1. Caddy version:
caddy:latest (v2.6.7)
Using Docker composer.yaml, build and run through GUI.
Synology DSM 7.2.1-69057 Update 3
Docker version(Container Manager) - 20.10.2.3
a. Docker composer.yaml:
version: "3.7"
proxy-network:
image: caddy:latest
- proxy-network
hostname: caddy
depends_on:
- tailscale
- "8080:80"
- "8443:443"
- "8443:443/udp"
- /volume1/docker/caddy/Caddyfile:/etc/caddy/Caddyfile
- /volume1/docker/caddy/data:/data
- /volume1/docker/caddy/config:/config
- /volume1/docker/tailscale/tmp/tailscaled.sock:/var/run/tailscale/tailscaled.sock
tailscale:
container_name: tailscaled
image: tailscale/tailscale
network_mode: host
cap_add:
- NET_ADMIN
- NET_RAW
- /volume1/docker/tailscale/varlib:/var/lib
- /volume1/docker/tailscale/tmp:/tmp
- TS_STATE_DIR=/var/lib/tailscale
- TS_AUTH_KEY=MY_TAILSCALE_AUTH_KEY
mytailscaledomain.ts.net {
get_certificate tailscale
handle_path /teslamate {
reverse_proxy teslamate-app:1000 <<"teslamate-app" is the project name. The underlying container names are "teslamate-grafana-1". Tried both, neither worked>>
handle_path /immich {
reverse_proxy immich-app:1001
Followed the above steps and tried reverse proxy setup on my Synology NAS.
After setting up everything and hit the URL: https://mytailscaledomain.ts.net/teslamate.
It’s defaulting to https://mytailscaledomain.ts.net:<DSM_HOME_HTTPS_PORT>/teslamate, and throwing the error - “Sorry, the page you are looking for is not found.”
Am i missing any other configurations on my NAS or Tailscale settings?
Please help. I’m pulling my hairs on this. Below are my docker and caddy file details.
Tried following caddy documentation and couple of other online similar posts, I don’t have much expereince with caddy to try beyond this.
https://caddy.community/t/taiscale-synology-https-to-docker-services/18834
https://www.reddit.com/r/Tailscale/comments/104y6nq/docker_tailscale_and_caddy_with_https_a_love_story/
