docker-compose
- CADDY_TLS
- DOMAIN_NAME
- TZ=Europe/London
image: caddy
restart: always
- ./deployment/Caddyfile:/etc/caddy/Caddyfile
- caddy_config:/config
- caddy_data:/data
- django_static:/app/static
- django_media:/app/media
rabbitmq:
container_name: rabbitmq
- RABBITMQ_SERVER_ADDITIONAL_ERL_ARGS=-rabbitmq_management path_prefix "/rabbitmq"
- DEFAULT_USER=admin
- DEFAULT_PASS=${RABBITMQ_DEFAULT_PASS}
hostname: rabbitmq # must be set for data to be persisted - https://github.com/docker-library/rabbitmq/issues/106
image: rabbitmq:3-management-alpine
- "1883:1883"
restart: always
- rabbitmq_data:/var/lib/rabbitmq
- ./deployment/rabbitmq_plugins:/etc/rabbitmq/enabled_plugins:ro
{$DOMAIN_NAME} {
# serve some files directly from caddy rather than through django/unicorn for performance
root * /app # needed for file_server
file_server /static/* # assets e.g. js, css
file_server /media/* # uploaded files e.g. OTA updates
rewrite /favicon.ico /static/images/favicon.ico
# various reverse proxies which strip the TLS part and pass through http
reverse_proxy /ws rabbitmq:15675 # rabbitmq websocket
reverse_proxy /rabbitmq/* rabbitmq:15672 # rabbitmq admin
reverse_proxy /grafana/* grafana:3000 # grafana for internal use
reverse_proxy /portal/* portal:3000 # custom grafana instance for landlord portal
# for all other web requests and not /static or /media, proxy to Django
@not_served {
not path /static/* /media/*
reverse_proxy @not_served web:8000
tls {$CADDY_TLS} # generate ssl cert automatically
encode gzip # encode gzip for performance
level WARN
# allow both http and https for firmware as needed by some devices
http://{$DOMAIN_NAME} {
handle /media/firmware* {
root * /app
# fallback to redirect
redir https://{host}{uri} 308
I am connecting devices to a rabbitmq container using mqtt-over-wss but using Caddy to terminate the ssl connection. So the device connects to caddy port 443 using wss://, and between caddy and rabbitmq it’s plain ws://.
I did it this way because I thought it was a good way to avoid having to generate my own CA certs etc in rabbitmq when I can just use the ones in Caddy, and also because the connection is less likely to be blocked by firewalls if it’s port 443. But no-one else is doing it this way so it might be a terrible idea.
Everything works fine but now that I’m connecting devices through 4G and have a limited data allowance I have noticed that an mqtt keepalive is being sent every 15s which is unnecessarily using data. If I increase this value to 120s or above (so sending a packet every 60s) then the mqtt connection gets closed (see log below). If I use a value of 115s then the connection stays open but TCP keepalive packets are sent every 15s instead, as can be seen by the packet capture below:
Time Source Destination Protocol Length Info
33.8 172.18.0.6 <client> TCP 54 443 → 30441 [ACK] Seq=2 Ack=114 Win=63989 Len=0
33.8 172.18.0.6 <client> TLSv1.2 89 Application Data
34.0 <client> 172.18.0.6 TCP 54 30441 → 443 [ACK] Seq=114 Ack=37 Win=4710 Len=0
49.1 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=36 Ack=114 Win=63989 Len=0
49.6 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=114 Ack=37 Win=4710 Len=0
64.6 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=36 Ack=114 Win=63989 Len=0
65.7 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=114 Ack=37 Win=4710 Len=0
80.7 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=36 Ack=114 Win=63989 Len=0
81.7 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=114 Ack=37 Win=4710 Len=0
92.2 <client> 172.18.0.6 TLSv1.2 89 Application Data
92.2 172.18.0.6 <client> TCP 54 443 → 30441 [ACK] Seq=37 Ack=149 Win=63989 Len=0
92.5 <client> 172.18.0.6 TLSv1.2 85 Application Data
92.5 172.18.0.6 <client> TCP 54 443 → 30441 [ACK] Seq=37 Ack=180 Win=63989 Len=0
92.5 172.18.0.6 <client> TLSv1.2 87 Application Data
92.7 <client> 172.18.0.6 TCP 54 30441 → 443 [ACK] Seq=180 Ack=70 Win=4677 Len=0
108.0 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=69 Ack=180 Win=63989 Len=0
108.5 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=180 Ack=70 Win=4677 Len=0
123.5 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=69 Ack=180 Win=63989 Len=0
124.5 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=180 Ack=70 Win=4677 Len=0
139.5 172.18.0.6 <client> TCP 54 [TCP Keep-Alive] 443 → 30441 [ACK] Seq=69 Ack=180 Win=63989 Len=0
140.6 <client> 172.18.0.6 TCP 54 [TCP Keep-Alive ACK] 30441 → 443 [ACK] Seq=180 Ack=70 Win=4677 Len=0
149.8 <client> 172.18.0.6 TLSv1.2 89 Application Data
149.8 172.18.0.6 <client> TCP 54 443 → 30441 [ACK] Seq=70 Ack=215 Win=63989 Len=0
150.1 <client> 172.18.0.6 TLSv1.2 85 Application Data
150.1 172.18.0.6 <client> TCP 54 443 → 30441 [ACK] Seq=70 Ack=246 Win=63989 Len=0
150.1 172.18.0.6 <client> TLSv1.2 87 Application Data
150.3 <client> 172.18.0.6 TCP 54 30441 → 443 [ACK] Seq=246 Ack=103 Win=4644 Len=0
You can see that MQTT keepalive packets are sent at 33s, 92s, 150s (roughly 60s apart) which is right but then TCP keepalive packets are being sent in between.
If I connect a device straight to rabbitmq (not through Caddy) using plain MQTT on port 1883 then I have no problem using longer MQTT keepalive, which makes me believe that it’s the Caddy proxy which is causing the problem and not something else. I also found that Golang sets a default TCP keepalive of 15s which makes me think caddy is generating them.
So I am wondering if there’s a setting somewhere which controls a) the tcp keepalives and b) when the proxy is closed due to inactivity. I am assuming here that Caddy is closing the proxy for some reason after a minute of inactivity but I could be wrong about this.
I am coming round to the idea that perhaps I just need to connect directly to rabbitmq using mqtts which would probably result in less problems but I thought I’d just check if there’s a way of making it work through Caddy first.
This is the log output from the client when the keepalive is set to a high value, which results in mqtt disconnecting frequently:
I (16:27:34.102) MQTT: MQTT Connected
I (16:28:43.165) TRANSPORT_WS: Got CLOSE frame with status code=1000
W (16:28:43.173) TRANSPORT_WS: esp_transport_ws_poll_connection_closed: unexpected data readable on socket=57
W (16:28:43.174) TRANSPORT_WS: Connection terminated while waiting for clean TCP close
E (16:28:43.183) MQTT_CLIENT: mqtt_message_receive: transport_read() error: errno=119
E (16:28:43.192) MQTT_CLIENT: mqtt_process_receive: mqtt_message_receive() returned -1
W (16:28:43.204) MQTT: MQTT disconnected
I (16:29:02.113) MQTT: MQTT Connected
I (16:30:03.170) TRANSPORT_WS: Got CLOSE frame with status code=1000
W (16:30:03.177) TRANSPORT_WS: esp_transport_ws_poll_connection_closed: unexpected data readable on socket=57
W (16:30:03.178) TRANSPORT_WS: Connection terminated while waiting for clean TCP close
E (16:30:03.188) MQTT_CLIENT: mqtt_message_receive: transport_read() error: errno=119
E (16:30:03.197) MQTT_CLIENT: mqtt_process_receive: mqtt_message_receive() returned -1
W (16:30:03.210) MQTT: MQTT disconnected
MQTT is connected for around a minute then disconnects.
I tried the following but it made no difference, probably because websockets aren’t http:
reverse_proxy /ws rabbitmq:15675 {
keepalive off
