systemd on Ubuntu Linux in production; though right now I’m running caddy run on a Mac laptop for testing.
Ubuntu Linux, eventually; OSX right now.
./caddy run
127.0.0.1:80 {
@missingFile not file {path} {path}.md
handle @missingFile {
respond @missingFile "Not found" 404
@notes {
path_regexp \/\d{4}\/?.*$
handle @notes {
templates
rewrite * /note.html
root * /Users/smerrill/skippy/content/
templates
rewrite /* /index.html
I don’t completely understand how named matches, routes, and handlers interact.
What I want is to serve different templates for different paths. Request for /foo should use the index.html template, and requests for /2020/10/30/foo should use the note.html template.
The old v1 Markdown system was simple and worked extremely well for my needs. I’m finding it hard to implement all the logic in my Caddyfile to make this work for v2.
2020/11/01 00:35:33.972 ERROR http.log.error template: /index.html:8:20: executing "/index.html" at <include $markdownFilePath>: error calling include: open /Users/smerrill/skippy/content/2020/10/30/foo.md: no such file or directory {"request": {"remote_addr": "127.0.0.1:64903", "proto": "HTTP/1.1", "method": "GET", "host": "127.0.0.1", "uri": "/2020/10/30/foo", "headers": {"Connection": ["keep-alive"], "Upgrade-Insecure-Requests": ["1"], "Dnt": ["1"], "Sec-Gpc": ["1"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"], "Accept-Encoding": ["gzip, deflate"], "Accept-Language": ["en-US,en;q=0.5"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:81.0) Gecko/20100101 Firefox/81.0"]}}, "duration": 0.00057551, "status": 500, "err_id": "9wxq8khf6", "err_trace": "templates.(*Templates).executeTemplate (templates.go:315)"}
2020/11/01 00:35:34.019 ERROR http.log.error template: /index.html:8:20: executing "/index.html" at <include $markdownFilePath>: error calling include: open /Users/smerrill/skippy/content/favicon.ico.md: no such file or directory {"request": {"remote_addr": "127.0.0.1:64904", "proto": "HTTP/1.1", "method": "GET", "host": "127.0.0.1", "uri": "/favicon.ico", "headers": {"User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:81.0) Gecko/20100101 Firefox/81.0"], "Dnt": ["1"], "Sec-Gpc": ["1"], "Accept": ["image/webp,*/*"], "Accept-Language": ["en-US,en;q=0.5"], "Accept-Encoding": ["gzip, deflate"], "Connection": ["keep-alive"], "Referer": ["http://127.0.0.1/2020/10/30/foo"]}}, "duration": 0.000710707, "status": 500, "err_id": "c4z2e8yzb", "err_trace": "templates.(*Templates).executeTemplate (templates.go:315)"}
As you can see from the Caddyfile, I’m trying to set up different templates for different paths, and also trying to properly handle 404 errors.
I have two major paths in my site: /YYYY/MM/DD/XYZ for short-form notes, and then long-form posts off the root. I would like different templates for each of these.
When I visit http://127.0.01/2020/10/30/foo, I expect to get a 404 error because there is no such file. Instead, Caddy is trying to use the /index.html template. Even if the 404 fails, I would expect the /note.html template to be used.
Here is my index.html template, which is a basic effort to output a Markdown file:
<html>
<body>
{{$pathParts := splitList "/" .OriginalReq.URL.Path}}
<br />
{{$markdownFilename := default "index" (slice $pathParts 1 | join "/")}}
{{ $markdownFilename }}
{{$markdownFilePath := printf "/%s.md" $markdownFilename}}
{{$markdownFile := (include $markdownFilePath | splitFrontMatter)}}
{{$title := default $markdownFilename $markdownFile.Meta.title}}
{{ $title }}
</body>
</html>
And here is note.html which is intended to be used for the request I’m trying, and also a minimal debug effort:
<html>
<head><title>note</title></head>
<body>
<br />
{{ $title }}
</body>
</html>
The error message I posted above indicates that index.html is being used for the request.
V2 Markdown, Templates, and HTTP error codes - my original post in my effort to move from Caddy v1 to v2.
