Using {host} as part of a log output filename
I have followed discussion Logging snippet using {host} placeholder for log filename and the patch was landed at caddyfile: Add support for args on imports #3423
But it does not work on mine. :slightly_frowning_face:
It cannot replace {host} as the {args[0]} of a snippet for log output file.
{"level":"info","ts":1742132974.028858,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132974.0328307,"msg":"adapted config to JSON","adapter":"caddyfile"}
Error: loading initial config: loading new config: setting up custom log 'log0': loading log writer module: loading module 'file': provision caddy.logging.writers.file: invalid filename for log file: unrecognized placeholder {http.request.host}
{"level":"info","ts":1742132975.4025917,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132975.4074125,"msg":"adapted config to JSON","adapter":"caddyfile"}
Error: loading initial config: loading new config: setting up custom log 'log1': loading log writer module: loading module 'file': provision caddy.logging.writers.file: invalid filename for log file: unrecognized placeholder {http.request.host}
{"level":"info","ts":1742132979.1320577,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132979.1396198,"msg":"adapted config to JSON","adapter":"caddyfile"}
Error: loading initial config: loading new config: setting up custom log 'log6': loading log writer module: loading module 'file': provision caddy.logging.writers.file: invalid filename for log file: unrecognized placeholder {http.request.host}
{"level":"info","ts":1742132984.1881135,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132984.1925123,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1742132989.4567785,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132989.461187,"msg":"adapted config to JSON","adapter":"caddyfile"}
Error: loading initial config: loading new config: setting up custom log 'log2': loading log writer module: loading module 'file': provision caddy.logging.writers.file: invalid filename for log file: unrecognized placeholder {http.request.host}
{"level":"info","ts":1742132991.6371255,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132991.641008,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1742132995.584764,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742132995.588706,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1742133002.5841055,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1742133002.5883136,"msg":"adapted config to JSON","adapter":"caddyfile"}
2.9.1-builder
# cat /etc/debian_version
12.10
# docker compose up -d
# caddy/compose.yaml
    build:
      context: .
    container_name: caddy2
    pull_policy: build
    user: "3012:3012"
    cap_add:
      - NET_ADMIN
    env_file:
      - ./secrets.env
      - "5580:80"
      - "5443:443"
      - "5443:443/udp"
      - ./caddy:/etc/caddy
      - ./config:/config:rw
      - ./data:/data:rw
      - ./srv:/srv
      - /mnt/logs/caddy/:/logs
	# 	auto_https disable_redirects
	grace_period 10s
	email janus.ng@gmail.com
	# operation CA
	# 	acme_ca https://acme-v02.api.letsencrypt.org/directory
	# staging CA
(rp) {
		dns duckdns {args[0]}
	reverse_proxy {args[1]}
		output file /logs/{args[2]}.json {
			roll_size 10MB
			roll_keep 10
			roll_keep_for 168h
		format json
# ha.*
ha.[REDACT] homeassistant.[REDACT] {
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.50:8123 {host}
ha.[REDACT] {
	import rp {env.DYNU_API_TOKEN} http://10.27.0.50:8123 {host}
# ha2.*
ha2.[REDACT] homeassistant2.[REDACT] {
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.65:8123 {host}
ha2.[REDACT] {
	import rp {env.DYNU_API_TOKEN} http://10.27.0.65:8123 {host}
# nc.*
nc.[REDACT] nextcloud.[REDACT] {
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.65:1780 {host}
nc.[REDACT] {
	import rp {env.DYNU_API_TOKEN} http://10.27.0.65:1780 {host}
# plex.*
plex.[REDACT] {
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.50:32400 {host}
plex.[REDACT] {
	import rp {env.DYNU_API_TOKEN} http://10.27.0.50:32400 {host}
# v2ray.*
v2.[REDACT] {
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.50:6080 {host}
v2.[REDACT] {
	import rp {env.DYNU_API_TOKEN} http://10.27.0.50:6080 {host}
$ cat Dockerfile
FROM caddy:2.9.1-builder AS builder
RUN xcaddy build \
	--with github.com/caddy-dns/dynu \
	--with github.com/caddy-dns/duckdns
FROM caddy:2.9.1
{host} only exists when there’s an incoming HTTP request.
When Caddy starts, it needs to create a log file, but since there’s no HTTP request at that moment, there’s no {host} value available. In other words, {host} doesn’t exist yet during Caddy’s startup, so it can’t be used at that point.
@francislavoie clearly explains that here.
In the links you provided, they are using hardcoded values instead. So, in your case, you’d have to use somethign like this:
	import rp {env.DUCKDNS_API_TOKEN} http://10.27.0.50:8123 ha.[REDACT]
Thanks for your explanation.
