Reverse proxy returning blank page in docker
2.4.6
I run caddy through docker compose
Docker on macOS Server
No commands used
version: "3.8"
  komga:
    container_name: komga
    image: gotson/komga
      - PUID=${PUID}
      - PGID=${PGID}
      - TZ=${TZ}
      - JAVA_TOOL_OPTIONS=-Xmx4g
      - SERVER_PORT=8081
      - ${ROOT_CONF}/komga:/config # config files
      - ${ROOT_DATA}/Media/Comics:/data # data folder
    image: caddy
      - PUID=${PUID}
      - PGID=${PGID}
      - TZ=${TZ}
      - ${ROOT_APP}/caddy/Caddyfile:/etc/caddy/Caddyfile
      - ${ROOT_APP}/caddy/site:/srv
      - ${ROOT_APP}/caddy/data:/data
      - ${ROOT_APP}/caddy/config:/config
      - 443:443
myserver.com {
  log
  reverse_proxy /komga/* komga:8081
When I navigate to https://myserver.com/komga it returns a blank webpage. I expected it to show the komga webpage which works using http://127.0.0.1:8081
Log file
{"level":"info","ts":1637778544.7673826,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1637778544.7679336,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
{"level":"info","ts":1637778544.7692125,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1637778544.7693286,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1637778544.769336,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1637778544.7695339,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0x400029c0e0"}
{"level":"info","ts":1637778544.7699456,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1637778544.770441,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["myserver.com"]}
{"level":"info","ts":1637778544.8046563,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1637778544.8046868,"msg":"serving initial configuration"}
{"level":"info","ts":1637778544.8106759,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1637778556.4096696,"logger":"http.log.access","msg":"handled request","request":{"remote_addr":"172.18.0.1:65084","proto":"HTTP/2.0","method":"GET","host":"myserver.com","uri":"/komga","headers":{"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"96\", \"Google Chrome\";v=\"96\""],"Sec-Ch-Ua-Platform":["\"macOS\""],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua-Mobile":["?0"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.55 Safari/537.36"],"Sec-Fetch-Site":["none"],"Sec-Fetch-User":["?1"],"Accept-Language":["en-US,en;q=0.9"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"myserver.com"}},"common_log":"172.18.0.1 - - [24/Nov/2021:18:29:16 +0000] \"GET /komga HTTP/2.0\" 0 0","user_id":"","duration":0.000377875,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
{"level":"info","ts":1637778556.4399047,"logger":"http.log.access","msg":"handled request","request":{"remote_addr":"172.18.0.1:65084","proto":"HTTP/2.0","method":"GET","host":"myserver.com","uri":"/favicon.ico","headers":{"Accept-Language":["en-US,en;q=0.9"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"96\", \"Google Chrome\";v=\"96\""],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.55 Safari/537.36"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Sec-Fetch-Mode":["no-cors"],"Sec-Fetch-Dest":["image"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Sec-Fetch-Site":["same-origin"],"Referer":["https://myserver.com/komga"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"myserver.com"}},"common_log":"172.18.0.1 - - [24/Nov/2021:18:29:16 +0000] \"GET /favicon.ico HTTP/2.0\" 0 0","user_id":"","duration":0.000029292,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
Curl
curl -v https://myserver.com/komga
* ALPN, offering h2
* ALPN, offering http/1.1
*  CAfile: /etc/ssl/cert.pem
*  CApath: none
* TLSv1.2 (OUT), TLS handshake, Client hello (1):
* TLSv1.2 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-ECDSA-CHACHA20-POLY1305
*  subject: CN=myserver.com
*  start date: Oct  3 15:21:05 2021 GMT
*  expire date: Jan  1 15:21:04 2022 GMT
*  subjectAltName: host "myserver.com" matched cert's "myserver.com"
* Using Stream ID: 1 (easy handle 0x154812800)
> GET /komga HTTP/2
> Host: myserver.com
> user-agent: curl/7.77.0
> accept: */*
< HTTP/2 200
< server: Caddy
< content-length: 0
< date: Wed, 24 Nov 2021 18:46:34 GMT
* Connection #0 to host myserver.com left intact
  • Used respond to ensure caddy is working properly without reverse proxy
  • Used wget from the caddy container to the komga container to make sure the service name could be used and it returned the HTML I expected
  • Different types of configurations in the caddy config file like including http:// in the docker service name, using subdomains komga.myserver.com for example.
  • Installed caddy on the host OS (macOS) and still had the same issue, wanted to eliminate an issue with docker desktop. I uninstalled caddy from the OS since this didn’t work.
  • Curl commands to find any errors
Your path matcher is /komga/* so a request like /komga will not match, because it doesn’t have the expected trailing slash. Use /komga* instead, (or just omit the matcher entirely, if it’s the only thing you’re proxying).
Thank you, that resolved the reverse proxy issue with Caddy.
For anyone else running into this problem with Komga, I also needed to add the following environment variable to the Komga (via the docker compose file) so it can support the base url needed for the reverse proxy to work.
SERVER_SERVLET_CONTEXT_PATH=/komga
