1. Caddy version (caddy version): 2
Inside a docker container on a raspberry pi 4.
N/A
version: "3.7"
image: caddy
hostname: caddy
- MY_DOMAIN
- ./data:/data
- ./config:/config
default:
external:
# testing
#make homer my homepage
{$MY_DOMAIN} {
reverse_proxy homer:6941
portainer.{$MY_DOMAIN} {
reverse_proxy portainer:9000
radarr.{$MY_DOMAIN} {
reverse_proxy radarr:7878
sonarr.{$MY_DOMAIN} {
reverse_proxy sonarr:8989
lidarr.{$MY_DOMAIN} {
reverse_proxy lidarr:8686
ombi.{$MY_DOMAIN} {
reverse_proxy ombi:3579
jellyfin.{$MY_DOMAIN} {
reverse_proxy jellyfin:8096
jackett.{$MY_DOMAIN} {
reverse_proxy mullvad:9117
qbittorrent.{$MY_DOMAIN} {
reverse_proxy mullvad:8080
bitwarden.{$MY_DOMAIN} {
# Disallow the site to be rendered within a frame (clickjacking protection)
X-Frame-Options "DENY"
# Prevent search engines from indexing (optional)
X-Robots-Tag "none"
# Server name removing
-Server
# Notifications redirected to the websockets server
reverse_proxy /notifications/hub bitwarden:3012
# Proxy the Root directory to Rocket
reverse_proxy bitwarden:80
I want to route certain container traffic (jackett and qbittorrent) through a vpn.
I have a wireguard container that is on the same network as caddy, and it connect to a mullvad sever. For those 2 containers I use network_mode: container:mullvad as the network.
It appears as though caddy correctly sees those 2 containers, but when I go to the actual address I get this: HTTP ERROR 502.
I have the relevant error logs posted below.
{"level":"error","ts":1600277313.0205107,"logger":"http.log.error","msg":"dial tcp 192.168.80.2:9117: i/o timeout","request":{"method":"GET","uri":"/UI/Dashboard","proto":"HTTP/2.0","remote_addr":"<my public ip>:44672","host":"jackett.rypi.software","headers":{"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Accept-Language":["en-US,en;q=0.9"],"Cookie":["Jackett=CfDJ8KbBTytGR8NNsWSsHP4qUiycGDNo5Kw2pjx29gHYf2C8xL2YA_VTv3_BMkVMNYfJipSUmZcm8XD34Zx4juPRRjCsU9IncCIvL3MB79Cirj2zEBULKNWaW-ff5n-3jp1gPMl4Ys1tCkUDFdD2JE90AR6RK7vgfbQfgdFHUsgva0cUBijJIyIJVi_nI0YeRvh7-JAwAFW50jBmpgYxtcvUGX5nex2w7qAvl_pp8A9pfiMfaFN8zJpjxAevq1gtysI752Xo_5R4i3csBwkVMMzTSZ5gkpfWRre3SeuORYQzJfDbiipC1ZQetlfALQgqwY1s2tOvSaO-YElyPG5guYjsTAY"],"Dnt":["1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.105 Safari/537.36"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"ciphersuite":4867,"proto":"h2","proto_mutual":true,"server_name":"jackett.rypi.software"}},"duration":10.001932598,"status":502,"err_id":"jfvrgzf3r","err_trace":"reverseproxy.(*Handler).ServeHTTP (reverseproxy.go:411)"}
I have researched possible solutions on these forums and using a search engine, but have not been able to find a solution.
I have done a lot of tweaking the network and hostnames and such, but I am pretty confident that the vpn connects correctly to the server, the containers are connected to the vpn, and that caddy can see the containers. The problem seems to lie with caddy interacting with the vpn, I just dont know where to go from here.
This post seems to be a similar error to mine, but went unsolved so I don’t know if @The_Spartan ever found a solution.
