Wildcard Subdomain Reverse Proxy
1. Caddy version:
2.6.4
Installed using Homebrew: brew install caddy
MacOS
*.localhost {
    log
    reverse_proxy localhost:3000/{labels.2}
I’m attempting to use a wildcard subdomain which reverse proxies to another domain with the subdomain value being appended to the path. For example: about.localhost → localhost:3000/about
However, Caddy returns the following error: invalid dial address localhost:3000/: missing port in address
cURL output
curl -Lkv https://about.localhost
*   Trying 127.0.0.1:443...
* Connected to about.localhost (127.0.0.1) port 443 (#0)
* ALPN: offers h2
* ALPN: offers http/1.1
* (304) (IN), TLS handshake, Server hello (2):
* (304) (IN), TLS handshake, Unknown (8):
* (304) (IN), TLS handshake, Certificate (11):
* (304) (IN), TLS handshake, CERT verify (15):
* (304) (IN), TLS handshake, Finished (20):
* (304) (OUT), TLS handshake, Finished (20):
* SSL connection using TLSv1.3 / AEAD-CHACHA20-POLY1305-SHA256
* ALPN: server accepted h2
*  subject: [NONE]
*  start date: Feb 15 12:09:08 2023 GMT
*  expire date: Feb 16 00:09:08 2023 GMT
*  issuer: CN=Caddy Local Authority - ECC Intermediate
* h2h3 [:method: GET]
* h2h3 [:path: /]
* h2h3 [:scheme: https]
* h2h3 [:authority: about.localhost]
* h2h3 [user-agent: curl/7.85.0]
* h2h3 [accept: */*]
* Using Stream ID: 1 (easy handle 0x126014800)
> GET / HTTP/2
> Host: about.localhost
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Wed, 15 Feb 2023 13:17:10 GMT
* Connection #0 to host about.localhost left intact
Pretty printed the JSON for readability
http.log.error  making dial info: upstream localhost:3000/{http.request.host.labels.2}: invalid dial address localhost:3000/: missing port in address
  "request": {
    "remote_ip": "127.0.0.1",
    "remote_port": "49293",
    "proto": "HTTP/2.0",
    "method": "GET",
    "host": "about.localhost",
    "uri": "/",
    "headers": {
      "User-Agent": ["curl/7.85.0"],
      "Accept": ["*/*"]
    "tls": {
      "resumed": false,
      "version": 772,
      "cipher_suite": 4867,
      "proto": "h2",
      "server_name": "about.localhost"
  "duration": 0.000355125,
  "status": 502,
  "err_id": "8xu9c7kk6",
  "err_trace": "reverseproxy.statusError (reverseproxy.go:1299)"
I’ve attempted using the rewrite directive (don’t think this is what I need, but I’m not 100%) and using the answer posted in this other help article however neither have solved my issue.
Yes, it is what you need.
Try this:
*.localhost {
	log
	rewrite * /{labels.2}{uri}
This will rewrite https://foo.localhost/bar to the request path /foo/bar, then proxy it to localhost:3000.
