to noob to answer
This is about the only part of this template I can use and I don’t feel comfortable here already with these strict guidelines,
But I do need help and will at least try
First, I have no idea what caddy is and am confused, what I need help with may be to elementary for this site but… I may not be alone and may well help others to speak up
I only found caddy giving nostr a try, I followed the instructions here:
I made it through to “apt install caddy” and if I go to my IP I see the angle sheet “caddy works”
Caddy is a general purpose webserver. It’s similar to Apache or Nginx. That guide you linked uses it as a reverse proxy (i.e. a server that sits in front of another server/app) to automate TLS setup (so you have HTTPS instead of HTTP).
Make sure to read through the homepage:
That guide covers it, your config is at /etc/caddy/Caddyfile.
Make sure to follow our official installation instructions:
Thanks for all that, I never tried to just nano /etc/caddy/Caddyfile which was a big help, unfortunately I got conflicting info, tried both, neither worked, but I think its a nostr issue and not one to bothered with here
When I began the IP direct worked (caddy read it works) but not the url, even with DNS directing A setting
as I recall that page (caddy page it works page) (or somewhere) it read to change the 80: to my url and also one other setting, a file directory, and then restart
As the url still didn’t work I then tried what the nostr page directed
If people here are willing to help I’m willing to provide whatever is needed on my end including starting over, Caddy itself is active so I don’t expect errors related to that, as I’ve said I’m a noob, this is an expedition of sorts, I heard of Nostr and that lead me here to Caddy, I just done’t want to trouble anyone here if its not desired, I can not PM anyone either so feel I’m perhaps muddying the board.
We’re all happy to help, here. The error logs are necessary to provide a solution, and it will indicate if the problem lies within a Caddy configuration or something else. Lots of the guys here understand how other services interact with Caddy. I, however, don’t know anything about Nostr.
Have you tried looking here for potential solutions?
I’m going to delete my Nostr and cease for now, prioritize, had a rocky start here but pleased to report I’m very happy with this board and looking forward to finding out more about Caddy software
