I use Caddy v1 to power my personal website, using Markdown templates. I store raw Markdown files in my docroot, each with front matter, and have my Caddyfile apply a template to them. This has been great, because I can just drop a new file into the directory and Caddy servers it all styled for me.
I used to use Hugo, as someone else encouraged in the links, below, but site generation time started creeping up to 10+ seconds; and it’s fundamentally inefficient to regenerate the whole site when I add one new file. Caddy v1 rendering Markdown on the fly has been great for me!
Ubuntu 20.04.1 LTS with Caddy (v1) running via systemd.
N/A
After=network-online.target
#Wants=network-online.target systemd-networkd-wait-online.service
Restart=on-failure
# I've had to twiddle these values a few times
# when systemd reports that Caddy is restarting too fast
StartLimitInterval=600
StartLimitBurst=125
User=www-data
Group=www-data
Environment=CADDYPATH=/etc/caddy/ssl
; Always set "-root" to something safe in case it gets forgotten in the Caddyfile.
ExecStart=/usr/local/bin/caddy -log stdout -agree=true -email=skippy@skippy.net -conf=/etc/caddy/Caddyfile -root=/var/tmp -pidfile /var/run/caddy/caddy.pid
ExecReload=/bin/kill -USR1 $MAINPID
; Use graceful shutdown with a reasonable timeout
KillMode=mixed
KillSignal=SIGQUIT
; Unmodified caddy is not expected to use more than that.
; Use a minimal /dev
PrivateDevices=true
ProtectHome=true
; … except /etc/caddy/ssl, because we want Letsencrypt-certificates there.
; This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/caddy/ssl
; They further retrict privileges that can be gained by caddy. Uncomment if you like.
NoNewPrivileges=true
https://skippy.net {
root /var/www/skippy.net/
gzip
tls skippy@skippy.net
ext .md
markdown / {
template home /templates/home.html
template archive /templates/archive.html
template /templates/single.html
log /var/log/caddy/skippy.log
errors /var/log/caddy/skippy.log
I’m looking to update my template files for use with the new v2 system. The old way made it easy to point to a Markdown file, and apply a template to that file.
Here are my home.html template, which serves index.md:
<!DOCTYPE html>
<html lang="en-us">
<head>
<style>
body{font:1.2em/1.62 sans-serif;margin:1em auto;max-width:40em;padding:0 .62em;}
h1,h2,h3{line-height:1.2;}
pre{background:#F8F8F8;overflow: auto;padding:0.5em;}
img{max-width:100%;}
img.u-photo{float:right;}
@media print{body{max-width:none}}
</style>
<title>skippy dot net</title>
<meta name="author" content="skippy">
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<link rel="author" href="https://skippy.net/">
<link rel="alternate" type="application/rss+xml" href="https://skippy.net/index.xml" title="skippy.net" />
<link rel="feed" type="application/rss+xml" href="https://skippy.net/index.xml" title="skippy.net" />
<link rel="license" href="http://creativecommons.org/licenses/by/4.0/" />
<link rel="pgpkey" href="https://skippy.net/files/skippy.pub">
<link rel="me" href="https://micro.blog/skippy" />
<link rel="authorization_endpoint" href="https://micro.blog/indieauth/auth" />
<link rel="token_endpoint" href="https://micro.blog/indieauth/token" />
<link rel="microsub" href="https://aperture.p3k.io/microsub/38">
</head>
<body>
<article class="h-entry">
<header class="h-card">
<img class="u-photo" src="https://skippy.net/images/scott-merrill-2017.jpg" alt="Scott Merrill" />
<h1 class="p-name"><a rel="me" class="u-url" href="https://skippy.net/">Scott Merrill</a></h1>
<h2><a class="u-email" href="mailto:skippy@skippy.net">skippy@skippy.net</a></h2>
<h3>GPG key <a class="u-key" href="https://pgp.mit.edu/pks/lookup?op=get&search=0xD8F2E57BED0F2C0A">0xD8F2E57BED0F2C0A</a></h3>
<p><span class="p-locality">Columbus</span>, <span class="p-region">Ohio</span>, <span class="p-country-name">USA</span></p>
<p><a href="https://skippy.net/about">about me</a> / <a href="https://skippy.net/posts">posts</a></p>
<p><a rel="me" href="https://www.flickr.com/people/skippy">flickr</a> / <a rel="me" href="https://github.com/skpy">github</a> / <a rel="me" href="https://keybase.io/skippy">keybase</a> / <a rel="me" href="https://www.linkedin.com/in/scottdmerrill">linkedin</a></p>
<hr />
</header>
{{ .Doc.body }}
<hr />
<p><a rel="me" href="/">home</a> / <a href="/about">about</a> / <a rel="me" href="https://www.flickr.com/people/skippy">flickr</a> / <a rel="me" href="https://github.com/skpy">github</a> / <a rel="me" href="https://keybase.io/skippy">keybase</a> / <a rel="me" href="https://www.linkedin.com/in/scottdmerrill">linkedin</a></p>
</body>
</html>
And here is the current contents of index.md:
template: home
## Recent posts
* 2019-11-08 12:27:18 - [Bash Blog](https://skippy.net/bash-blog)
* 2019-10-22 12:00 - [Quitter](https://skippy.net/quitter)
* 2019-02-02 12:00 - [How To Meeting](https://skippy.net/how-to-meeting)
* 2019-01-03 13:59 - [Hugo Data Files](https://skippy.net/hugo-data-files)
* 2018-11-08 10:11 - [London 2018 - Day Six](https://skippy.net/london-2018---day-six)
* 2018-11-08 10:11 - [London 2018 - Day Seven](https://skippy.net/london-2018---day-seven)
* 2018-11-08 09:11 - [London 2018 - Day Five](https://skippy.net/london-2018---day-five)
* 2018-10-24 04:10 - [London 2018 - Day Two](https://skippy.net/london-2018---day-two)
* 2018-10-24 05:10 - [London 2018 - Day Three](https://skippy.net/london-2018---day-three)
* 2018-10-24 04:10 - [London 2018 - Day One](https://skippy.net/london-2018---day-one)
## Recent notes
[¶](https://skippy.net/2020/05/10/1143 '2020-05-10 11:43:36')
Words to live by:
* wash your hands
* don’t drink bleach
[¶](https://skippy.net/2020/05/10/0908 '2020-05-10 09:07:53')
We’re doing Quarantine Bingo!
This is single.md, used for rendering a single post:
<!DOCTYPE html>
<html lang="en-us">
<head>
<style>
.separator{text-align:center;}
</style>
<title>skippy: {{ if .Doc.permalink -}}
{{- if eq (len (.Split .Doc.permalink "/")) 1 -}}{{ .Doc.title -}}
{{- else if .Doc.permalink }}{{ .Doc.permalink -}}
{{- end -}}
{{- else -}}
{{- .Doc.date -}}
{{- end -}}</title>
</head>
<body>
{{- if .Doc.permalink }}
{{ if eq (len (.Split .Doc.permalink "/")) 1 }}
<h1 class="p-name"><a class="u-url" href="/{{ .Doc.permalink }}" title="{{ .Doc.title }}">{{ .Doc.title }}</a></h1>
{{- end }}{{- end }}
<div class="e-content">
{{ .Doc.body }}
</div>
{{ if .Doc.permalink }}
<h4>published <time class="dt-published" datetime="{{ .Doc.date }}"><a href="/{{ .Doc.permalink }}">{{ .Doc.date }}</a></time><a class="p-author h-card" href="https://skippy.net/" title="skippy"></a></h4>
{{ end }}
</article>
<hr />
</body>
</html>
And here’s a part of what one entry looks like:
title: Quitter
permalink: quitter
date: 2019-10-22 12:00
I celebrated my twelfth anniversary of using Twitter by [deleting almost all of my tweets](https://twitter.com/smerrill/status/1186256887773388806). I left that one, plus my [Keybase verification](https://twitter.com/smerrill/status/446651749474902016) so that my Keybase proof wouldn’t break. I’m not sure I care about that, after all, so I may soon simply terminate my entire Twitter account.
To recap: my current workflow is that Caddy gets a request, it applies .md to that request via the ext directive, and reads the associated Markdown file into memory. Then it reads the template from the front matter of that Markdown and loads up the corresponding HTML template. It synthesizes that template and the Markdown contents and serves the result back to the requestor.
If a request is made for a non-existent file, Caddy properly serves an HTTP 404 error.
If I’m reading the v2 information (see links, below) correctly, this model is inverted in the new format: I point requests to a template, and that template is responsible for parsing the URL and fetching a Markdown file for inclusion.
I can live with re-arranging all of my content to use this new form, but it seems like this doesn’t handle error conditions very well. The template doesn’t seem to provide a way to respond with an HTTP 404 in the event that the to-be-included file doesn’t exist?
Indeed, the Caddy docs themselves simply terminate the connection without an HTTP code at all if you request an invalid URL:
❯ curl -v https://caddyserver.com/docs/foo
* Trying 165.227.20.207...
* TCP_NODELAY set
* Connected to caddyserver.com (165.227.20.207) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
* CAfile: /etc/ssl/cert.pem
CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Client hello (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-AES256-GCM-SHA384
* subject: CN=caddyserver.com
* start date: Sep 15 18:51:51 2020 GMT
* expire date: Dec 14 18:51:51 2020 GMT
* subjectAltName: host "caddyserver.com" matched cert's "caddyserver.com"
* issuer: C=US; O=Let's Encrypt; CN=Let's Encrypt Authority X3
* SSL certificate verify ok.
* Using Stream ID: 1 (easy handle 0x7fb664808600)
> GET /docs/foo HTTP/2
> Host: caddyserver.com
> User-Agent: curl/7.54.0
* Connection state changed (MAX_CONCURRENT_STREAMS updated)!
* HTTP/2 stream 1 was closed cleanly, but before getting all response header fields, teated as error
* Closing connection 0
* TLSv1.2 (OUT), TLS alert, Client hello (1):
curl: (92) HTTP/2 stream 1 was closed cleanly, but before getting all response header fields, teated as error
Is there an easy and sane way to provide 404 messages for errors when using templates to serve Markdown files?
Before I go whole-hog on rearranging all of my content and templates, might there be a lower-friction way to recreate my current setup with Caddy v2?
Finally, is Caddy v1 officially end-of-life? At what point should I expect Caddy v1 to stop working with Let’s Encrypt, for example? (I assume at some point in the future LE will update in some way that doesn’t get support added back to Caddy v1, which renders Caddy v1 pretty much dead in the water at the point.)
N/A
N/A
