Converting nginx's try_files to caddy
1. Output of caddy version:
sudo systemctl start caddy
OS: Ubuntu 22.04
Built with: caddy-dns/cloudflare (91cf700356a1cd0127bcc4e784dd50ed85794af5)
sudo caddy stop && sudo caddy start ./Caddyfile
or
sudo systemctl restart caddy
Description=caddy
After=network.target
WorkingDirectory=/home/user/caddy
Environment=
Type=simple
User=root
ExecStart=/usr/bin/caddy run /home/user/caddy/Caddyfile
Restart=on-failure
        acme_dns cloudflare <REDIACTED>
                output file /home/user/caddy/server.log
                format console
onix.minjae.dev {
        php_fastcgi unix//run/php/php8.1-fpm.sock php {
                root /var/www/pterodactyl/public
                index index.php
                split ^(.+\.php)(/.+)$
                try_files {uri} /index.php?{uri}
I was moving the nginx configuration (full configuration) to Caddyfile, but I have trouble with try_files, how do I convert nginx’s
try_files $uri $uri/ /index.php?$query_string;
to caddy one?
(currently website only shows empty page)
N/A
I’ve tried all things in the below links, but it seems they aren’t working.
Your config should just look like this:
onix.minjae.dev {
	root * /var/www/pterodactyl/public
That’s all you need. Caddy’s php_fastcgi directive has built-in try_files, and it should work just fine out of the box in your case.
Thanks! It worked.
