Docker caddy:2.2.1-alpine
Also tested with v2.4.5
Using docker
Docker system on Ubuntu
docker-compose up
c. compose file:
docker-compose file:
version: "3.2"
api:
container_name: mapper-api
image: docker-repo-/mapper-api:v1.2.3
- /tmp:/host
restart: on-failure
command: serve -dgAddr 172.31.0.2:9080
- api_net
gw:
image: caddy:2.2.1-alpine
- /tmp:/host
- ${PWD}/Caddyfile:/etc/caddy/Caddyfile:ro
- ${PWD}/caddy_data:/data
- ${PWD}/caddy_config:/config
restart: on-failure
- api_net
api_net:
driver: bridge
# domain name.
grpc.mapper.com
level INFO
reverse_proxy {
to h2c://api:8008
versions h2c 2
This configuration worked since Jan 2021.
It listen to port 443 then using h2c it forward the request to the grpc server in clear-text.
Last day (Sep 30) around 5pm GMT grpc cli started to return error:
"error": "14 UNAVAILABLE: failed to connect to all addresses"
- I validated the cert and that the port is open (using firefox), and it is open and valid till end of Dec.
- I opened the port to the insecure endpoint (skipping caddy) and the grpc server behaved correctly.
- The dockers was not restarted or changed in the last month
- I wiped the caddy data dir and restarted to get a new cert/reset/whatever. Didn’t helped.
- Restarted other dockers / upgrade caddy to latest. None helped.
Reverse proxy to GRPC didn’t yield any logs whatsoever and that’s since I started to use Caddy.
Did tried to change Caddy log level ro DEBUG. nothing changed.
Maybe the log directive in my Caddy is incorrect???
My initial discuss on how to implament h2c:
Another discussion about h2c:
