Reverse-Proxy self-hosted Supabase with Caddy
Hi, im pretty new here and never did anything with caddy before.
Currently im trying to secure my Supabase studio that runs at port 3000 because Docker runs on a Windows-Server and we dont want employees to just connect to the database.
I have 2 Docker-Containers, the first one is caddy with the latest version, the second one is Supabase (i followed the tutorial from their site).
How can i reverse-proxy the Container that runs on port 3000 when Caddy is in another Container?
Docker latest
Docker-Image: docker pull caddy
Windows 10 Pro, Docker
localhost {
        reverse_proxy /rest/v1/* localhost:8000
        reverse_proxy /auth/v1/* localhost:8000
        reverse_proxy /realtime/v1/* localhost:8000
        reverse_proxy /storage/v1/* localhost:8000
        reverse_proxy * localhost:3000
        basicauth / {
                joker $2y$10$oPH1//179OXYwKeA3gXfjO4DmoVChbOa66yQ431wItFblhT.W.IAG
localhost in a container means “this same container”.
You need to use the other container’s name as the hostname. So if your container is named supabase, you’d do reverse_proxy supabase:3000.
Make sure both containers share a Docker network.
FYI this will only require authentication for exactly / and nothing else. If you want auth for all pages, you should use remove the / path matcher (leaving it blank means “match all requests”. See Request matchers (Caddyfile) — Caddy Documentation
You can simplify this by using a single path matcher for all of these:
@api path /rest/v1/* /auth/v1/* /realtime/v1/* /storage/v1/*
reverse_proxy @api supabase:8000
