Auto HTTPS with Tailscale not working on 2.7.3
In the new 2.7.3 update, SSL with Tailscale is not working. I’ve tested on 2.7.3 and then again on 2.6.4. It still does work on 2.6.4.
Here are the debug logs from 2.7.3:
{"level":"debug","ts":1691996068.5566437,"logger":"events","msg":"event","name":"tls_get_certificate","id":"bc161537-3252-4d91-a30b-101f18f7fb43","origin":"tls","data":{"client_hello":{"CipherSuites":[39578,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"ServerName":"machine-name.tailscale-host.ts.net","SupportedCurves":[64250,29,23,24],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,1281,2054,1537],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[31354,772,771],"Conn":{}}}}
{"level":"debug","ts":1691996068.556993,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.ts.net"}
{"level":"debug","ts":1691996068.557011,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"100.*.*.*","remote_port":"49482","server_name":"machine-name.tailscale-host.ts.net","remote":"100.*.*.*:49482","identifier":"machine-name.tailscale-host.ts.net","cipher_suites":[39578,4865,4866,4867,49195,49199,49196,49200,52393,52392,49171,49172,156,157,47,53],"cert_cache_fill":0,"load_or_obtain_if_necessary":true,"on_demand":false}
Debian, tested on both bullseye and bookworm.
start.sh
sysctl -w net.core.rmem_max=2048000
mkdir --parents /data/caddy/caddy /data/tailscale
tailscaled --state=/var/lib/tailscale/tailscaled.state --socket=/var/run/tailscale/tailscaled.sock &
sleep 5
if [ ! -S /var/run/tailscale/tailscaled.sock ]; then
    echo "tailscaled.sock does not exist. exit!"
    exit 1
fi
until tailscale up --authkey=${TS_AUTHKEY} --hostname=${TS_HOSTNAME}
do
  sleep 0.1
done
exec "$@"
command:
CMD ["caddy", "run", "--config", "/config/caddy/caddy.json"]
This is for Fly.io
  services = [
      ports = [
          port     = 443
          handlers = ["tls", "http"]
          port     = 80
          handlers = ["http"]
      "protocol" : "tcp",
      "internal_port" : 443
  "admin": {
    "disabled": true
  "logging": {
    "logs": {
      "default": {
        "level": "DEBUG"
      "platform": {
        "level": "DEBUG",
        "writer": {
          "output": "stdout"
        "include": [
          "http.log.access.platform"
  "apps": {
    "http": {
      "http_port": 80,
      "https_port": 443,
      "servers": {
        "services": {
          "listen": [":80", ":443"],
          "logs": {
            "default_logger_name": "platform"
          "routes": [
              "handle": [
                  "handler": "subroute",
                  "routes": [
                      "match": [
                          "host": [
                            "fly-app.tailnet-name.ts.net"
                      "handle": [
                          "handler": "reverse_proxy",
                          "upstreams": [
                              "dial": "fly-app.internal:9101"
              "terminal": true
It works for me.
What are your full logs? No redactions please (this is a forum rule).
Please post the full logs as the help template requires so we know how to help you.
