I use Deluge as a torrent client and have Sonarr, Radarr and Jackett installed as well. I tried to use the split tunneling feature on ExpressVPN to prevent Ombi and Caddy from being encrypted in the VPN. When the VPN is off, everything works as intended. When I start the VPN, Caddy starts, but i get a constant loading from the borwser trying to access Ombi at my domain.
I also cannot seem to to get Caddy to properly start with Windows.
I have tried changing applications and managing the split tunneling feature with Express VPN.
I tried using NSSM and a .bat file to start Caddy.
Here is the error I keep getting when I turn on the VPN even though Caddy and Ombi and Dynu IP are all set to NOT use the VPN. I also have a windows firewall rule set to accept all 80 and 443 port connections. And I have the VPN set to allow all LAN connections.
