Using caddy proxy to access another caddy proxy
I want to run 2 instances of caddy; one that is locally available for my clients on lan, and one that is publicly available for my clients on the internet. I want to access everything under the same dns name. In an ideal world, I would like to do something like this:
Caddyfile: prod
some.service.tld {
  reverse_proxy tunneled_connection_to_lab_instance
Caddyfile: lab
some.service.tld {
  reverse_proxy the_real_backend_service:some-port
where the wan instance proxies everything to the lan instance, instead of the wan instance directly accessing all the backend services. What’s the best way to achieve this? Is this simple config possible?
N/A
Both hosts are running v2.10.2 h1:g/gTYjGMD0dec+UgMw8SnfmJ3I9+M2TdvoRL/Ovu6U8=, pulled from ghcr.io/caddybuilds/caddy-cloudflare:latest
Services in docker compose projects
Both hosts are amd64. Both caddy instances are running on docker.
host lab:
    image: ghcr.io/caddybuilds/caddy-cloudflare:latest
      - "./Caddyfile:/etc/caddy/Caddyfile:ro"
      - "./caddy_data:/data"
      - "./caddy_config:/config"
      - CLOUDFLARE_API_TOKEN=(redacted)
host prod:
N/A
See Common Caddyfile Patterns — Caddy Documentation
Thanks for making this post because I was searching for the answers and beyond. I did find this post too: Running a Caddy server behind another [SOLVED]
I would like to know on which instance (front or back) I should put all the directives in? Does it matter at all?
front instance facing public internet
subdomain.domain.tld {
    reverse_proxy http://192.168.1.50
    basic_auth {
        <username> <hash>
back instance 192.168.1.50 facing private subnet
http://subdomain.domain.tld {
    reverse_proxy <docker-container>:<port>
It depends on what you’re trying to do. That’s totally up to you where you put your auth layer. If you put it in the front one then you avoid unauthenticated requests hitting your back one but depending on your level of traffic that might not really matter
Thanks for the additional information. I couldn’t assess whether configuring basic_auth on the frontend or backend posed a security risk. I only need Caddy privately for standard self-hosted services such as Immich, Nextcloud, Vaultwarden, etc.
Until now, I had a public /28 subnet with 5 usable IPs, but I have to reduce this to one IP, so I now need the option “Caddy proxying to another Caddy”.
