1. My Caddy version (caddy version): v2, RC3
2. How I run Caddy: Docker
example.ca {
file_server {
root /mnt/welcome
index index.html
tls email@example.ca
import /config/caddy/caddy_security.conf
subdomain1.example.ca {
reverse_proxy 10.10.2.10:80
redir / "/word/#/tp"
subdomain2.example.ca {
file_server {
root /mnt/somefiles
browse
caddy_security.conf:
header / {
X-Xss-Protection "1; mode=block"
X-Frame-Options "DENY"
Content-Security-Policy "upgrade-insecure-requests"
Cache-Control "public, max-age=15, must-revalidate"
Feature-Policy "accelerometer 'none'; ambient-light-sensor 'none'; autoplay 'self'; camera 'none'; encrypted-media 'none'; fullscreen 'self'; geolocation 'none'; gyroscope 'none'; magnetometer 'none'; microphone 'none'; midi 'none'; payment 'none'; picture-in-picture *; speaker 'none'; sync-xhr 'none'; usb 'none'; vr 'none'"
Server "No."
Visiting securityheaders.io, example.ca and subdomain2.example.ca pass with A+, with a whole set of correctly set headers.
subdomain1.example.ca fails with an F, with not a single set header.
Now of course, the difference between example.ca and subdomain2.example.ca if that they serve static files, while subdomain1 is a reverse proxy. There must be something obvious I’m missing here, but I’ve been at it trying so many things for about 2 hours.
Any ideas would be appreciated!
edit: Aha, I did notice that by commenting out the redir, it passes with an A+ and all the headers are correctly set! So is the redir bypassing the headers? Input the full URL that the redir normally points to gives an F. I checked the other subdomains, and if I throw in a directory at the end of it they also fail too.
