2.0.0 docker builder with webdav plugin
Running using docker/docker-compose, from a Caddy builder image.
Debian 10, Docker 19.03.12, Docker-Compose 1.26.0
To build docker image: docker build --tag caddy:2.0.0-custom .
To run docker-compose: docker-compose up -d caddy
Dockerfile to build image:
FROM caddy:2.0.0-builder AS builder
RUN caddy-builder \
github.com/mholt/caddy-webdav
FROM caddy:2.0.0
docker-compose.yml:
version: '3.4'
# Caddy web server, doing reverse proxy
image: "caddy:2.0.0-custom"
container_name: "caddy"
- /srv/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- /srv/caddy/www:/usr/share/caddy:rw
- /srv/caddy/data:/data:rw
restart: always
order webdav last
# WebDAV
dav.rowland.pw {
root * /usr/share/caddy/webdav
output file /data/logs/caddy_dav.log
basicauth {
secureguy JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX
encode gzip zstd
Access-Control-Allow-Origin *
Access-Control-Allow-Credentials true
Access-Control-Allow-Methods "GET, HEAD, POST, PUT, OPTIONS, MOVE, DELETE, COPY, LOCK, UNLOCK, PROPFIND, MKCOL"
Access-Control-Allow-Headers "Authorization,DNT,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,X-Accept-Charset,X-Accept,origin,accept,if-match,destination,overwrite,X-CustomHeader"
Access-Control-Expose-Headers "ETag"
Access-Control-Max-Age 1728000
webdav
# KeeWeb/KeePass
kee.rowland.pw {
root * /usr/share/caddy/keeweb
file_server /*
output file /data/logs/caddy_kee.log
encode gzip zstd
I was using Caddy v1 for a long time, and as such I had moved my password manager to KeeWeb. This ran for a long time with not issues. Recently the drive died on my NUC, so I replaced it and I’m rebuilding from backup with Caddy v2. I posted before, listed below in Section 6, about BasicAuth issues and those got resolved. Now I’m trying to get 2x different sites to talk to each other. kee.domain.tld is KeeWeb, dav.domain.tld is the WebDAV.
In Firefox, when I try to connect to the WebDav from KeeWeb site, I see the error CORS Preflight Did Not Succeed using the Web Dev Tools/Network console.
From my caddy log for the webdav site:
"level":"error",
"ts":1594411512.1438713,
"logger":"http.log.access.log1",
"msg":"handled request",
"request":{
"method":"OPTIONS",
"uri":"/keepass/drowland.kdbx",
"proto":"HTTP/1.1",
"remote_addr":"192.168.20.1:59915",
"host":"dav.rowland.pw",
"headers":{
"Referer":[
"https://kee.rowland.pw/"
"Connection":[
"keep-alive"
"Pragma":[
"no-cache"
"User-Agent":[
"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:78.0) Gecko/20100101 Firefox/78.0"
"Accept":[
"Accept-Language":[
"en-US,en;q=0.5"
"Accept-Encoding":[
"gzip, deflate, br"
"Access-Control-Request-Method":[
"HEAD"
"Access-Control-Request-Headers":[
"authorization,cache-control"
"Origin":[
"https://kee.rowland.pw"
"Dnt":[
"1"
"Cache-Control":[
"no-cache"
"tls":{
"resumed":false,
"version":771,
"ciphersuite":49196,
"proto":"http/1.1",
"proto_mutual":true,
"server_name":"dav.rowland.pw"
"common_log":"192.168.20.1 - - [10/Jul/2020:20:05:12 +0000] \"OPTIONS /keepass/drowland.kdbx HTTP/1.1\" 401 0",
"duration":0.000087038,
"size":0,
"status":401,
"resp_headers":{
"Access-Control-Allow-Origin":[
"Access-Control-Expose-Headers":[
"ETag"
"Access-Control-Max-Age":[
"1728000"
"Access-Control-Allow-Credentials":[
"true"
"Access-Control-Allow-Headers":[
"Access-Control-Allow-Methods":[
"Www-Authenticate":[
"Basic realm=\"restricted\""
"Server":[
"Caddy"
If I use CyberDuck or Windows 10 Explorer, the WebDAV doesn’t have an issue authenticating and allowing transfers. So I don’t believe it’s a WebDAV plugin issue, I think I’m just missing a header or two.
I was missing a few headers from my v1 config in my v2 config of my previous post, so I’ve added them, but it’s still not connecting.
Original Post - [v2] BasicAuth not working with docker image or custom build
