@francislavoie Thank you so much, but no matter what I use
Shift+G
or journalctl -u caddy --no-pager | less +G
, there’s no other logs. All logs I can see is following.
Sep 25 22:59:04 instance-1 caddy[15448]: HOME=/var/lib/caddy
Sep 25 22:59:04 instance-1 caddy[15448]: LOGNAME=caddy
Sep 25 22:59:04 instance-1 caddy[15448]: USER=caddy
Sep 25 22:59:04 instance-1 caddy[15448]: INVOCATION_ID=0c599e557dc848279112aecb56fe5e28
Sep 25 22:59:04 instance-1 caddy[15448]: JOURNAL_STREAM=8:165592
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0482202,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"warn","ts":1632581944.049663,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0507057,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0508385,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0511289,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0002febd0"}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.051359,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["sub.esdomain.com"]}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0515633,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0523117,"logger":"tls","msg":"finished cleaning storage units"}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0527992,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 25 22:59:04 instance-1 caddy[15448]: {"level":"info","ts":1632581944.0528612,"msg":"serving initial configuration"}
Sep 25 22:59:04 instance-1 systemd[1]: Started Caddy.
Sep 25 22:59:08 instance-1 caddy[15448]: {"level":"info","ts":1632581948.4735227,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
Sep 25 22:59:08 instance-1 caddy[15448]: {"level":"warn","ts":1632581948.4735641,"msg":"exiting; byeee!! <F0><9F><91><8B>","signal":"SIGTERM"}
Sep 25 22:59:08 instance-1 systemd[1]: Stopping Caddy...
Sep 25 22:59:08 instance-1 caddy[15448]: {"level":"info","ts":1632581948.477029,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0002febd0"}
Sep 25 22:59:08 instance-1 caddy[15448]: {"level":"info","ts":1632581948.4782743,"logger":"admin","msg":"stopped previous server","address":"tcp/localhost:2019"}
Sep 25 22:59:08 instance-1 caddy[15448]: {"level":"info","ts":1632581948.478296,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Sep 25 22:59:08 instance-1 systemd[1]: caddy.service: Succeeded.
Sep 25 22:59:08 instance-1 systemd[1]: Stopped Caddy.
Sep 25 22:59:30 instance-1 systemd[1]: Starting Caddy...
Sep 25 22:59:30 instance-1 caddy[15482]: caddy.HomeDir=/var/lib/caddy
Sep 25 22:59:30 instance-1 caddy[15482]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Sep 25 22:59:30 instance-1 caddy[15482]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Sep 25 22:59:30 instance-1 caddy[15482]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Sep 25 22:59:30 instance-1 caddy[15482]: caddy.Version=v2.4.5 h1:P1mRs6V2cMcagSPn+NWpD+OEYUYLIf6ecOa48cFGeUg=
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.GOOS=linux
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.GOARCH=amd64
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.Compiler=gc
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.NumCPU=2
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.GOMAXPROCS=2
Sep 25 22:59:30 instance-1 caddy[15482]: runtime.Version=go1.17
Sep 25 22:59:30 instance-1 caddy[15482]: os.Getwd=/
Sep 25 22:59:30 instance-1 caddy[15482]: LANG=C.UTF-8
Sep 25 22:59:30 instance-1 caddy[15482]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Sep 25 22:59:30 instance-1 caddy[15482]: NOTIFY_SOCKET=/run/systemd/notify
Sep 25 22:59:30 instance-1 caddy[15482]: HOME=/var/lib/caddy
Sep 25 22:59:30 instance-1 caddy[15482]: LOGNAME=caddy
Sep 25 22:59:30 instance-1 caddy[15482]: USER=caddy
Sep 25 22:59:30 instance-1 caddy[15482]: INVOCATION_ID=3c93ebfae1e147b5a50781a4f9f6967f
Sep 25 22:59:30 instance-1 caddy[15482]: JOURNAL_STREAM=8:164838
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2402203,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"warn","ts":1632581970.2413936,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2425866,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2427633,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.243474,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000341d50"}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2536423,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2538764,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["sub.esdomain.com"]}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2543538,"logger":"tls","msg":"finished cleaning storage units"}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.2550151,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Sep 25 22:59:30 instance-1 caddy[15482]: {"level":"info","ts":1632581970.255211,"msg":"serving initial configuration"}
Sep 25 22:59:30 instance-1 systemd[1]: Started Caddy.
