after caddy v2.8.4 upgrade . I also tried different domains just to be sure . But i was able to generate zerossl certificate when i switch redis to some other database number this time ( didnt try it earlier ) . Issue is there are several thousand certificates present in production and i cannot switch or flush the current db. Not sure what has changed in config ( either at caddy’s or zerossl end )
{"level":"error","ts":1718687448.8552423,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test23.whizzygeeks.com","issuer":"zerossl","error":"creating certificate: POST https://api.zerossl.com/certificates?access_key=redacted: HTTP 200: API error 2836: csr_cn_is_invalid (details=map[]) (raw={\"success\":false,\"error\":{\"code\":2836,\"type\":\"csr_cn_is_invalid\"}} decode_error=json: unknown field \"success\")"}
{"level":"debug","ts":1718687455.7735543,"logger":"events","msg":"event","name":"cert_failed","id":"2f5df9ed-4ef0-41be-9634-5e1f59493dfd","origin":"tls","data":{"error":{},"identifier":"test22.whizzygeeks.com","issuers":["zerossl","acme-v02.api.letsencrypt.org-directory"],"remaining":7843769581198218,"renewal":true}}
{"level":"debug","ts":1718687458.2845871,"logger":"events","msg":"event","name":"cert_failed","id":"c8c3e630-01ad-4099-933b-3a524e9a6fac","origin":"tls","data":{"error":{},"identifier":"test23.whizzygeeks.com","issuers":["zerossl","acme-v02.api.letsencrypt.org-directory"],"remaining":7843751340722873,"renewal":true}}
{"level":"error","ts":1718687529.4483867,"logger":"tls.renew","msg":"could not get certificate from issuer","identifier":"test24.whizzygeeks.com","issuer":"zerossl","error":"creating certificate: POST https://api.zerossl.com/certificates?access_key=redacted: HTTP 200: API error 2836: csr_cn_is_invalid (details=map[]) (raw={\"success\":false,\"error\":{\"code\":2836,\"type\":\"csr_cn_is_invalid\"}} decode_error=json: unknown field \"success\")"}
Other major difference i am seeing after caddy upgrade is the format change in redis, not sure it is due to redis tls module or caddy . See below pic ( acme.zerossl.com-v2-dv90 has been replaced by zerossl ) . This seems to be the reason it is creating new certificate for every domain. Is there a way to override it ?
In 2.8, the ZeroSSL issuer now uses the ZeroSSL API with an API key (to align with expectations and to conform to ZeroSSL’s latest policy changes). So the “issuer key” for the ZeroSSL issuer is no longer an ACME endpoint, it is simply “zerossl” – hence the change of the change of path for the certificate resources.
I believe that is a red herring, since that change is expected and, I believe, unrelated.
csr_cn_is_invalid suggests that the CSR isn’t being accepted by the server – we don’t even write this to storage because it’s needed only momentarily.
Do you have a minimal reproducer config or instructions I could use to troubleshoot this? Otherwise I’ll probably have to ask you to follow various troubleshooting steps.
@matt i have a reproduction script but it will not work for you as most of the things are on internal network and includes varnish as well. I will modify the script and provide it to you. Give me a day or two for this.
Another issue i found out is redis tls for caddy storage module has been deprecated and author has moved to GitHub - pberkel/caddy-storage-redis. Can this be related ?
After installing caddy via debian repo on ubuntu 22.04 . I am using xcaddy to build redis-tls storage module and rate limit module using below
xcaddy build --with GitHub - caddyserver/transform-encoder: Log encoder module for custom log formats --with GitHub - gamalan/caddy-tlsredis: Redis Storage using for Caddy TLS Data --with GitHub - mholt/caddy-ratelimit: HTTP rate limiting module for Caddy 2
Thanks, does it really require varnish? I’d love to eliminate external dependencies/requirements to make it easier to test but also to eliminate external factors that might be the problem.
Seems unlikely, since we don’t use storage to generate or store CSRs.
Thanks for your help!
@matt varnish is not required . I have removed varnish from caddyfile and have made few changes removing any dependency on application . PFB commands which will invoke the script and copy the caddy file.
git clone https://github.com/whizzygeeks/caddy-issue-2.8.git
cd caddy-issue-2\.8
bash caddy-build-script.sh
cp Caddyfile /etc/caddy/
systemctl restart caddy
Not sure why csr output with hostname was not visible in debug logs. I tried to trace logs (including stacktrace) multiple times but could’nt figure out.Seems error is coming from zerossl but what input is being fed to zerossl might be worth to look into. Appreciate your kind help.
@matt were you able to spend time on above script ? One more thing i wanted to validate - does ask url output matters or caddy only checks for 200 status code ?
Sorry – I have had the tab open… with the holiday and such it’s been a bit busy but I’m catching up to it!
Only the status code matters.
