TLS handshake error (ws+tls)
Only use websockets. I am sure of that, thank you.
Conclusion:
https://caddy.community/t/appending-tls-handshake-error-ws-tls/14474
Sorry I opened a new post because the old post is closed.
This question is fixed, and I want to share how.
Caddy is strictly case-sensitive, as shown in the old post, my Caddy config.json is following
sub.esdomain.com {
   protocols tls1.2 tls1.3
   ciphers TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384 TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305_SHA256
   curves x25519
 @staff_websocket {
  path /3367
  header Connection *Upgrade*
  header Upgrade websocket
 reverse_proxy @staff_websocket localhost:37566
But the proxy tool I’m using sends the header like Connection *upgrade*, and I added a new block in config.json
@staff_websocket_alias {
  path /3367
  header Connection *upgrade*
reverse_proxy @staff_websocket_alias localhost:37566
That’s all.
What you can do is this:
@staff_websocket {
	path /3367
Caddy will then match either of those Connection header patterns.
But really, do you even need the matcher? If the only thing that site block has is that proxy, then you can completely omit the matcher.
Also, this is redundant, because they’re already the defaults, so you can remove it:
Also, why are you changing the ciphers? There’s rarely any benefit to doing that. Caddy’s defaults are secure.
I don’t think Let’s Encrypt nor ZeroSSL supports curve x25519 yet. I don’t think this’ll actually work. Caddy allows configuring it, but I don’t think a cert will be successfully issued with that key type. This option will actually do nothing unless you set key_type, because the default is still to issue RSA keys.
I see, thank you.
I added additional information in edits above, in case you missed it.
In order not to create confusion with the previous post, I did not delete the content, such as protocols tls1.2 tls1.3.
I used the default configuration information of the proxy protocol, and you will see these config thing.
I just removed the matcher and tested, it works, thank you.
