dlamag
(Daniel LaVine)
June 16, 2020, 3:56pm
1
Alpine docker container
./caddy run --config Caddyfile
FROM alpine:3.9.4
ENV CADDYPATH=/etc/.caddy
WORKDIR /app
COPY . .
RUN apk add nss-tools
EXPOSE 80 443
CMD ["sh", "./run.sh"]
https://localhost:8070
tls internal
log
@cdn_resize {
path /cdn/photos*
not query ""
not query random=*
rewrite @cdn_resize /display/resize/0x0/{path}
# CDN Image Resizer
reverse_proxy /display/* picfit:7319
I’m trying to figure out how to match an empty query string so I can exclude them from the reverse_proxy directive in the above Caddyfile.
run: adapting config using caddyfile: Caddyfile:62 - Error during parsing: malformed query matcher token: ; must be in param=val format
I tried the configuration mentioned above. I apologize for not having tried more configurations on this but I wasn’t really sure what else to try in terms of matching an empty query string.
Maybe I have to do the inverse and exhaustively match every possible query instead of negating a match on an empty query?
Hmm, that’s interesting. This might be brittle, but maybe something like this?
not expression {uri}.contains('?')
matt
(Matt Holt)
June 16, 2020, 4:39pm
3
This is the first I’ve seen a request for this. It should be pretty easy to make not query "" work.
Edit: Yep
committed 04:41PM - 16 Jun 20 UTC
Caddyfile syntax: query ""
Or a nil matcher in the JSON should also match an em… pty query string.
See https://caddy.community/t/v2-match-empty-query/8708?u=matt
@dlamag I tried it with your Caddyfile and it worked for me. Can you please try that out to confirm? There will be build artifacts you can use momentarily.
dlamag
(Daniel LaVine)
June 16, 2020, 5:54pm
5
Thanks for the quick response @francislavoie and @matt !
I wasn’t sure what to do from the link provided by @francislavoie . Instead, I built off master (per these instructions: Build from source — Caddy Documentation ), now I’m getting this when I start up:
run: loading initial config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 0: loading handler modules: position 0: loading module 'subroute': provision http.handlers.subroute: setting up subroutes: route 5: loading matcher modules: module name 'not': provision http.matchers.not: loading matcher sets: module name 'query': module value cannot be null
git log confirms that I have pulled the commit mentioned above
matt
(Matt Holt)
June 16, 2020, 5:56pm
6
Oh. Hmm, mine adapted just fine but I guess I didn’t try it with --validate. Will look into that more…
You could download the caddy_v2_Linux_6db3615 link which contains a caddy binary.
But if you can build it from source, that works too
matt
(Matt Holt)
June 16, 2020, 6:03pm
8
Okay, pushed a better fix that I used --validate on this time. This one works and the tests pass. Give it a shot!
committed 06:02PM - 16 Jun 20 UTC
dlamag
(Daniel LaVine)
June 16, 2020, 8:40pm
9
Caddy is starting. I still have a problem but I’m pretty sure it’s on my end – I’ll check in here if I discover otherwise.
Francis, thanks for clarifying. My problem was that I wasn’t signed into github
Thanks for looking at this and taking care of it so swiftly!
Huh, TIL. Strange that you need to be logged in to download CI artifacts. Well okay then! They just grey out the links without saying why.
system
(system)
Closed
July 16, 2020, 4:05pm
11
