WSS TLS handshake error
WSS TLS Handshake problem for my subdomain.
The device trying to connect is using an OCPP protocol without any authentication, I get some connected but this one says TLS Handshake problem!
{"level":"debug","ts":1723118114.8205967,"logger":"http.stdlib","msg":"http: TLS handshake error from ip:54612: EOF"}
v2.8.4
directly in ubuntu
Ubuntu 22.04
# domain name.
    email me@email.com
    key_type rsa2048
	root * /usr/share/caddy
	# php_fastcgi localhost:9000
wss.myapp.com {
	@websockets {
	header Connection *Upgrade*
	header Connection *upgrade*
	header Upgrade websocket
	reverse_proxy @websockets 127.0.0.1:8010
    		output file /var/log/caddy/app-access.log {
        	roll_size 10mb
        	roll_keep 20
        	roll_keep_for 720h
Here is the entire log that I have:
Aug 09 07:02:50 systemd[1]: caddy.service: Deactivated successfully.
Aug 09 07:02:50 systemd[1]: Stopped Caddy.
Aug 09 07:02:50 systemd[1]: Starting Caddy...
Aug 09 07:02:50 caddy[3250641]: caddy.HomeDir=/var/lib/caddy
Aug 09 07:02:50 caddy[3250641]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Aug 09 07:02:50 caddy[3250641]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Aug 09 07:02:50 caddy[3250641]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Aug 09 07:02:50 caddy[3250641]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Aug 09 07:02:50 caddy[3250641]: runtime.GOOS=linux
Aug 09 07:02:50 caddy[3250641]: runtime.GOARCH=amd64
Aug 09 07:02:50 caddy[3250641]: runtime.Compiler=gc
Aug 09 07:02:50 caddy[3250641]: runtime.NumCPU=3
Aug 09 07:02:50 caddy[3250641]: runtime.GOMAXPROCS=3
Aug 09 07:02:50 caddy[3250641]: runtime.Version=go1.22.3
Aug 09 07:02:50 caddy[3250641]: os.Getwd=/
Aug 09 07:02:50 caddy[3250641]: LANG=en_US.UTF-8
Aug 09 07:02:50 caddy[3250641]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Aug 09 07:02:50 caddy[3250641]: NOTIFY_SOCKET=/run/systemd/notify
Aug 09 07:02:50 caddy[3250641]: HOME=/var/lib/caddy
Aug 09 07:02:50 caddy[3250641]: LOGNAME=caddy
Aug 09 07:02:50 caddy[3250641]: USER=caddy
Aug 09 07:02:50 caddy[3250641]: INVOCATION_ID=e397a7d480964d90bfda9cadab60a4b5
Aug 09 07:02:50 caddy[3250641]: JOURNAL_STREAM=8:223540212
Aug 09 07:02:50 caddy[3250641]: SYSTEMD_EXEC_PID=3250641
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6278996,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6297174,"msg":"adapted config to JSON","adapter":"caddyfile"}
Aug 09 07:02:50 caddy[3250641]: {"level":"warn","ts":1723186970.6297307,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":11}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6307454,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.630907,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6309319,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Aug 09 07:02:50 caddy[3250641]: {"level":"warn","ts":1723186970.6309392,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.6309674,"logger":"http.auto_https","msg":"adjusted config","tls":{"automation":{"policies":[{"key_type":"rsa2048"}]}},"http":{"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"127.0.0.1:8010"}]}],"match":[{"header":{"Connection":["*Upgrade*","*upgrade*"],"Upgrade":["websocket"]}}]}]}],"terminal":true}],"tls_connection_policies":[{}],"automatic_https":{},"logs":{"logger_names":{"wss.myapp.com":["log0"]}}},"srv1":{"listen":[":80"],"routes":[{},{"handle":[{"handler":"vars","root":"/usr/share/caddy"},{"handler":"file_server","hide":["/etc/caddy/Caddyfile"]}]},{}],"automatic_https":{"disable":true}}}}}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6313033,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00061a580"}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6318195,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.631938,"logger":"http","msg":"starting server loop","address":"[::]:443","tls":true,"http3":true}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6319509,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.6320364,"logger":"http","msg":"starting server loop","address":"[::]:80","tls":false,"http3":false}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6320448,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.632923,"logger":"tls","msg":"loading managed certificate","domain":"wss.myapp.com","expiration":1728203574,"issuer_key":"acme-v02.api.letsencrypt.org-directory","storage":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.633204,"logger":"tls.cache","msg":"added certificate to cache","subjects":["wss.myapp.com"],"expiration":1728203574,"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"f1f5063293d8acd1e163352381b0ae06020464223ac4cd2647cde1993231a475","cache_size":2,"cache_capacity":10000}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.633219,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"be9691a3-4c38-4ce3-a330-2f1c8d0977e0","try_again":1723273370.6332178,"try_again_in":86399.99999968}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6332784,"logger":"tls","msg":"finished cleaning storage units"}
Aug 09 07:02:50 caddy[3250641]: {"level":"debug","ts":1723186970.6332283,"logger":"events","msg":"event","name":"cached_managed_cert","id":"19cae5d7-ea57-444d-aa62-0bca455e226e","origin":"tls","data":{"sans":["wss.myapp.cm"]}}
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6366217,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Aug 09 07:02:50 systemd[1]: Started Caddy.
Aug 09 07:02:50 caddy[3250641]: {"level":"info","ts":1723186970.6383379,"msg":"serving initial configuration"}
Aug 09 07:03:17 caddy[3250641]: {"level":"debug","ts":1723186997.2410202,"logger":"http.stdlib","msg":"http: TLS handshake error from ip:55760: EOF"}
and also this:
//not working
Jul 24 15:44:12 [1629176]: {"level":"error","ts":1721835852.9529366,"logger":"http.log.error.log0","msg":"dial tcp 127.0.0.1:8010: connect: connection refused","request":{"remote_ip":"ip","remote_port":"50033","client_ip":"ip","proto":"HTTP/1.1","method":"GET","host":"wss.myapp.com:443","uri":"/ocpp/1234/567/st01","headers":{"Upgrade":["websocket"],"Connection":["Upgrade"],"Sec-Websocket-Key":["h1Pt7GEL7jXXwcktQjoixQ=="],"Sec-Websocket-Protocol":["ocpp1.6"],"Sec-Websocket-Version":["13"]},"tls":{"resumed":false,"version":771,"cipher_suite":49199,"proto":"","server_name":"wss.myapp.com"}},"duration":0.000743485,"status":502,"err_id":"8r2y9q8ig","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Jul 24 15:45:13 [1629176]: {"level":"error","ts":1721835913.2652106,"logger":"http.log.error.log0","msg":"dial tcp 127.0.0.1:8010: connect: connection refused","request":{"remote_ip":"ip","remote_port":"50034","client_ip":"ip","proto":"HTTP/1.1","method":"GET","host":"wss.myapp.com:443","uri":"/ocpp/1234/567/st01","headers":{"Sec-Websocket-Protocol":["ocpp1.6"],"Sec-Websocket-Version":["13"],"Upgrade":["websocket"],"Connection":["Upgrade"],"Sec-Websocket-Key":["5a6OBEw+CBWcr+h5bCvy7g=="]},"tls":{"resumed":false,"version":771,"cipher_suite":49199,"proto":"","server_name":"wss.myapp.com"}},"duration":0.000398294,"status":502,"err_id":"cvdw87ep5","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
Jul 24 15:46:13 [1629176]: {"level":"error","ts":1721835973.1385367,"logger":"http.log.error.log0","msg":"dial tcp 127.0.0.1:8010: connect: connection refused","request":{"remote_ip":"ip","remote_port":"50035","client_ip":"ip","proto":"HTTP/1.1","method":"GET","host":"wss.myapp.com:443","uri":"/ocpp/1234/567/st01","headers":{"Connection":["Upgrade"],"Sec-Websocket-Key":["05IE9e2Ry5dS7PbfJutGyg=="],"Sec-Websocket-Protocol":["ocpp1.6"],"Sec-Websocket-Version":["13"],"Upgrade":["websocket"]},"tls":{"resumed":false,"version":771,"cipher_suite":49199,"proto":"","server_name":"wss.myapp.com"}},"duration":0.000364427,"status":502,"err_id":"pir0twx9h","err_trace":"reverseproxy.statusError (reverseproxy.go:1269)"}
//working
Aug 09 07:06:51 [3250641]: {"level":"debug","ts":1723187211.7254717,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"127.0.0.1:8010","duration":0.001991361,"request":{"remote_ip":"ip","remote_port":"42565","client_ip":"ip","proto":"HTTP/1.1","method":"GET","host":"wss.myapp.com:443","uri":"/ocpp/1234/567","headers":{"Sec-Websocket-Key":["x3JJHMbDL1EzLkh9GBhXDw=="],"X-Forwarded-Proto":["https"],"Sec-Websocket-Version":["13"],"Connection":["Upgrade"],"Upgrade":["websocket"],"User-Agent":[""],"X-Forwarded-For":["ip"],"X-Forwarded-Host":["wss.myapp.com:443"],"Sec-Websocket-Protocol":["ocpp1.6"]},"tls":{"resumed":false,"version":771,"cipher_suite":49199,"proto":"","server_name":"wss.myapp.com"}},"headers":{"Upgrade":["websocket"],"Connection":["Upgrade"],"Sec-Websocket-Accept":["HSmrc0sMlYUkAGmm5OPpG2HaGWk="],"Sec-Websocket-Protocol":["ocpp1.6"],"Uwebsockets":["20"]},"status":101}
Aug 09 07:06:51 [3250641]: {"level":"debug","ts":1723187211.7255325,"logger":"http.handlers.reverse_proxy","msg":"upgrading connection","upstream":"127.0.0.1:8010","duration":0.001991361,"request":{"remote_ip":"ip","remote_port":"42565","client_ip":"ip","proto":"HTTP/1.1","method":"GET","host":"wss.myapp.com:443","uri":"/ocpp/1234/567","headers":{"Sec-Websocket-Key":["x3JJHMbDL1EzLkh9GBhXDw=="],"X-Forwarded-Proto":["https"],"Sec-Websocket-Version":["13"],"Connection":["Upgrade"],"Upgrade":["websocket"],"User-Agent":[""],"X-Forwarded-For":["ip"],"X-Forwarded-Host":["wss.myapp.com:443"],"Sec-Websocket-Protocol":["ocpp1.6"]},"tls":{"resumed":false,"version":771,"cipher_suite":49199,"proto":"","server_name":"wss.myapp.com"}}}
I don’t know what OCPP is. Is it not HTTP? Caddy’s standard distribution only includes an HTTP server, it can’t handle arbitrary TCP traffic. For that you would need GitHub - mholt/caddy-l4: Layer 4 (TCP/UDP) app for Caddy
You only need the websockets matcher if you’re trying to split up traffic (i.e. send websocket traffic to one upstream and the rest to another). If you’re not doing that, you can simplify it to just this (dropping the matcher):
reverse_proxy 127.0.0.1:8010
You should remove this from your config. Having a :80 site will mess with HTTP->HTTPS redirects. That’s just there to give you a welcome page when you first install Caddy, you’re not meant to keep it there afterwards.
Could you please clarify that? It doesn’t seem to mess with the implicit redirects from auto_https if that is what you meant?
Below is what I used to verify, everything is bundled into a single compose.yaml file you can copy/paste, then just run the CLI commands shown at the end :slight_smile:
# For the separate container to reference by name:
  default:
  reverse-proxy:
    image: caddy:2.8
    # Normally this would be `volumes`, but `configs` embeds config for a simple copy/paste `compose.yaml` example
    configs:
      - source: caddy-config
        target: /etc/caddy/Caddyfile
    # Support for requests from the Docker host like: `https://example.localhost`
    # Containers on this network will resolve these aliases to the IP of this container:
      default:
        aliases:
          - example.test
configs:
  caddy-config:
    content: |
        local_certs
        # Docker Compose ENV interpolation feature to toggle auto_https:
        ${AUTO_HTTPS:-}
        respond "Hello from port 80"
      # `auto_https disable_redirects` would need require this for HTTP + HTTPS access:
      #http://example.test, https://example.test {
      example.test, example.localhost {
        respond "Hello from {scheme}://{host}"
$ docker compose up --force-recreate
# Run a separate container on the same network to curl from and leverage container DNS
$ docker run --rm -it --network custom-network fedora
# HTTP => HTTPS redirect works:
$ curl -L --insecure http://example.test
Hello from https://example.test
# Caddy container also reachable via container_name:
$ curl -L --insecure http://caddy
Hello from port 80
# Repeat but this time with implicit redirects disabled:
$ AUTO_HTTPS='auto_https disable_redirects' docker compose up --force-recreate
# HTTP => HTTPS redirect disabled as expected:
Hello from port 80
# HTTPS still available directly as expected:
$ curl --insecure https://example.test
It’s for when a request is made to a domain that doesn’t appear in the config (e.g. foo.test), then the redirect to HTTPS would be overridden with that site block.
But let’s not get off topic here. That wasn’t the users question in this topic.
