V2: is it possible to serve HTTP on a non-80 port with caddyfile?
Hi,
I wasn’t able to find a way to explicitly disable TLS for a specific port in V2’s Caddyfile. In V1, you could just do tls off but this no longer work in V2. Did I miss something or is it just unimplemented yet?
Thanks.
If you specify your site label like http://mysite.com:8080, it’ll serve HTTP on port 8080. Is that what you’re looking for?
Definitely, thanks. It wasn’t clear to me that you could specify the scheme in the site label for some reason.
A post was split to a new topic: Why does this proxy config result in a HTTPS redirect?
