Running a Caddy server behind another [SOLVED]
1. Caddy version (caddy version): v2
In a LXC Container
Ubuntu 20.04 Container
I have a need to run another webserver running on a separate VM. My primary Caddy server is primarily used for reverse proxy & has been serving me well.
I need help to configure this primary Caddy Server to proxy all requests to the 2nd Caddy server for domain2.mydomain.com
i tried the proxy directive, but i guess thats not supported in v2
Any idea how i can get this working will LE?
thanks
See the docs.
Thanks. I tried this but the reverse proxy doesnt seem to work
On my main Caddy Server I have this
cloud.mydomain.com {
    reverse_proxy http://192.168.11.97
& on the server where cloud is running, this is my caddyfile
        encode zstd gzip
        templates
        file_server browse
        root * /usr/share/caddy
        # file_server
        # php_fastcgi localhost:9000
When I restart my main caddy, i’m unable to reach the cloud server
You’ll probaby need to specify http://cloud.mydomain.com for your upstream server, since the one in front will terminate TLS.
I’m really sorry. I dont understand
I have specified the IP of the Main Server (192.168.11.6) in Unbound as the Override (Is this the Upstream Server>?) So all traffic that hits my firewall for cloud.mydomain.com hits this server. I guess this is where the LE cert is generated.
The 2nd server (Downstream?) another Caddy instance is running
If you please dont mind can you please let me know what my Caddyfile should look like?
On your main server, use this (as you already have):
On your backend/upstream, use this:
http://cloud.mydomain.com {
	encode zstd gzip
	templates
	file_server browse
Your backend will not fetch a certificate from Let’s Encrypt, because it doesn’t need one, since your first one will be doing it. Specifying http:// will tell Caddy not to manage a TLS certificate for that domain, and will make sure it’s serving the site over port 80 instead of 443 (your first one will try to proxy on port 80 because you specified http:// on the upstream address).
You want to make sure your domain name domain.com resolves to the frontend Caddy IP (192.168.11.6) from inside your network (split-DNS).
PERFECT!!!
Thank you very much … that worked
Yes, i have that. thanks
