Port of NGINX $is_args variable
I am porting the example Nextcloud NGINX conf to Caddy. I have made it to about line 93, more or less. I am stuck on porting the NGINX variable $is_args.
From the $is_args documentation,
“?” if a request line has arguments, or an empty string otherwise
Is there a concise alternative to multiple matchers to port this block, assuming I am… mostly on the right track?
nginx.conf
# Rule borrowed from `.htaccess` to handle Microsoft DAV clients
location = / {
    if ( $http_user_agent ~ ^DavClnt ) {
        return 302 /remote.php/webdav/$is_args$args;
Caddyfile
(davclient) {
    path /
    header_regexp User-Agent ^DavClnt
@davclient {
    import davclient
@davclientwithquery {
    import davclient
    not query ""
handle @davclientwithquery {
    redir /remote.php/webdav/?{http.request.orig_uri.query} temporary
# Fall through match only no query?
handle @davclient {
    redir /remote.php/webdav/ temporary
See also V2: Match empty query? - #3 by matt
If there’s no query, there’s not really any harm in including ? in the URL.
Just do redir /remote.php/webdav/?{query}
Please don’t delete the help topic template. It’s important that you properly fill it out so that we get proper context for your question. It’s a forum rule.
