Hey @francislavoie Iāve done a completely fresh install of WordPress and still having this issue.
Iāve included the Caddyfile and wp-config.php below. Iāve also checked the database to confirm there arenāt any strings including index.php. The only one I could see was the permalink_structure key in the wp_options table, set to /index.php/%postname%/ but this is the same as in my previous screenshot, I canāt change this value via the WP dashboard.
I am using wp core download to fetch the WordPress files, then wp config create to generate the wp-config.php file. I have also tried creating the config file via the WordPress UI, but the result is the same.
Caddyfile
example.localhost {
root * /home/james/Development/example.com
php_fastcgi unix//var/run/php/php8.1-fpm.sock
wp-config.php
<?php
* The base configuration for WordPress
* The wp-config.php creation script uses this file during the installation.
* You don't have to use the web site, you can copy this file to "wp-config.php"
* and fill in the values.
* This file contains the following configurations:
* * Database settings
* * Secret keys
* * Database table prefix
* * ABSPATH
* @link https://wordpress.org/support/article/editing-wp-config-php/
* @package WordPress
// ** Database settings - You can get this info from your web host ** //
/** The name of the database for WordPress */
define( 'DB_NAME', 'example' );
/** Database username */
define( 'DB_USER', 'root' );
/** Database password */
define( 'DB_PASSWORD', 'password' );
/** Database hostname */
define( 'DB_HOST', 'localhost' );
/** Database charset to use in creating database tables. */
define( 'DB_CHARSET', 'utf8mb4' );
/** The database collate type. Don't change this if in doubt. */
define( 'DB_COLLATE', '' );
* Authentication unique keys and salts.
* Change these to different unique phrases! You can generate these using
* the {@link https://api.wordpress.org/secret-key/1.1/salt/ WordPress.org secret-key service}.
* You can change these at any point in time to invalidate all existing cookies.
* This will force all users to have to log in again.
* @since 2.6.0
define( 'AUTH_KEY', ' Y~Wy[3HlHbH;FytH.aa2}Y<cu>++jwk0I:x}R/oMe!UP$`X rq4h^gfhIbFZphx' );
define( 'SECURE_AUTH_KEY', 'SV1Yp#4]/1=y&%PG<cdU}YUst^xccaYT2>+@xl5tC=v)<pn(Si zd4L*L/<mE|JF' );
define( 'LOGGED_IN_KEY', 'm28y.<UH~KfDNhLd$k2lJ,wL_:ZwMIZeY`_6Ym$<A2^lmOF8dVf4(g{13+p;{=U7' );
define( 'NONCE_KEY', 'j?!><8Mv9!gWgq@|lsrli8L_}G@AjLe.G~RZ@Ha!,0A~*@}<*JCE-@VZT6bcIrWk' );
define( 'AUTH_SALT', 'Z=Z$T8}VV;WMx 5NhHdYsfR`9?7gQP|rOd[-|bfL<TgIei+ptwCs/YKz23 @ ,di' );
define( 'SECURE_AUTH_SALT', 'c~I:LJQ393xSs%(~Hd@2Tm2G9Q93iGj&zA4ZIg<m+>Iv08f+/Ous<`MI{z*T+qAU' );
define( 'LOGGED_IN_SALT', 'qV9i6n=<Fv2BjLh~F|FL36?.Z_ harH/zx1J>Zlem~Q/j9], s,f#]g[P03McF~4' );
define( 'NONCE_SALT', 'v}URPPas<[M*8Y[M&@YlF8nz5<W8[=-gB(yG~*1o~H+r<7l~Yd<Lsx;7Q> ^Oi`@' );
* WordPress database table prefix.
* You can have multiple installations in one database if you give each
* a unique prefix. Only numbers, letters, and underscores please!
$table_prefix = 'wp_';
* For developers: WordPress debugging mode.
* Change this to true to enable the display of notices during development.
* It is strongly recommended that plugin and theme developers use WP_DEBUG
* in their development environments.
* For information on other constants that can be used for debugging,
* visit the documentation.
* @link https://wordpress.org/support/article/debugging-in-wordpress/
define( 'WP_DEBUG', false );
/* Add any custom values between this line and the "stop editing" line. */
/* That's all, stop editing! Happy publishing. */
/** Absolute path to the WordPress directory. */
if ( ! defined( 'ABSPATH' ) ) {
define( 'ABSPATH', __DIR__ . '/' );
/** Sets up WordPress vars and included files. */
require_once ABSPATH . 'wp-settings.php';
