Try_files Rewrite Request exclude path help plz
Hi, I need to enable rewrite rules on my WordPress site with Caddy 2 server.
When I was on NGINX, I was doing the following:
location / {
try_files $uri $uri/ /index.php$args;
In the same way when I just keep:
try_files {path} {path}/ /index.php?{query}
on Caddyfile, everything is working fine except I am getting error too many redirects on:
https://mysite.com/wp-admin/
path. So, it is necessary that I must exclude /wp-admin/ path from rewrite since rewrite for that path is not necessary for me.
That were the main problem appeared I tried many ways but I am unable to exclude /wp-admin/ path from try_files directive. I checked documentation many times but I don’t see a way to exclude a path.
I tried to validate with many ways but failed such as the following: So please help me!
@try_files {
file
not path /wp-admin/* {
rewrite @try_files {http.matchers.file.relative}
@wp-admin {
rewrite @wp-admin {path} {path}/ /index.php?{query}
@wp-admin {
not path / /wp-admin/*
rewrite @wp-admin /index.php?{query}
@wp-admin {
@wp-admin {
try_files @wp-admin {path} {path}/ /index.php?{query}
@try_files {
I think you were on the right path with your first attempt using the expanded form of try_files. the matcher looks a bit malformed however, please see Request matchers (Caddyfile) β€” Caddy Documentation.
Try this instead
@try_files {
    file {
edit: removing ?{query} from code snippet as it is implied, thanks @francislavoie
The ?{query} bit is unnecessary, Caddy retains the query parameters when rewriting.
@cupanoodle thank you man you are awesome! & @francislavoie thank you too!!
