Tried both 2.2.1
& 2.3
using the caddy alpine docker
start docker:
docker run --rm -it -h node2 --name node2 --network my_net -p 443:443 -v $PWD/Caddyfile:/etc/caddy/Caddyfile -v caddy_data:/data --link node1 caddy:2.3.0-alpine
docker on fedora linux:
Client: Docker Engine - Community
Version: 19.03.8
API version: 1.40
Go version: go1.12.17
Git commit: afacb8b
Built: Wed Mar 11 01:26:01 2020
OS/Arch: linux/amd64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.8
API version: 1.40 (minimum version 1.12)
Git commit: afacb8b
Built: Wed Mar 11 01:24:39 2020
Experimental: false
containerd:
Version: 1.2.13
GitCommit: 7ad184331fa3e55e52b890ea95e65ba581ae3429
runc:
Version: 1.0.0-rc10
GitCommit: dc9208a3303feef5b3839f4323d9beb36df0a9dd
docker-init:
Version: 0.18.0
GitCommit: fec3683
Refer point 2
Clean docker
from caddy repo
localhost
level DEBUG
reverse_proxy {
to h2c://node1:8008
versions h2c 2
Also tried:
localhost
level DEBUG
reverse_proxy h2c://node1:8008
docker named node1
providing GRPC
service on port 8008
without TLS
the docker also publish the port to localhost
and I can query it using:
grpcurl -plaintext -proto main.proto 127.0.0.1:8008 pb.TenantService/List
I can also successfully run it form the caddy
docker itself using:
grpcurl -plaintext -proto main.proto node1:8008 pb.TenantService/List
But any attempt to run through the exposed 443
port of caddy
fail.
# grpcurl -insecure -proto main.proto node2:443 pb.TenantService/List
Failed to dial target host "node2:443": remote error: tls: internal error
caddy
itself does not log any error
