Why is `:80` a problem for HTTP to HTTPS redirects?
In another thread, some advice was given about an :80 { ... } site block being bad due to how it affects HTTP => HTTPS redirects (from the default auto_https setting).
In seeking clarification on that, it was considered off-topic.. hence this new thread (my config + commands from that thread are repeated below).
The response I received after was: WSS TLS handshake error - #5 by francislavoie
I am not sure what is being said here…? What is the problem with a domain that you’ve not configured not being redirected to HTTPS?
Here is what happens if I omit that block and follow the redirect:
$ curl http://caddy -L --insecure -v
curl: (35) OpenSSL/3.2.1: error:0A000438:SSL routines::tlsv1 alert internal error
* Host caddy:80 was resolved.
* IPv6: (none)
* IPv4: 172.28.0.3
*   Trying 172.28.0.3:80...
* Connected to caddy (172.28.0.3) port 80
> GET / HTTP/1.1
> Host: caddy
> User-Agent: curl/8.6.0
< Connection: close
< Location: https://caddy/
< Server: Caddy
< Date: Wed, 14 Aug 2024 13:32:18 GMT
< Content-Length: 0
* Closing connection
* Issue another request to this URL: 'https://caddy/'
* Host caddy:443 was resolved.
* IPv6: (none)
* IPv4: 172.28.0.3
*   Trying 172.28.0.3:443...
* Connected to caddy (172.28.0.3) port 443
* OpenSSL/3.2.1: error:0A000438:SSL routines::tlsv1 alert internal error
That is the same if I were to have a https:// { ... } site block since no site address to match on for a cert.
If I have http://, https:// { ... } I can optionally reach HTTP without an implicit redirect, like I could http:// { ... } / :80 { ... } as shown below.
If this were to be an instance of Caddy bundled into an image like some might do with nginx/apache, it’s quite normal for that to just offer up port 80 / HTTP in favor of another reverse proxy that terminates TLS and routes to different containers.
The other use-case where you have explicit site addresses for other site blocks configured, we’ve clarified that as non-issue.
Main question
So why is it important to support HTTP => HTTPS redirects for site addresses that you don’t intend to have certificates for, nor respond to uniquely?
Could I please have an example / command that shows off the intended difference / benefit? I feel that I’m misunderstanding something or missing some context?
N/A
Docker Compose + WSL2
Windows 11 + WSL2 (Ubuntu) + Docker Desktop
Docker Engine 26.1.1
v2.27
Two runs with redirects enabled/disabled were used to see what havoc :80 would wreck (but it was still not evident):
$ docker compose up --force-recreate
# Run a separate container on the same network to curl from and leverage container DNS
$ docker run --rm -it --network custom-network fedora
# HTTP => HTTPS redirect works:
$ curl -L --insecure http://example.test
Hello from https://example.test
# Caddy container also reachable via container_name:
$ curl -L --insecure http://caddy
Hello from port 80
# Repeat but this time with implicit redirects disabled:
$ AUTO_HTTPS='auto_https disable_redirects' docker compose up --force-recreate
# HTTP => HTTPS redirect disabled as expected:
Hello from port 80
# HTTPS still available directly as expected:
$ curl --insecure https://example.test
# For the separate container to reference by name:
  default:
  reverse-proxy:
    image: caddy:2.8
    # Normally this would be `volumes`, but `configs` embeds config for a simple copy/paste `compose.yaml` example
    configs:
      - source: caddy-config
        target: /etc/caddy/Caddyfile
    # Support for requests from the Docker host like: `https://example.localhost`
    # Containers on this network will resolve these aliases to the IP of this container:
      default:
        aliases:
          - example.test
configs:
  caddy-config:
    content: |
      local_certs
      # Docker Compose ENV interpolation feature to toggle auto_https:
      ${AUTO_HTTPS:-}
      respond "Hello from port 80"
    # `auto_https disable_redirects` would need require this for HTTP + HTTPS access:
    #http://example.test, https://example.test {
    example.test, example.localhost {
      respond "Hello from {scheme}://{host}"
This is provided above embedded in the compose.yaml for easy reproduction. But here it is separately (comments stripped):
  local_certs
Yeah my point was that for unknown domains, having the :80 site will cover the default HTTP->HTTPS redirects. Remove the :80 and you’ll see that this would do a redirect from http://caddy/ to https://caddy/ (even if this would result in a failed TLS handshake).
Either way, the point of my comment on the other thread was to say “clean up your config so you don’t have stuff that’s useless for you long-term”, there’s no reason to keep the welcome page after you’ve seen it the first time.
Right, that’s what I thought was the case.
I was concerned when you warned of it messing with HTTP => HTTPS redirects somehow meant it’d affect valid site-blocks HTTPS configuration too.
Ah ok, since that followed directly after advice about :80 messing with redirects, it threw me off a bit :sweat_smile:
Thanks for clearing up the confusion! :slight_smile:
