Tailscale + caddy https not working after first time
Not being able to get CA certificate with tailscale after the first time.
{"level":"info","ts":1711194450.518464,"msg":"using provided configuration","config_file":"/etc/caddy/Cad}
{"level":"warn","ts":1711194450.6241379,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwri}
{"level":"info","ts":1711194450.671978,"logger":"admin","msg":"admin endpoint started","address":"localho}
{"level":"info","ts":1711194450.6745296,"logger":"http.auto_https","msg":"server is listening only on the}
{"level":"info","ts":1711194450.6748042,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS }
{"level":"debug","ts":1711194450.6752484,"logger":"http.auto_https","msg":"adjusted config","tls":{"autom}
{"level":"debug","ts":1711194450.6856575,"logger":"http","msg":"starting server loop","address":"[::]:80"}
{"level":"info","ts":1711194450.6863039,"logger":"http.log","msg":"server running","name":"remaining_auto}
{"level":"info","ts":1711194450.687011,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1711194450.6914823,"logger":"tls.cache.maintenance","msg":"started background certif}
{"level":"info","ts":1711194450.7327113,"msg":"failed to sufficiently increase receive buffer size (was: }
{"level":"debug","ts":1711194450.7348628,"logger":"http","msg":"starting server loop","address":"[::]:443}
{"level":"info","ts":1711194450.7350845,"logger":"http.log","msg":"server running","name":"srv0","protoco}
{"level":"info","ts":1711194450.7642596,"msg":"autosaved config (load with --resume flag)","file":"/confi}
{"level":"info","ts":1711194450.7648487,"msg":"serving initial configuration"}
{"level":"warn","ts":1711194450.82002,"logger":"tls","msg":"storage cleaning happened too recently; skipp}
{"level":"info","ts":1711194450.8221798,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"debug","ts":1711194528.9645557,"logger":"events","msg":"event","name":"tls_get_certificate","id}
{"level":"debug","ts":1711194528.975552,"logger":"tls.handshake","msg":"no matching certificates and no c}
{"level":"debug","ts":1711194528.975886,"logger":"tls.handshake","msg":"no matching certificates and no c}
{"level":"debug","ts":1711194528.9759614,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194528.9760218,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194528.9760816,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194528.9762642,"logger":"tls.handshake","msg":"no certificate matching TLS Clie}
{"level":"debug","ts":1711194528.9836023,"logger":"http.stdlib","msg":"http: TLS handshake error from 172}{"level":"debug","ts":1711194529.9345684,"logger":"events","msg":"event","name":"tls_get_certificate","id}
{"level":"debug","ts":1711194529.9361234,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194529.9363244,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194529.9364479,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194529.9365647,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194529.9366813,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194529.9369273,"logger":"tls.handshake","msg":"no certificate matching TLS Clie}
{"level":"debug","ts":1711194529.9427412,"logger":"http.stdlib","msg":"http: TLS handshake error from 172}{"level":"debug","ts":1711194530.6413088,"logger":"http.stdlib","msg":"http: TLS handshake error from 172}
{"level":"debug","ts":1711194553.0504,"logger":"events","msg":"event","name":"tls_get_certificate","id":"}{"level":"debug","ts":1711194553.0526292,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194553.0528328,"logger":"tls.handshake","msg":"no matching certificates and no }{"level":"debug","ts":1711194553.05296,"logger":"tls.handshake","msg":"no matching certificates and no cu}
{"level":"debug","ts":1711194553.053072,"logger":"tls.handshake","msg":"no matching certificates and no c}{"level":"debug","ts":1711194553.053182,"logger":"tls.handshake","msg":"no matching certificates and no c}
{"level":"debug","ts":1711194553.0535116,"logger":"tls.handshake","msg":"no certificate matching TLS Clie}
{"level":"debug","ts":1711194553.0554667,"logger":"http.stdlib","msg":"http: TLS handshake error from 172}
{"level":"info","ts":1711194690.6617126,"logger":"admin.api","msg":"received request","method":"POST","ho}
{"level":"info","ts":1711194690.669924,"msg":"config is unchanged"}
{"level":"info","ts":1711194690.6702116,"logger":"admin.api","msg":"load complete"}
{"level":"info","ts":1711194790.5546253,"logger":"admin.api","msg":"received request","method":"POST","ho}
{"level":"info","ts":1711194790.57294,"logger":"admin","msg":"admin endpoint started","address":"localhos}
{"level":"info","ts":1711194790.575305,"logger":"http.auto_https","msg":"server is listening only on the }
{"level":"info","ts":1711194790.5756228,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS }
{"level":"debug","ts":1711194790.5763958,"logger":"http.auto_https","msg":"adjusted config","tls":{"autom}
{"level":"debug","ts":1711194790.5839634,"logger":"http","msg":"starting server loop","address":"[::]:80"}
{"level":"info","ts":1711194790.5842729,"logger":"http.log","msg":"server running","name":"remaining_auto}
{"level":"info","ts":1711194790.5848498,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"debug","ts":1711194790.5851398,"logger":"http","msg":"starting server loop","address":"[::]:443}{"level":"info","ts":1711194790.5852385,"logger":"http.log","msg":"server running","name":"srv0","protoco}
{"level":"info","ts":1711194790.5854242,"logger":"http","msg":"servers shutting down with eternal grace p}
{"level":"info","ts":1711194790.5934982,"msg":"autosaved config (load with --resume flag)","file":"/confi}{"level":"info","ts":1711194790.6022587,"logger":"admin.api","msg":"load complete"}
{"level":"info","ts":1711194790.6304986,"logger":"admin","msg":"stopped previous server","address":"local}
{"level":"debug","ts":1711194822.955547,"logger":"events","msg":"event","name":"tls_get_certificate","id"}
{"level":"debug","ts":1711194822.9566104,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194822.9567468,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194822.9568245,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194822.9568923,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194822.9569638,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194839.2144682,"logger":"tls.handshake","msg":"using externally-managed certifi}
{"level":"debug","ts":1711194839.2900548,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.3773313,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194839.5522234,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.5572228,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.564637,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.582307,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.5844734,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.5993066,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.601491,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.664308,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.666504,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.675325,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.6802447,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.6969726,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.7135148,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.7158349,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.7210596,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.723289,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194839.7401738,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194839.871429,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194839.8686006,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194840.0354888,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194840.9934971,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.1424139,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.4828594,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5101826,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5116918,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5125198,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5133953,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5144143,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5152748,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5161242,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5169623,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5206068,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194841.5498998,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194842.0106542,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194842.2072084,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194842.2298312,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194843.3666027,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194843.381461,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194843.964385,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194844.489565,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194845.5469456,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.561147,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194845.5622318,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5725946,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5737743,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.574588,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194845.575336,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194845.5761313,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5768821,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5817556,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5882196,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5895686,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.5919898,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194845.8510666,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194847.6211653,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194847.7406003,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194847.845113,"logger":"events","msg":"event","name":"tls_get_certificate","id"}
{"level":"debug","ts":1711194847.916819,"logger":"tls.handshake","msg":"no matching certificates and no c}
{"level":"debug","ts":1711194848.0288198,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194848.0484116,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194848.0488267,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194848.0489101,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194848.1241672,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194848.3001683,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194848.5094032,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194848.604773,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194848.6215885,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194848.626401,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194848.9027667,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194848.906048,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194848.94389,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","}
{"level":"debug","ts":1711194849.122429,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194849.1793482,"logger":"events","msg":"event","name":"tls_get_certificate","id}
{"level":"debug","ts":1711194849.189608,"logger":"tls.handshake","msg":"no matching certificates and no c}
{"level":"debug","ts":1711194849.1899195,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194849.1900136,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194849.1900933,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194849.1901715,"logger":"tls.handshake","msg":"no matching certificates and no }
{"level":"debug","ts":1711194849.2604697,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194849.3602483,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194849.4890554,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194849.5269866,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194849.8606732,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194850.3103137,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194850.5788128,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194850.6565144,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194851.1351876,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194851.1948972,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194851.993243,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194851.997027,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194852.5241306,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194852.7802434,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194852.8750503,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194854.8863745,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194855.9628356,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194855.9657376,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194855.9669333,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.014142,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.062575,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.086894,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.0899377,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.092723,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.1149828,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.116997,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.1302695,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.146892,"logger":"http.handlers.reverse_proxy","msg":"selected upstream",}
{"level":"debug","ts":1711194856.1357882,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.1347992,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194856.3998826,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194857.9246788,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194858.1870034,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194858.4656112,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194858.6036708,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194859.4273186,"logger":"http.handlers.reverse_proxy","msg":"selected upstream"}
{"level":"debug","ts":1711194859.473549,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194859.629727,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194859.702844,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip"}
{"level":"debug","ts":1711194860.3401885,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194861.1108086,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
{"level":"debug","ts":1711194861.1598299,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip}
I used this docker-composed:
version: "3.7"
  proxy-network:
    image: caddy:latest
      - proxy-network
    hostname: caddy
    depends_on:
      - tailscale
      - "8080:80"
      - "8443:443"
      - "8443:443/udp"
      - /home/aikooo7/.docker/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /home/aikooo7/.docker/caddy/data:/data
      - /home/aikooo7/.docker/caddy/config:/config
      - /home/aikooo7/.docker/tailscale/tmp/tailscaled.sock:/var/run/tailscale/tailscaled.sock
  tailscale:
    container_name: tailscaled
    image: tailscale/tailscale
    network_mode: host
    cap_add:
      - NET_ADMIN
      - NET_RAW
      - /home/aikooo7/.docker/tailscale/varlib:/var/lib
      - /home/aikooo7/.docker/tailscale/tmp:/tmp
      - TS_STATE_DIR=/var/lib/tailscale
      - TS_EXTRA_ARGS=--advertise-tags=tag:container
      - TS_AUTH_KEY=supersecretkey
Alpine Linux;
Docker version 25.0.4, build 1a576c50a9a33dd7ab2bcd78db1982cb965812b0
Cited at the docker compose
Not revelant
testtt.tail4fad.ts.net {
        reverse_proxy homepage:3000
ts.net subdomains are private only
So isn’t possible to have https on it?
Might be related: Auto HTTPS with Tailscale not working on 2.7.3
Your logs look strangely truncated. Hard to help without seeing the full logs. It does seem like your server is successfully receiving requests though, because of those debug logs for the proxy. I’m not sure I understand what the problem is.
Hey Francis thanks for the answer but I already fixed it but adding the file /etc/default/tailscaled to the tailscaled container via a docker volume with the following content:
TS_PERMIT_CERT_UID=caddy
I will keep it here as it may help others.
Thanks for your help anyways!
yep, this is also in Tailscale’s documentation.
