Get the wildcard subdomain to reverse proxy
Hello:
I am trying to build a CI with drone and I would like to do something like this:
*.my.domain {
reverse_proxy local-branch-$SUBDOMAIN:3000
So for example staging.my.domain should point to local-branch-staging:3000. Is there anyway to do that or should I build the caddyfile everytime something’s deployed?
You can use {labels.2} to get the 2-indexed segment of the domain, from the right.
Next time, please fill out the help topic template, as per the forum rules.
