TCP Keepalives from client to caddy (*not* to upstream)
Downloaded binary from the website and activated with systemd.
Ubuntu 20.04 LTS
sudo systemctl start caddy
(it’s enabled so it runs by default)
; Ansible managed
; source: https://github.com/mholt/caddy/blob/master/dist/init/linux-systemd/caddy.service
; version: 6be0386
; changes: Set variables via Ansible
After=network-online.target
Restart=on-failure
StartLimitInterval=86400
StartLimitBurst=5
User=www-data
Group=www-data
ExecStart="/usr/local/bin/caddy" run --environ --config "/etc/caddy/Caddyfile"
ExecReload="/usr/local/bin/caddy" reload --config "/etc/caddy/Caddyfile"
; Use a minimal /dev
PrivateDevices=true
ProtectHome=false
; … except /etc/ssl/caddy, because we want Letsencrypt-certificates there.
;   This merely retains r/w access rights, it does not add any new. Must still be writable on the host!
ReadWriteDirectories=/etc/ssl/caddy /var/log/caddy
; They further retrict privileges that can be gained by caddy.
NoNewPrivileges=true
:8080 {
        reverse_proxy localhost:8081 {
                        keepalive_interval 65s
I am receiving TCP keepalive packets every 15 seconds (if there haven’t been any other packets in that duration). I expect to receive them every 65 seconds (or, since my application is sending websocket ping/pong faster than that, I shouldn’t receive any tcp keepalives at all).
The following is the wireshark summary:
No.     Time           Source     Protocol Length Info
     27 72.148176926   48628      HTTP     412    GET /test/ws?since=1656775973 HTTP/1.1
     28 72.148223335   8080       TCP      86     8080 → 48628 [ACK] Seq=1 Ack=327 Win=64000 Len=0 TSval=3094866771 TSecr=6435782
     29 72.151626305   8080       HTTP     230    HTTP/1.1 101 Switching Protocols
     30 72.151963175   8080       WebSocket 158    WebSocket Text [FIN]
     31 72.153697178   48628      TCP      86     48628 → 8080 [ACK] Seq=327 Ack=145 Win=86528 Len=0 TSval=6435782 TSecr=3094866775
     32 72.154024249   48628      TCP      86     48628 → 8080 [ACK] Seq=327 Ack=217 Win=86528 Len=0 TSval=6435782 TSecr=3094866775
     33 87.666293523   8080       TCP      86     [TCP Keep-Alive] 8080 → 48628 [ACK] Seq=216 Ack=327 Win=64128 Len=0 TSval=3094882289 TSecr=6435782
     34 87.706096262   48628      TCP      86     [TCP Keep-Alive ACK] 48628 → 8080 [ACK] Seq=327 Ack=217 Win=86528 Len=0 TSval=6437337 TSecr=3094866775
     35 103.026345910  8080       TCP      86     [TCP Keep-Alive] 8080 → 48628 [ACK] Seq=216 Ack=327 Win=64128 Len=0 TSval=3094897650 TSecr=6437337
     36 103.062308046  48628      TCP      86     [TCP Keep-Alive ACK] 48628 → 8080 [ACK] Seq=327 Ack=217 Win=86528 Len=0 TSval=6438873 TSecr=3094866775
     37 117.153146331  8080       WebSocket 88     WebSocket Ping [FIN]
     38 117.220795649  48628      TCP      86     48628 → 8080 [ACK] Seq=327 Ack=219 Win=86528 Len=0 TSval=6440287 TSecr=3094911776
     39 117.221098923  48628      WebSocket 92     WebSocket Pong [FIN] [MASKED]
     40 117.221148901  8080       TCP      86     8080 → 48628 [ACK] Seq=219 Ack=333 Win=64128 Len=0 TSval=3094911844 TSecr=6440287
     41 132.162149274  48628      WebSocket 92     WebSocket Ping [FIN] [MASKED]
     42 132.162260954  8080       TCP      86     8080 → 48628 [ACK] Seq=219 Ack=339 Win=64128 Len=0 TSval=3094926785 TSecr=6441783
     43 132.162751004  8080       WebSocket 88     WebSocket Pong [FIN]
     44 132.201040062  48628      TCP      86     48628 → 8080 [ACK] Seq=339 Ack=221 Win=86528 Len=0 TSval=6441787 TSecr=3094926786
     45 147.399617161  8080       TCP      86     [TCP Keep-Alive] 8080 → 48628 [ACK] Seq=220 Ack=339 Win=64128 Len=0 TSval=3094942023 TSecr=6441787
     46 147.514169666  48628      TCP      86     [TCP Keep-Alive ACK] 48628 → 8080 [ACK] Seq=339 Ack=221 Win=86528 Len=0 TSval=6443318 TSecr=3094926786
     47 162.159970283  8080       WebSocket 88     WebSocket Ping [FIN]
     48 162.261729577  48628      TCP      86     48628 → 8080 [ACK] Seq=339 Ack=223 Win=86528 Len=0 TSval=6444792 TSecr=3094956783
     49 162.262402747  48628      WebSocket 92     WebSocket Pong [FIN] [MASKED]
     50 162.262422115  8080       TCP      86     8080 → 48628 [ACK] Seq=223 Ack=345 Win=64128 Len=0 TSval=3094956886 TSecr=6444792
     51 178.119675152  8080       TCP      86     [TCP Keep-Alive] 8080 → 48628 [ACK] Seq=222 Ack=345 Win=64128 Len=0 TSval=3094972743 TSecr=6444792
     52 178.122020596  48628      TCP      86     [TCP Keep-Alive ACK] 48628 → 8080 [ACK] Seq=345 Ack=223 Win=86528 Len=0 TSval=6446378 TSecr=3094956886
The following are my logs:
2022/07/02 17:07:01.976 INFO    using provided configuration    {"config_file": "Caddyfile", "config_adapter": ""}
2022/07/02 17:07:01.980 INFO    admin   admin endpoint started  {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/07/02 17:07:01.981 INFO    tls.cache.maintenance   started background certificate maintenance      {"cache": "0xc000430f50"}
2022/07/02 17:07:01.981 DEBUG   http    starting server loop    {"address": "[::]:8080", "http3": false, "tls": false}
2022/07/02 17:07:01.981 INFO    tls     cleaning storage unit   {"description": "FileStorage:/home/karmanyaahm/.local/share/caddy"}
2022/07/02 17:07:01.981 INFO    tls     finished cleaning storage units
2022/07/02 17:07:01.981 INFO    autosaved config (load with --resume flag)      {"file": "/home/karmanyaahm/.local/share/caddy/autosave.json"}
2022/07/02 17:07:01.981 INFO    serving initial configuration
2022/07/02 17:07:11.758 DEBUG   http.handlers.reverse_proxy     selected upstream       {"dial": "localhost:8081", "total_upstreams": 1}
2022/07/02 17:07:11.761 DEBUG   http.handlers.reverse_proxy     upstream roundtrip      {"upstream": "localhost:8081", "duration": 0.002632688, "request": {"remote_ip": "fd73:ac06:d336:6780:45c7:ccad:8a1e:729b", "remote_port": "48628", "proto": "HTTP/1.1", "method": "GET", "host": "karmanyaahsarch.homenet.malhotra.cc:8080", "uri": "/test/ws?since=1656775973", "headers": {"Sec-Websocket-Version": ["13"], "X-Forwarded-For": ["fd73:ac06:d336:6780:45c7:ccad:8a1e:729b"], "X-Forwarded-Proto": ["http"], "X-Forwarded-Host": ["karmanyaahsarch.homenet.malhotra.cc:8080"], "Accept-Encoding": ["gzip"], "Upgrade": ["websocket"], "Sec-Websocket-Key": ["WCm5Mz872IAOPbaTfupLSA=="], "User-Agent": ["ntfy/1.10.0 (fdroid; Android 10; SDK 29)"], "Connection": ["Upgrade"], "Sec-Websocket-Extensions": ["permessage-deflate"]}}, "headers": {"Sec-Websocket-Accept": ["PttZ6SVgw+WyjZ7VBIwteet3tkw="], "Upgrade": ["websocket"], "Connection": ["Upgrade"]}, "status": 101}
2022/07/02 17:07:11.761 DEBUG   http.handlers.reverse_proxy     upgrading connection    {"upstream": "localhost:8081", "duration": 0.002632688, "request": {"remote_ip": "fd73:ac06:d336:6780:45c7:ccad:8a1e:729b", "remote_port": "48628", "proto": "HTTP/1.1", "method": "GET", "host": "karmanyaahsarch.homenet.malhotra.cc:8080", "uri": "/test/ws?since=1656775973", "headers": {"Sec-Websocket-Version": ["13"], "X-Forwarded-For": ["fd73:ac06:d336:6780:45c7:ccad:8a1e:729b"], "X-Forwarded-Proto": ["http"], "X-Forwarded-Host": ["karmanyaahsarch.homenet.malhotra.cc:8080"], "Accept-Encoding": ["gzip"], "Upgrade": ["websocket"], "Sec-Websocket-Key": ["WCm5Mz872IAOPbaTfupLSA=="], "User-Agent": ["ntfy/1.10.0 (fdroid; Android 10; SDK 29)"], "Connection": ["Upgrade"], "Sec-Websocket-Extensions": ["permessage-deflate"]}}}
I tried setting transport.http.keepalive_interval to 65 seconds. However, according to the Caddy docs transport defines how to communicate with the backend. Default is http. Transport communicates with the backend, not the client.
I cannot find any setting to set the keepalive_interval from caddy to the client (my mobile device).
This is very similar to my query, but it was never solved. Mqtt/tcp keepalive when proxying websocket
Ah, you need the net.TCPConn.SetKeepAlivePeriod() parameter exposed:
15 seconds is indeed Go’s current default for probes. We just haven’t had a feature request to make this changeable. Congrats, you’re the first!
Want to open an issue on GitHub so we can keep track of this? Feel free to just link to this topic. We’d also be happy to review a proposal/PR if you want to speed things up :smiley:
Depending on what kind of flexibility you need, this might actually be tricky to get just right. From [this article(https://thenotexpert.com/golang-tcp-keepalive/):
It sets both Idle time and Retry interval. The Ping amount remains at the system default. So when I set it to, say, 5 * time.Second, it waits for 5 seconds, pings and waits for another 5. And 8 more pings. I require more flexibility.
Doing that requires system calls. Which we can do… but it’s a little more complicated.
Done `net.TCPConn.SetKeepAlivePeriod` on HTTP(S) listener · Issue #4863 · caddyserver/caddy · GitHub
