Connection refused / 502 / Upgrade-Insecure-Requests error for a single app, the rest work fine
1. Caddy version:
v2.6.2
docker compose
Docker, Lubuntu
docker compose up caddy -d
version: "3.8"
    external: true
    image: caddy:latest
      - caddy
      - "443:443/udp"
      - /opt/appdata/caddy/Caddyfile:/etc/caddy/Caddyfile:rw
      - /opt/appdata/caddy/site:/srv
      - /opt/appdata/caddy/data:/data/caddy
      - /opt/appdata/caddy/config:/config/caddy
  gotify:
    image: gotify/server
    container_name: gotify
      - caddy
      - "/opt/appdata/gotify:/app/data"
    restart: always
    cert_issuer zerossl [redacted]
    email [redacted]
(authentik) {
	reverse_proxy /outpost.goauthentik.io/* http://authentik:9000
	forward_auth http://authentik:9000 {
		uri /outpost.goauthentik.io/auth/caddy
		copy_headers X-Authentik-Username X-Authentik-Groups X-Authentik-Email X-Authentik-Name X-Authentik-Uid X-Authentik-Jwt X-Authentik-Meta-Jwks X-Authentik-Meta-Outpost X-Authentik-Meta-Provider X-Authentik-Meta-App X-Authentik-Meta-Version
# works fine
auth.example.com {
    reverse_proxy authentik:9000
gotify.example.com {
    # No authenik here for now, just trying to get it working normally first
    # I experienced this problem before authentik was installed
    reverse_proxy gotify:1245
# works fine
example.com {
    import authentik
    reverse_proxy homepage:3000
Caddy gives me errors when accessing a single service (Gotify) via reverse proxy despite the service working just fine on localhost:port. No other app experiences this problem, and they are set up identically.
caddy  | {"level":"error","ts":1675163175.496656,"logger":"http.log.error","msg":"dial tcp 172.22.0.8:1245: connect: connection refused","request":{"remote_ip":"192.168.1.1","remote_port":"60424","proto":"HTTP/2.0","method":"GET","host":"gotify.example.com","uri":"/","headers":{"User-Agent":["curl/7.85.0"],"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"gotify.example.com"}},"duration":0.001130156,"status":502,"err_id":"7ys3ep101","err_trace":"reverseproxy.statusError (reverseproxy.go:1272)"}
caddy  | {"level":"error","ts":1675163184.699816,"logger":"http.log.error","msg":"dial tcp 172.22.0.8:1245: connect: connection refused","request":{"remote_ip":"192.168.1.1","remote_port":"37216","proto":"HTTP/2.0","method":"GET","host":"gotify.example.com","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:109.0) Gecko/20100101 Firefox/109.0"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":[],"Upgrade-Insecure-Requests":["1"],"Te":["trailers"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Site":["same-site"],"Sec-Fetch-User":["?1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"gotify.example.com"}},"duration":0.000409353,"status":502,"err_id":"0s3vmtzzs","err_trace":"reverseproxy.statusError (reverseproxy.go:1272)"}
  • Mapping different ports to the Gotify docker container
  • Mapping a local port to port 443 in the container (1245:443)
Security Headers not Working with Reverse Proxy? (I’m not using caddy security so I wasn’t sure how to make this apply to me)
When you proxy to other containers, you should use the port internal to the docker network, not one you bound to the host. So use gotify:80 instead.
And you can remove the port mapping for that service from your docker-compose file, because you should let Caddy protect access to it. If you publish it to the host, then anything on your host (or anything that can connect to your host) will be able to reach that container, allowing a bypass of your authentication.
Ah somehow I didn’t catch that, that worked perfectly. Thanks!
