aronchick
(David Aronchick)
May 12, 2024, 12:01am
1
I’d like to write my logs to a file.
No errors, it’s just that the access log keeps going to stdout instead of to the file.
Nothing special - just installed the go library, then ran xcaddy to build it.
Nothing relevant - latest MacOS
xcaddy run --config caddyfile-logging.json
N/A
"logging": {
"logs": {
"access-formatted": {
"writer": {
"filename": "/tmp/access-foo.log",
"output": "file"
"include": [
"http.log.access.foo"
"access-json": {
"writer": {
"filename": "/tmp/access-foo.json",
"output": "file"
"encoder": {
"format": "json"
"include": [
"default": {
"exclude": [
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":443"
"routes": [
"match": [
"host": [
"foo.example.com",
"localhost"
"terminal": true
"logs": {
"logger_names": {
"foo.example.com": "foo",
"localhost": "bar"
Can you show evidence of the problem? Show how you’re testing this.
What version of Caddy are you using, exactly.
aronchick
(David Aronchick)
May 12, 2024, 4:11pm
3
$ xcaddy version
v0.4.0 h1:V4n6nNlkRPmrgE+npteBjS7hgMfw24UEmiIONDpIWSo=
$ xcaddy run --config=caddyfile-logging.json
2024/05/12 15:55:58.146 INFO http.log server running {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2024/05/12 15:55:58.146 INFO http.log server running {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2024/05/12 15:55:58.146 INFO http enabling automatic TLS certificate management {"domains": ["localhost"]}
2024/05/12 15:55:58.147 WARN tls stapling OCSP {"error": "no OCSP stapling for [localhost]: no OCSP server specified in certificate", "identifiers": ["localhost"]}
2024/05/12 15:55:58.151 INFO autosaved config (load with --resume flag) {"file": "/Users/daaronch/Library/Application Support/Caddy/autosave.json"}
2024/05/12 15:55:58.151 INFO serving initial configuration
2024/05/12 15:55:58.169 WARN tls storage cleaning happened too recently; skipping for now {"storage": "FileStorage:/Users/daaronch/Library/Application Support/Caddy", "instance": "9cfc62d9-28c4-469a-bdd5-97fb30adf0e9", "try_again": "2024/05/13 15:55:58.169", "try_again_in": 86399.999999708}
2024/05/12 15:55:58.169 INFO tls finished cleaning storage units
[Now waits for requests]
Second window:
$ curl localhost
$ # Finished correctly
First window (STDOUT - not to the file):
2024/05/12 15:56:42.988 INFO http.log.access.bar handled request {"request": {"remote_ip": "::1", "remote_port": "64853", "client_ip": "::1", "proto": "HTTP/1.1", "method": "GET", "host": "localhost", "uri": "/", "headers": {"Accept": ["*/*"], "User-Agent": ["curl/8.4.0"]}}, "bytes_read": 0, "user_id": "", "duration": 0.000030167, "size": 0, "status": 308, "resp_headers": {"Content-Type": [], "Server": ["Caddy"], "Connection": ["close"], "Location": ["https://localhost/"]}}
List of /tmp (no log files listed):
> ls -la /tmp/access*
That’s the xcaddy
version, not the caddy
version. But I guess since you’re not specifying a Caddy version to xcaddy run
you’re probably getting v2.7.6
aronchick:
http.log.access.bar
You didn’t include/exclude this logger in any of your configured loggers (you only have foo
, but not bar
). Is that an oversight? This means that it’ll end up in the default only because you’re not excluding it, and not including it in the other two which write to files.
What if you try to create the log file by hand first? Do you see the logs there?
The library we use for log rolling isn’t perfect, it might have trouble making the file itself.
Also keep in mind that /tmp
is virtualized when running as a systemd service, so it actually ends up in /tmp/systemd-private-<somehash>-caddy.service-<someID>/tmp
instead. But that’s probably not the case for you here cause you’re running Caddy directly from CLI.
aronchick
(David Aronchick)
May 14, 2024, 6:59pm
5
oh, this is interesting as well - can you only write to one log at a time? that’s helpful!
aronchick
(David Aronchick)
May 14, 2024, 7:00pm
6
i THINK both of these had the same root cause - here’s what I discovered:
Ok, FWIW, here’s what i got to work with minimal repro:
WORKS (BTW, this is the output of caddy adapt with logging at the top)
"logging": {
"logs": {
"default": {
"exclude": [
"http.log.access.filelog"
"filelog": {
"writer": {
"filename": "access-foo.json",
"output": "file"
"include": [
No, you can definitely write to more than one file. I’m not certain why the file wasn’t being created though. But did you try creating it by hand (i.e. touch
command)?
aronchick
(David Aronchick)
May 14, 2024, 10:09pm
8
just tried touching the file first with the below - no joy.
"logging": {
"logs": {
"default": {
"exclude": [
"filelog": {
"writer": {
"output": "file"
"include": [
"apps": {
"http": {
"servers": {
"spartacus_server": {
"listen": [
":443"
"routes": [
"handle": [
"body": "Hello",
"handler": "static_response"
"match": [
"host": [
"localhost"
"logs": {
"logger_names": {
"spartacus_server": "filelog"
matt
(Matt Holt)
May 15, 2024, 3:04am
9
I think it’s because you are sending localhost
access logs to a logger named “bar” but you don’t have a logger named “bar” – just “access-formatted” and “access-json” and, of course, “default”.
It’s been a long time since I’ve looked at this code but I think that’s the issue?
aronchick
(David Aronchick)
May 15, 2024, 6:20pm
10
That was an old one - i misunderstood what that field was for (i thought it was a prefix in your log)
system
(system)
Closed
June 14, 2024, 6:21pm
11
