Templates not working for me? Probably driver error
With the V2 built from github on a Mac.
Including the templates directive in the Caddyfile, I get no html output from my sample web site - it’s all
static pages.
Are them some examples out there of a web site using templates?
Thanks,
Joe
Please post your full Caddyfile, we can’t help you without knowing what you’ve tried.
The thread template is there to help both you and us. Make sure to fill it out instead of deleting it!
http://127.0.0.1:4000 {
root * /Users/joe/caddy/public_html
output file http.log
templates
Would you be able to supply a minimal index file that shows this behaviour?
Also helpful information:
  • Version (run caddy version and copy output)
  • How you run Caddy (which command / as a service / etc)
  • Which requests you made, and any log output from those requests
INDEX.HTML:
MINIMAL WEB PAGE
{{.IP}}
CADDYFILE:
templates
…/caddy version
(devel)
This is really frustrating as I can’t even get the small example from the Caddy V2 documentation working.
I just get a blank page returned with nothing in it if I look at the page source.
I noticed this from the log:
status": 500, “err_id”: “5vtpj8ve5”, “err_trace”: “templates.(*Templates).executeTemplate (templates.go:292)”}
Byw, is there a way to shorten the size of each log entry, or can I pick & choose which bits of data get logged?
Thanks,
Joe
It errors out because there’s no data element with the name .IP to be included in template execution context. The list of available data and functions is listed here in the JSON docs. I believe you’re looking for {{.RemoteIP}}.
In regards to logging, you might be interested in the single_field option.
Ahh! Success! Thanks Mohammed for the hint.
Joe
Also, in the wiki, @nicolinux has written a really handy guide for using jq to parse Caddy’s log output to your liking.
