2.0.0 docker builder with webdav plugin
Running using docker/docker-compose, from a Caddy builder image.
Debian 10, Docker 19.03.12, Docker-Compose 1.26.0
To build docker image: docker build --tag caddy:2.0.0-custom .
To run docker-compose: docker-compose up -d caddy
Dockerfile to build image:
FROM caddy:2.0.0-builder AS builder
RUN caddy-builder \
github.com/mholt/caddy-webdav
FROM caddy:2.0.0
docker-compose.yml:
version: '3.4'
# Caddy web server, doing reverse proxy
image: "caddy:2.0.0-custom"
container_name: "caddy"
- /srv/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
- /srv/caddy/www:/usr/share/caddy:rw
- /srv/caddy/data:/data:rw
restart: always
The basicauth password is hiccup, I copied it from the documentation for testing.
order webdav last
(global) {
encode gzip zstd
output file /data/logs/caddy_access.log
handle_errors /data/logs/caddy_errors.log
php_fastcgi phpfpm:9000
http://dav.homelab.zt {
import global
basicauth /* {
secureguy JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX
webdav / {
root /usr/share/caddy/webdav
Access-Control-Allow-Origin *
Access-Control-Allow-Credentials true
Access-Control-Allow-Methods GET, HEAD, POST, PUT, OPTIONS, MOVE, DELETE, COPY, LOCK, UNLOCK
Access-Control-Allow-Headers Authorization,DNT,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,X-Accept-Charset,X-Accept,origin,accept,if-match,destination,overwrite
Access-Control-Expose-Headers ETag
Access-Control-Max-Age 1728000
http://static.homelab.zt {
import global
root * /usr/share/caddy/static
file_server /* browse
basicauth /* {
I ran a docker builder to add the webdav plugin, and while doing testing with converting my v1 config to v2 I ran across the issue that basicauth isn’t working. Firefox and Chrome headers show Www-Authenticate: Basic realm="restricted", but I’m not getting any credentials request. If I take the basicauth directive out of the my static.homelab.zt or dav.homelab.zt, I get the file browser from static and XML output from dav. Also, if I change the order webdav last to order webdav first, then I get XML output from dav and still no basicauth request (which makes sense since I am running webdav directive before the basicauth).
Access.log when I tried to access http://dav.homelab.zt from Firefox
{"level":"info","ts":1593117167.841527,"logger":"http.log.access.log0",
"msg":"handled request","request":{"method":"GET","uri":"/","proto":"HTTP/1.1",
"remote_addr":"172.25.163.57:41254","host":"dav.homelab.zt",
"headers":{"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:77.0) Gecko/20100101 Firefox/77.0"],
"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8"],
"Accept-Language":["en-US,en;q=0.5"],"Accept-Encoding":["gzip, deflate"],
"Connection":["keep-alive"],"Upgrade-Insecure-Requests":["1"]}},
"common_log":"172.25.163.57 - - [25/Jun/2020:20:32:47 +0000] \"GET / HTTP/1.1\" 0 0",
"duration":0.000083627,"size":0,"status":0,"resp_headers":{"Access-Control-Expose-Headers":["ETag"],
"Access-Control-Max-Age":["1728000"],"LOCK,":["UNLOCK"],
"Www-Authenticate":["Basic realm=\"restricted\""],"Server":["Caddy"],
"Access-Control-Allow-Credentials":["true"],
"Access-Control-Allow-Headers":["Authorization,DNT,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,X-Accept-Charset,X-Accept,origin,accept,if-match,destination,overwrite"],
"Access-Control-Allow-Origin":["*"]}}
If I remove the basicauth directive, I get an XML response from my WebDAV site and a file browser from the Static File_Server site.
If I add basicauth directive, I just get a white blank page. The log above is from basicauth being added.
I changed my docker-compose to use the Docker Hub caddy:2.0.0 instead of my custom build, and I adjusted my Caddyfile to remove the webdav site and order directive. My static site still will not work with the basicauth directive.
