I am trying to set up Caddy in order to have different third level domain to point at different container on my VPS. So far I used Caddy to reverse proxy a couple of services: Baserow, N8N, Portainer… In all of them, I used Caddy to be able to connect through SSL in a third level domain.
Now I want to connect another service, on another third level, but I am having trouble. To be noted, this one (LinkStack) is the only one that, as default setting, has ports 80 and 443 exposed. The same ports Caddy uses.
I got no error, simply, the service is unreachable.
v2.8.4
4. The stack now (working)
image: caddy:latest
- caddy_data:/data
- ${DATA_FOLDER}/caddy_config:/config
- ${DATA_FOLDER}/caddy_config/Caddyfile:/etc/caddy/Caddyfile
n8n:
image: docker.n8n.io/n8nio/n8n
container_name: n8n
restart: always
- N8N_HOST=${N8N_SUBDOMAIN}.${DOMAIN_NAME}
- N8N_PORT=5678
- N8N_PROTOCOL=https
- NODE_ENV=production
- WEBHOOK_URL=https://${N8N_SUBDOMAIN}.${DOMAIN_NAME}/
- GENERIC_TIMEZONE=${GENERIC_TIMEZONE}
- N8N_LOG_OUTPUT=console
- N8N_LOG_LEVEL=debug
- n8n_data:/home/node/.n8n
- ${DATA_FOLDER}/local_files:/files
portainer:
image: portainer/portainer-ce:latest
container_name: portainer
- "9000:9000"
- portainer_data:/data
caddy_data:
external: true
n8n_data:
external: true
portainer_data:
Caddy config
n8n.***.it {
reverse_proxy n8n:5678 {
flush_interval -1
portainer.***.it {
reverse_proxy portainer:9000
Addition to the yml file
linkstack:
container_name: linkstack
hostname: linkstack
- HTTP_SERVER_NAME=links.planbproject.it
- HTTPS_SERVER_NAME=links.planbproject.it
- SERVER_ADMIN=g.lanzi@planbproject.it
- TZ=Europe/Rome
- PHP_MEMORY_LIMIT=512M
- UPLOAD_MAX_FILESIZE=8M
- "8000:8000"
# - "4431:4431"
- linkstack:/htdocs
image: linkstackorg/linkstack:latest
linkstack:
external: true
Addition to the caddy config file
links. *** .it {
reverse_proxy linkstack:8000
I am not sure how to deal with the port in the compose file and in the caddy config.
Can you help?
Thank you
